Momed80
150
35,046
LS Tractor PLUS Series P7040 (Old Cabin MECHANICAL) Parts Catalog
Brand: LS
Model: LS PLUS Series P7040 (Old Cabin MECHANICAL) Tractor
Number of Pages: 342 Pages
01. ENGINE
G010S01-04 ENGINE (95)
Q100S01-04 ENGINE ASSY GRP (95)
Q110S01-04 CRANKCASE ASSY (95)
Q115S01-07 ROCKER COVER (95)
Q115S01-08 CYLINDER HEAD COVER (95)
Q115S02-04 AIR BREATHER (95)
Q116S01-04 CYLINDER HEAD (95)
Q116S02-04 LIFTING EYE (95)
Q120S02-04 PISTON (95)
Q120S03-04 CONNECTION ROD (95)
Q120S04-04 CRANKSHAFT (95)
Q122S01-04 CAMSHAFT GRP (95)
Q125S01-13 FUEL SYSTEM (95)
Q125S01-14 FUEL SYSTEM (95)
Q125S01-15 FUEL SYSTEM (95)
Q125S01-16 FUEL SYSTEM (95)
Q125S01-17 FUEL SYSTEM (95)
Q125S02-10 FUEL PUMP & FILTER (95)
Q125S02-11 FUEL PUMP & FILTER (95)
Q125S02-12 FUEL PUMP & FILTER (95)
Q125S03-04 INJECTOR (95)
Q130S01-04 TIMING GEAR & CASE (95)
Q130S02-04 SIDE POWER TAKE-OFF (95)
Q135S01-16 COOLING SYSTEM (95)
Q135S01-17 COOLING SYSTEM (95)
Q135S01-18 COOLING SYSTEM (95)
Q135S01-19 COOLING SYSTEM (95)
Q135S01-20 COOLING SYSTEM (95)
Q135S01-21 COOLING SYSTEM (95)
Q135S01-22 COOLING SYSTEM (95)
Q135S01-23 COOLING SYSTEM (95)
Q135S01-24 COOLING SYSTEM (95)
Q140S01-16 OIL SYSTEM (95)
Q140S01-17 OIL SYSTEM (95)
Q140S01-18 OIL SYSTEM (95)
Q140S01-19 OIL SYSTEM (95)
Q140S01-20 OIL SYSTEM (95)
Q145S01-04 OIL PAN (95)
Q146S01-04 BALANCER (95)
Q150S01-04 FLYWHEEL (95)
Q150S01-05 FLYWHEEL (95)
Q160S02-07 INTAKE MANIFOLD (95)
Q160S02-08 INTAKE MANIFOLD (95)
Q160S02-09 INTAKE MANIFOLD (95)
Q165S01-04 EXHAUST MANIFOLD (95)
Q170S01-04 STARTER (95)
Q175S01-04 ALTERNATOR (95)
Q180S01-07 ELECTRIC PARTS (95)
Q180S01-08 ELECTRIC PARTS (95)
Q185S01-04 TURBOCHARGER (95)
Q185S01-05 TURBOCHARGER (95)
02. ENGINE APPLICATION
G040S01-02 FUEL TANK (95)
G100S01-02 THROTTLE LEVER (L70CA or F)
G100S01-04 THROTTLE PEDAL (L70CA or F,95)
G150S01-04 MUFFLER (95,VERTICAL,F)
G170S01-03 RADIATOR (95,L70CA or F)
G180S01-03 INTER COOLER (95)
G190S01-03 AIR CLEANER (95,L70CA or F)
G210S01-03 ENGINE FRAME (95,TAESAN)
03. TRANSMISSION
G250S01-02 CLUTCH (95,MEC)
G250S02-04 CLUTCH HOUSING (95,MEC)
G260S01-01 CLUTCH PEDAL (L70CA or F,MEC)
G280S01-01 TRANSMISSION CASE (MEC,EXP)
G281S01-01 MAIN SHAFT (MEC)
G281S02-02 MAIN GEAR SHAFT (95,(L70CA or F))
G285S01-01 RANGE GEAR SHAFT
G285S02-02 CREEPER GEAR SHAFT (CRP)
G310S01-01 REAR DIFFERENTIAL
04. PTO DRIVE
G283S01-01 PTO CLUTCH & SHAFT (MEC)
G287S01-01 PTO GEAR & SHAFT (INDP-PTO3,GSP,EXP)
05. FOUR WHEEL DRIVE (4WD)
G288S01-03 4WD DRIVE SHAFT (95,STD)
G288S01-04 4WD SHAFT COVER (95,STD)
G400S01-01 FRONT AXLE ASSY (MHL,WO-FEHD,EXP)
G400S02-01 FRONT AXLE CASE (TAESAN)
G400S02-02 FRONT AXLE CASE (TAESAN,LH,EXP)
G400S02-03 FRONT AXLE CASE (TAESAN,RH,EXP)
G400S03-01 FRONT DIFFERENTIAL (W-O FEHD)
G400S04-01 FRONT DRIVE (TAESAN,EXP)
G610S01-01 TIE-ROD (TAESAN,EXP)
G991S30-01 SVC KIT-FRONT AXLE CASE(LH) (Heavy Duty)
G991S30-02 SVC KIT-FRONT AXLE CASE(RH) (Heavy Duty)
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE
G650S01-01 BRAKE (DO,EXP)
G670S01-03 BRAKE PEDALS (MEC,60LPM)
G670S01-05 BRAKE PEDALS (EXP)
G670S01-07 BRAKE OIL TANK (MEC)
G670S01-10 BRAKE PIPES (L70CA or F,60LPM)
G670S02-02 PARKING BRAKE LEVER
08. SHIFT FORK & LINKAGE
G290S01-01 LEVER&FORK(MAIN GEAR) (L70CA or F)
G290S01-02 LEVER&FORK(F-R GEAR) (L70CA or F,MEC)
G290S01-05 LEVER&FORK(MAIN GEAR) (L70CA or F,PST,TRIPLE CONE)
G290S02-01 MAIN SHIFT LEVER (L70CA or F,MEC)
G291S01-01 LEVER&FORK(RANGE GEAR) (L70CA or F,MEC)
G291S01-02 LEVER&FORK(CREEPER) (CRP)
G291S01-03 LEVER&FORK(PTO) (PTO2,PTO3)
G291S01-05 LEVER&FORK(GSP) (GSP)
G320S01-01 DIFF-LOCK
G630S01-03 STEERING CYLINDER & LINES (95,L70CA or F)
G640S01-03 T-M OIL COOLER (MEC,W-COOLER)
G822S02-01 TM CTRL. VALVE PIPE
G822S02-03 TM CONTROL VALVE (INDP,1-SECOND)
G822S02-07 SEQUENCE VALVE (MEC)
G822S03-06 LOADER VALVE (L70CA or F,60LPM,L-V,WO-COUPLER)
G823S01-12 HYDRAULIC LINES (L70CA or F,95,60LPM,L-V,SEC3)
G827S01-05 REMOTE CONTROL LINE (L70CA or F,60LPM,SEC3-W-FLOAT)
G827S02-02 REMOTE CONTROL VALVE (L70CA or F,60LPM,SEC3-W-FLOAT)
G829S01-05 AUTO LEVELING HYD. LINE (L70CA or F,60LPM,MHL,NO LEVELING)
G730S01-08 ELECTRICAL WIRING (L70CA or F,95,Twin Lamp,EHL,MHL&NO AUTO PTO,EXP)
G730S02-01 7 POLE CONNECTOR (L70CA or F)
G730S60-01 HORN
G740S01-02 BATTERY (160AH)
G750S01-05 METER PANEL (L70CA,72,88,95)
G750S04-01 GRID HEATER (72.88.95)
G760S01-04 LAMP (L70CA,Twin-lamp,RHT,LSTA)
G760S01-08 HEAD LAMP (Twin-lamp)
G760S01-10 SIDE WORK LAMP (L70CA)
G760S03-01 BEACON LAMP (L70CA,DO)
11. HYDRAULIC LIFT UNIT
G820S01-01 HYD. HOUSING ASSY (L70CA or F,MHL,EXP)
G820S02-01 HYDRAULIC HOUSING (MHL)
G822S01-01 LIFT CTRL. VALVE & LINK (MHL)
G824S01-01 POSITION & DRAFT CTRL. LINK (MHL)
G825S01-01 HYD. CONTROL LEVER (L70CA,MHL)
G825S01-02 HYD. LEVER GUIDE (L70CA,MHL)
G825S02-01 AUTO LIFT CTRL. (L70CA or F,MHL)
G826S01-01 HYDRAULIC CYLINDER (MHL)
G828S01-01 UPPER LINK BRACKET (W-DRAFT,STD,DO,EXP,TK(EHL))
G828S01-03 UPPER LINK BRACKET (W-DRAFT,HD-LIFT,DO,EXP,TK(EHL))
12. 3-POINT LINKAGE & HITCH
G891S01-03 DRAWBAR & HITCH (SWING BAR&CLEVIS)
G896S01-03 UPPER & LOWER LINK (TELESCOPIC,STD)
G896S01-08 UPPER & LOWER LINK (TELESCOPIC,HD-LIFT)
G896S02-03 LIFT ROD (NO LEVEL for Telescopic,LSTA,AG)
G896S02-07 LIFT ROD (NO LEVEL,HD-LIFT)
G896S03-03 CHECK LINK (CHECK LINK for Telescopic,STD,LSTA,AG)
G896S03-07 CHECK LINK (CHECK LINK for Telescopic,HD-LIFT,LSTA,AG)
13. SHEET METALS & MOUNTS
G830S01-05 HOOD (S-BLUE,Twin Lamp,RHT,EXP)
G830S01-12 HOOD UNDER COVER (Dark Gray)
G830S02-03 HOOD SUPPORT (95,STD)
G840S01-01 MOUNT RUBBER (L70CA or P100CA)
G840S01-03 SUB STEP (L70CA or P100CA)
14. DRIVER’S STATION
G630S02-05 STEERING WHEEL & COLUMN (L70CA,LS-CAP,DO,TK,EU)
G835S01-01 PEDAL FRAME (L70CA or F)
G850S01-02 SEAT (L70CA,WOOCHANG)
G861S01-01 FRAME (L70CA)
G862S01-01 DOOR (L70CA)
G862S01-02 DOOR LOCK ROD (L70CA)
G863S01-01 FRONT & SIDE WINDOW (L70CA)
G863S02-01 REAR WINDOW (L70CA)
G864S01-01 INTERIOR (L70CA)
G865S01-05 AIR COMPRESSOR (95,L70CA,P100CA)
G865S01-06 AIR-CON LINE (95,L70CA)
G866S01-01 ELECTRICAL WIRING (L70CA,DO,AG,LSTA)
G866S02-01 WINDOW WIPER (L70CA,WIPER)
G866S03-01 AUDIO SYSTEM (L70CA,CD-player)
G867S01-01 ROOF (L70CA,S-BLUE)
G868S01-01 EXTERIOR (L70CA,S-BLUE,DO)
G869S01-01 MISCELLANY (L70CA)
G869S02-02 MISCELLANY (L70CA,MHL)
15. TIRES, WHEELS & REAR BALLAST
G490S01-08 WHEEL BOLTS & NUTS (TAESAN)
16. ACCESSORY & ETC
G868S02-01 SLOW MOVING VEHICLES (LSTA)
G869S04-01 TM AIR BREATHER (L70CA,P100CA)
G920S05-01 BOLT CAP
17. DECALS
G980S01-03 DECAL (L70CA,LSTA)
18. DIA KIT & SVC KIT
G991S01-01 SVC KIT LIST
