LS Tractor PLUS Series P7010 (New Cabin MECHANICAL) Parts Catalog
Brand: LS
Model: LS PLUS Series P7010 (New Cabin MECHANICAL) Tractor
Number of Pages: 340 Pages
01. ENGINE
G010S01-01 ENGINE (72)
Q100S01-01 ENGINE ASSY GRP (72)
Q110S01-01 CRANKCASE ASSY (72,80,88)
Q115S01-01 ROCKER COVER (72,88)
Q115S01-02 CYLINDER HEAD COVER (72,80,88)
Q115S02-01 AIR BREATHER (72,80,88)
Q116S01-01 CYLINDER HEAD (72,80,88)
Q116S02-01 LIFTING EYE (72,80,88)
Q120S02-01 PISTON (72,80,88)
Q120S03-01 CONNECTION ROD (72,80,88)
Q120S04-01 CRANKSHAFT (72,80,88)
Q122S01-01 CAMSHAFT GRP (72,88)
Q125S01-01 FUEL SYSTEM (72)
Q125S02-02 FUEL PUMP & FILTER (72,80,88)
Q125S02-03 FUEL PUMP & FILTER (72,80,88)
Q125S03-01 INJECTOR (72,80,88)
Q130S01-01 TIMING GEAR & CASE (72,80,88)
Q130S02-01 FUEL PUMP & FILTER (72,80,88)
Q135S01-01 COOLING SYSTEM (72,80,88)
Q135S01-02 COOLING SYSTEM (72,80,88)
Q135S01-03 COOLING SYSTEM (72,88)
Q135S01-04 COOLING SYSTEM (72,80,88)
Q135S01-05 COOLING SYSTEM (72,80,88)
Q140S01-01 OIL SYSTEM (72,80,88)
Q140S01-02 OIL SYSTEM (72,80,88)
Q140S01-03 OIL SYSTEM (72,80,88)
Q140S01-04 OIL SYSTEM (72,80,88)
Q140S01-05 OIL SYSTEM (72,80,88)
Q145S01-01 OIL PAN (72,80,88)
Q146S01-01 BALANCER (72,80,88)
Q150S01-01 FLYWHEEL (72,80,88)
Q155S02-01 FLYWHEEL HOUSING (72,80,88)
Q160S02-01 INTAKE MANIFOLD (72)
Q160S02-02 INTAKE MANIFOLD (72,80,88)
Q165S01-01 EXHAUST MANIFOLD (72,88)
Q170S01-01 STARTER (72,80,88)
Q175S01-01 ALTERNATOR (72,80,88)
Q180S01-01 ELECTRIC PARTS (72,88)
Q180S01-02 ELECTRIC PARTS (72,88)
Q185S01-01 TURBOCHARGER (72,80,88)
02. ENGINE APPLICATION
G040S01-01 FUEL TANK (72,80,88)
G100S01-05 THROTTLE PEDAL (P100CA,72,80,88)
G100S01-07 THROTTLE LEVER (P100CA)
G150S01-06 MUFFLER (72,80,88,VERTICAL,P100CA)
G170S01-06 RADIATOR (72,80,88,P100CA,Slide Condenser)
G190S01-05 AIR CLEANER (72,80,P100CA)
G210S01-01 ENGINE FRAME (72,80,88,TAESAN)
03. TRANSMISSION
G250S01-01 CLUTCH (72,80,88,MEC,EXP)
G250S02-01 CLUTCH HOUSING (72,80,88,MEC)
G260S01-03 CLUTCH PEDAL (P100CA,MEC)
G280S01-01 TRANSMISSION CASE (MEC,EXP)
G281S01-01 MAIN SHAFT (MEC)
G281S02-03 MAIN GEAR SHAFT (P100CA,MEC)
G285S01-01 RANGE GEAR SHAFT
G285S02-02 CREEPER GEAR SHAFT (CRP)
G310S01-01 REAR DIFFERENTIAL
04. PTO DRIVE
G283S01-01 PTO CLUTCH & SHAFT (MEC)
G287S01-01 PTO GEAR & SHAFT (INDP-PTO3,GSP,EXP)
05. FOUR WHEEL DRIVE (4WD)
G288S01-01 4WD DRIVE SHAFT (72,80,88,STD)
G288S01-02 4WD SHAFT COVER (72,80,88,STD)
G400S01-01 FRONT AXLE ASSY (MHL,WO-FEHD,EXP)
G400S02-01 FRONT AXLE CASE (TAESAN)
G400S02-02 FRONT AXLE CASE (TAESAN,LH,EXP)
G400S02-03 FRONT AXLE CASE (TAESAN,RH,EXP)
G400S03-01 FRONT DIFFERENTIAL (W-O FEHD)
G400S04-01 FRONT DRIVE (TAESAN,EXP)
G610S01-01 TIE-ROD (TAESAN,EXP)
G630S01-07 STEERING CYLINDER (TAESAN,EXP)
G991S30-01 SVC KIT-FRONT AXLE CASE(LH) (Heavy Duty)
G991S30-02 SVC KIT-FRONT AXLE CASE(RH) (Heavy Duty)
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE
G650S01-01 BRAKE (DO,EXP)
G670S01-03 BRAKE PEDALS (MEC,60LPM)
G670S01-05 BRAKE PEDALS (EXP)
G670S01-07 BRAKE OIL TANK (MEC)
G670S01-09 BRAKE PIPES ((L70CA or F,45LPM) or P100CA)
G670S02-02 PARKING BRAKE LEVER
08. SHIFT FORK & LINKAGE
G290S01-03 LEVER&FORK(MAIN GEAR) (P100CA,MEC,DOUBLE CONE)
G290S01-04 LEVER&FORK(F-R GEAR) (P100CA,MEC)
G290S02-03 MAIN SHIFT LEVER (P100CA,MEC)
G291S01-02 LEVER&FORK(CREEPER) (CRP)
G291S01-03 LEVER&FORK(PTO) (PTO2,PTO3)
G291S01-05 LEVER&FORK(GSP) (GSP)
G291S01-07 LEVER&FORK(RANGE GEAR) (P100CA,MEC)
G320S01-01 DIFF-LOCK
G630S01-05 STEERING LINES (72,80,88,P100CA)
G640S01-01 T-M OIL COOLER (72,80,88,45LPM,W-COOLER)
G640S01-03 T-M OIL COOLER (MEC,W-COOLER)
G640S01-07 T-M OIL COOLER (72,80,88,50LPM,60LPM,W-COOLER,LSTA)
G822S02-01 TM CTRL. VALVE PIPE
G822S02-03 TM CONTROL VALVE (INDP,1-SECOND)
G822S02-07 SEQUENCE VALVE (MEC)
G822S03-10 LOADER VALVE (P100CA,60LPM,L-V,WO-COUPLER,EXP)
G823S01-17 HYD. F-PRESSURE LINES (72,80,88,P100CA,60LPM,L-V,EXP)
G823S01-19 HYD. SUCTION LINES (72,80,88,60LPM)
G827S01-07 REMOTE CONTROL VALVE (P100CA,SEC3-FLOAT)
G827S01-14 REMOTE CONTROL LEVER (P100CA,SEC3)
G827S02-04 REMOTE CONTROL VALVE (P100CA,SEC3-FLOAT)
G829S01-13 AUTO LEVELING HYD. LINE (P100CA,60LPM,MHL,NO-LEVEL)
G730S01-13 ELECTRICAL WIRING (P100CA,72,80,88,Twin Lamp,EHL,MHL&NO AUTO PTO,EXP)
G730S02-03 7 POLE CONNECTOR (P100CA,ASAE)
G730S60-01 HORN
G740S01-01 BATTERY (110AH)
G750S01-08 METER PANEL (P100CA,72,88,95)
G750S04-01 GRID HEATER (72.88.95)
G760S01-06 LAMP (P100CA,EXP)
G760S01-07 HEAD LAMP (STD-LOOK)
G760S01-11 SIDE WORK LAMP (P100CA)
11. HYDRAULIC LIFT UNIT
G820S01-04 HYD. HOUSING ASSY (P100CA,MHL,EXP)
G820S02-01 HYDRAULIC HOUSING (MHL)
G822S01-01 LIFT CTRL. VALVE & LINK (MHL)
G824S01-01 POSITION & DRAFT CTRL. LINK (MHL)
G825S01-08 HYD. LEVER GUIDE (P100CA,MHL)
G825S01-09 HYD. CONTROL LEVER (P100CA,MHL)
G825S02-02 AUTO LIFT CTRL. (P100CA,MHL)
G826S01-01 HYDRAULIC CYLINDER (MHL)
G828S01-01 UPPER LINK BRACKET (W-DRAFT,STD,DO,EXP,TK(EHL))
G828S01-03 UPPER LINK BRACKET (W-DRAFT,HD-LIFT,DO,EXP,TK(EHL))
12. 3-POINT LINKAGE & HITCH
G891S01-03 DRAWBAR & HITCH (SWING BAR&CLEVIS)
G896S01-03 UPPER & LOWER LINK (TELESCOPIC,STD)
G896S01-08 UPPER & LOWER LINK (TELESCOPIC,HD-LIFT)
G896S02-03 LIFT ROD (NO LEVEL for Telescopic,LSTA,AG)
G896S02-07 LIFT ROD (NO LEVEL,HD-LIFT)
G896S03-03 CHECK LINK (CHECK LINK for Telescopic,STD,LSTA,AG)
G896S03-07 CHECK LINK (CHECK LINK for Telescopic,HD-LIFT,LSTA,AG)
13. SHEET METALS & MOUNTS
G830S01-05 HOOD (S-BLUE,Twin Lamp,RHT,EXP)
G830S01-12 HOOD UNDER COVER (Dark Gray)
G830S02-01 HOOD SUPPORT (72,80,88,L70CA,P100CA)
G840S01-01 MOUNT RUBBER (L70CA or P100CA)
G840S01-03 SUB STEP (L70CA or P100CA)
14. DRIVER’S STATION
G630S02-04 STEERING COLUMN (P100CA)
G630S02-08 STEERING WHEEL (LS-CAP)
G835S01-02 PEDAL FRAME (P100CA)
G850S01-04 SEAT (P100CA)
G861S01-02 FRAME (P100CA)
G862S01-03 DOOR (P100CA)
G863S01-02 FRONT & SIDE WINDOW (P100CA)
G863S02-02 REAR WINDOW (P100CA)
G864S01-05 INTERIOR(RH) (P100CA)
G864S01-06 INTERIOR(LH) (P100CA)
G864S01-07 INTERIOR(TOP) (P100CA)
G864S01-09 INTERIOR(FRONT) (P100CA)
G865S01-02 AIR COMPRESSOR (72,80,88,L70CA,P100CA)
G865S01-07 AIR-CON BLOWER (72,88,95,P100CA,HVAC)
G865S01-10 AIR-CON LINE (72,80,88,P100CA,Slide Condenser)
G865S02-01 AIR-CON UNIT (C,HVAC-40351466)
G866S01-05 ELECTRICAL WIRING (P100CA)
G866S02-02 WINDOW WIPER (P100CA,WIPER)
G866S02-03 WINDOW WASHER TANK (P100CA)
G866S03-02 AUDIO SYSTEM (P100CA,CD-player)
G867S01-04 ROOF (P100CA,S-BLUE)
G868S01-06 EXTERIOR (P100CA,S-BLUE)
G869S01-05 SUN SCREEN (P100CA)
G869S01-06 REAR VIEW MIRROR (P100CA)
G869S01-07 ROOM MIRROR (P100CA)
G869S02-06 MISCELLANY (P100CA,MHL)
15. TIRES, WHEELS & REAR BALLAST
G490S01-08 WHEEL BOLTS & NUTS (TAESAN)
16. ACCESSORY & ETC
G868S02-01 SLOW MOVING VEHICLES (LSTA)
G869S04-01 TM AIR BREATHER (L70CA,P100CA)
G920S05-01 BOLT CAP
17. DECALS
G980S01-10 DECAL (P100CA,LSTA)
18. DIA KIT & SVC KIT
G991S01-01 SVC KIT LIST
Brand: LS
01. ENGINE
03. TRANSMISSION
04. PTO DRIVE
G730S60-01 HORN
16. ACCESSORY & ETC
G920S05-01 BOLT CAP
17. DECALS
- LS Tractor J Series J2023H Parts Catalog
- LS Tractor KAI Series K5047 Parts Catalog
- LS Tractor KAI Series K5055 Parts Catalog
- LS Tractor MT1 Series MT125 Parts Catalog
- LS Tractor MT2 Series MT232 MT242 Parts Catalog
- LS Tractor MT2E Series MT225E MT225HE (with S3L2) Parts Catalog
- LS Tractor MT2E Series MT226E (with S3L2) Parts Catalog
- LS Tractor MT2E Series MT226E MT232E MT242E (with 3TNV88 4TNV88) Parts Catalog
- LS Tractor MT2E Series MT230E MT230HE MT235E MT235HE (with L3C19-D) Parts Catalog
- LS Tractor MT2E Series MT230E MT230HE MT235E MT235HE (with L3CRNV) Parts Catalog
- LS Tractor MT2E Series MT235E MT235HE MT240HE (with L3CRTV) Parts Catalog
- LS Tractor MT2E Series MT240E MT240HE (with L3C19-T) Parts Catalog
- LS Tractor MT2E Series MT240E MT240HE (with L3CRTV) Parts Catalog
- LS Tractor MT2S Series MT225S Parts Catalog
- LS Tractor MT3 Series MT335H MT335HC MT340HC (STAGE5) Parts Catalog
