Momed80
150
35,046
LS Tractor MT3 Series MT342 MT347 MT352 MT357 (TIER4) Parts Catalog
Brand: LS
Model: LS MT3 Series MT342 MT347 MT352 MT357 (TIER4) Tractor
Number of Pages: 610 Pages
01. ENGINE
G010S01-03 ENGINE LONG BLOCK ASSY
G010S01-05 ENGINE SHORT BLOCK ASSY
Q110S01-01 CRANKCASE ASSY
Q110S02-01 CRANKCASE
Q115S01-01 ROCKER COVER & CAMSHAFT
Q115S02-02 BLOW BY GAS HOSE
Q116S01-01 CYLINDER HEAD
Q120S01-01 MAIN MOVING PARTS
Q121S01-01 VALVE MECHANISM
Q125S01-01 FUEL SYSTEM
Q125S02-01 FUEL FILTER
Q125S04-03 INJECTION PUMP
Q130S01-01 TIMING GEAR & CASE
Q135S01-01 COOLING SYSTEM
Q140S01-01 OIL SYSTEM
Q145S01-01 OIL PAN
Q160S01-01 INLET & OUTLET MANIFOLD
Q166S01-01 EGR
Q166S02-06 EGR VV SVC KIT (ERAE to KAMTEC)
Q167S01-01 DOC&DPF
Q167S01-02 DPF SUPPORT (F)
Q180S01-01 ELECTRIC PARTS
Q180S01-05 ELECTRIC PARTS
Q185S01-01 TURBOCHARGER
02. ENGINE APPLICATION
G040S01-01 FUEL TANK (F)
G040S01-02 FUEL TANK (C)
G100S01-01 THROTTLE PEDAL (F,MEC,MPC)
G100S01-02 THROTTLE PEDAL (C,MEC,MPC)
G100S01-03 THROTTLE LEVER
G130S01-01 FUEL COOLER
G150S01-01 MUFFLER
G170S01-01 RADIATOR (C,MEC,MPC)
G170S01-02 RADIATOR (F)
G170S01-03 RADIATOR (C,S-HST)
G190S01-01 AIR CLEANER
G210S01-01 ENGINE FRAME
03. TRANSMISSION
G250S01-01 CLUTCH (MEC,MPC)
G250S02-01 CLUTCH HOUSING (C-HST)
G250S02-02 CLUTCH HOUSING (MEC,MPC)
G250S02-03 CLUTCH HOUSING (S-HST)
G250S03-01 DAMPER (HST)
G260S01-01 CLUTCH PEDAL (C,MEC,MPC)
G260S01-02 CLUTCH PEDAL (F,MEC,MPC)
G260S02-01 CLUTCH CONTROL LINK (MPC)
G270S01-01 HST UNIT (42,47HP,C-HST,28cc)
G270S01-02 HST ROTATING KIT (42,47HP,C-HST,28cc)
G270S01-03 HST SEAL KIT (42,47HP,C-HST,28cc)
G270S01-04 HST UNIT (52,57HP,C-HST,33cc)
G270S01-05 HST ROTATING KIT (52,57HP,C-HST,33cc)
G270S01-07 HST SEAL KIT (52,57HP,C-HST,33cc)
G270S01-08 HST UNIT (S-HST,42.4cc)
G270S01-10 HST SEAL KIT (S-HST, 42.4cc)
G280S01-01 TRANSMISSION CASE (MEC,MPC)
G280S01-02 TRANSMISSION CASE (C-HST)
G280S01-03 TRANSMISSION CASE (S-HST)
G281S01-01 MAIN SHAFT (MEC,MPC,NO-CRP)
G281S02-01 MAIN GEAR SHAFT (MEC,MPC)
G281S02-02 MAIN GEAR SHAFT (HST)
G285S01-01 RANGE GEAR SHAFT (MEC,MPC,NO-GSP)
G285S01-02 RANGE GEAR SHAFT (HST,NO-GSP)
G310S01-01 REAR DIFFERENTIAL
04. PTO DRIVE
G280S02-01 PTO SHIELD (STD or EC,EXP)
G283S01-01 PTO CLUTCH & SHAFT (HST)
G283S01-02 PTO CLUTCH & SHAFT (MEC,MPC,NO-GSP)
G287S01-01 PTO GEAR & DRIVE SHAFT (PTO1+N)
G287S02-01 MID PTO LEVER (C,MEC,MPC,DIA KIT)
G287S02-02 MID PTO LEVER (C,HST,DIA KIT)
G287S02-03 MID PTO HOUSING (DIA KIT)
G287S02-04 MID PTO LEVER (F,MEC,MPC,DIA KIT)
G287S02-05 MID PTO LEVER (F,HST,DIA KIT)
G287S04-01 PTO SHAFT CAP
05. FOUR WHEEL DRIVE (4WD)
G288S01-01 4WD SHAFT & COVER
G400S01-01 FRONT AXLE ASSY
G400S02-01 FRONT AXLE CASE(CENTER)
G400S02-02 FRONT AXLE CASE(RH)
G400S02-03 FRONT AXLE CASE(LH) (NO-Q-T)
G400S03-01 FRONT DIFFERENTIAL
G400S04-01 FRONT DRIVE
G610S01-01 TIE-ROD
G630S01-10 STEERING CYLINDER
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE
G650S01-01 BRAKE
G670S01-01 BRAKE ROD AND LINKAGE (HST)
G670S01-02 BRAKE ROD AND LINKAGE (MEC,MPC)
G670S01-04 BRAKE PEDALS (F,MEC,MPC)
G670S01-05 BRAKE PEDALS (F,C-HST)
G670S01-06 BRAKE PEDALS (C,MEC,MPC)
G670S01-07 BRAKE PEDALS (C,S-HST)
G670S02-01 PARKING BRAKE LEVER (C-HST)
G670S02-02 PARKING BRAKE LEVER (MEC,MPC)
G670S02-03 PARKING BRAKE LEVER (S-HST)
08. SHIFT FORK & LINKAGE
G290S02-01 RAIL&FORK(MAIN GEAR) (MEC)
G290S02-02 RAIL&FORK(MAIN GEAR) (MPC)
G290S03-01 RAIL&FORK(F-R GEAR) (MEC,MPC)
G291S01-01 RAIL&FORK(RANGE GEAR) (MEC,MPC)
G291S01-02 RAIL&FORK(RANGE GEAR) (C-HST)
G291S01-03 RAIL&FORK(RANGE GEAR) (S-HST)
G291S01-07 RANGE SHIFT COVER (MEC,MPC)
G291S02-01 LEVER&FORK(4WD) (4WD,NO-Q-T)
G291S03-01 RAIL&FORK(PTO) (PTO1+N)
G291S04-01 LEVER&FORK(GSP) (NO-GSP)
G291S05-01 LEVER&FORK(CRP) (MEC,NO-CRP)
G292S01-01 HST PEDAL (F,C-HST)
G292S01-02 HST CONTROL LINKAGE (F,C-HST)
G292S01-03 HST PEDAL (C,S-HST)
G292S01-06 HST CONTROL LINKAGE (C,S-HST)
G292S02-01 MAIN GEAR SHIFT LEVER (F,MEC)
G292S02-02 MAIN GEAR SHIFT LEVER (C,MEC)
G292S02-03 MAIN GEAR SHIFT LEVER (F,MPC)
G292S02-04 MAIN GEAR SHIFT LEVER (C,MPC)
G292S03-01 F-R SHUTTLE LEVER (C,MEC)
G292S03-02 F-R SHUTTLE LEVER (F,MEC)
G292S03-03 F-R SHUTTLE LEVER (MPC)
G293S01-01 RANGE GEAR LEVER (F,MEC,MPC)
G293S01-02 RANGE GEAR LEVER (C,S-HST)
G293S01-03 RANGE GEAR LEVER (F,C-HST)
G293S01-04 RANGE GEAR LEVER (C,MEC,MPC)
G293S03-01 PTO LEVER (F,PTO1+N)
G293S03-02 PTO LEVER (C,PTO1+N)
G320S01-01 DIFF-LOCK (C,MEC,MPC)
G320S01-02 DIFF-LOCK (F,MEC,MPC)
G320S01-03 DIFF-LOCK (HST)
G630S01-01 STEERING PUMP (MEC,MPC)
G630S01-02 STEERING PUMP (C-HST)
G630S01-03 STEERING LINES (MEC,MPC,C-HST)
G630S01-05 STEERING RESONATOR (C)
G630S01-06 STEERING LINES (S-HST)
G630S01-09 STEERING PUMP (S-HST)
G640S01-01 T-M OIL COOLER (C-HST)
G640S01-02 T-M OIL COOLER (MEC,MPC)
G640S01-03 T-M OIL COOLER (S-HST)
G640S02-01 HST FILTER & LINE (C-HST)
G640S02-02 OIL COOLER VALVE & LINE (MEC)
G640S02-04 OIL COOLER VALVE & LINE (MPC)
G640S02-05 HST FILTER & LINE (C,S-HST)
G822S02-01 INDP PTO VALVE (MEC,INDP,STD)
G822S02-02 INDP PTO VALVE (HST,INDP)
G822S02-03 INDP PTO VALVE (MPC,INDP,STD)
G822S03-01 LOADER VALVE (C,L-V,(MEC or S-HST))
G822S03-02 LOADER VALVE (F,L-V,(MEC or C-HST))
G822S03-03 LOADER VALVE (F,L-V,MPC)
G822S03-04 JOYSTICK LEVER (F,L-V)
G822S03-05 JOYSTICK LEVER (C,L-V)
G822S03-06 LOADER VALVE (C,L-V,MPC)
G822S04-01 LOADER VALVE 3rd DIA KIT (DIA KIT)
G822S05-01 LOADER VALVE COUPLER (C,L-V,W-COUPLER)
G822S05-02 LOADER VALVE COUPLER (F,L-V,W-COUPLER)
G822S06-01 CLUTCH CONTROL VALVE (MPC)
G823S01-01 HYD. SUCTION LINES (S-HST)
G823S01-20 HYD. SUCTION LINES (MEC,MPC,C-HST)
G823S02-01 HYD. F-PRESSURE LINES (C,S-HST,L-V)
G823S02-14 HYD. F-PRESSURE LINES (F,C-HST,L-V)
G823S02-16 HYD. F-PRESSURE LINES (F,MPC,L-V)
G823S02-17 HYD. F-PRESSURE LINES (F,MEC,L-V)
G823S02-18 HYD. F-PRESSURE LINES (C,MPC,L-V)
G823S02-19 HYD. F-PRESSURE LINES (C,MEC,L-V)
G823S03-12 HYD. M-PRESSURE LINES (F,L-V,NO-LEVEL,SD5-2)
G823S03-13 HYD. M-PRESSURE LINES (F,L-V,NO-LEVEL,SD5-3)
G823S03-23 HYD. M-PRESSURE LINES (C,L-V,NO-LEVEL,SD5-2)
G827S01-01 REMOTE CONTROL LEVER (C,SD5-2)
G827S01-02 REMOTE CONTROL LINE (C,SD5-2)
G827S01-04 REMOTE CONTROL LINE (F,SD5-2)
G827S01-13 REMOTE CONTROL LINE (C,SD5-3)
G827S01-14 REMOTE CONTROL LEVER (C,SD5-3)
G827S01-21 REMOTE CONTROL LINE (F,SD5-3)
G827S02-01 REMOTE CONTROL VALVE (C,SD5-2)
G827S02-02 REMOTE CONTROL VALVE (F,SD5-2)
G827S02-03 REMOTE CONTROL VALVE (C,SD5-3)
G827S02-04 REMOTE CONTROL VALVE (F,SD5-3)
G730S01-01 ELECTRICAL WIRING
G730S01-02 HEAD LAMP HARNESS
G730S01-03 MIDDLE HARNESS
G730S02-01 7 POLE CONNECTOR (C)
G730S02-02 7 POLE CONNECTOR (F)
G730S03-01 HORN
G730S04-01 MAIN FUSE
G740S01-12 BATTERY (80A)
G750S01-01 RELAY & FUSE (C-HST)
G750S01-02 RELAY & FUSE (MEC)
G750S01-03 RELAY & FUSE (S-HST)
G750S01-04 RELAY & FUSE (MPC)
G750S01-07 ECU
G750S01-08 DIAGNOSIS CONNECTOR
G750S01-20 METER PANEL
G750S01-21 RH CONSOLE SWITCH (C)
G750S01-55 RH CONSOLE SWITCH (F)
G750S02-03 RANGE GEAR NEUTRAL SENSOR (S-HST)
G750S02-06 F-R GEAR NEUTRAL SENSOR (F,MEC)
G750S03-03 F-R GEAR NEUTRAL SENSOR (MPC)
G750S03-04 LINKED PEDAL SENSOR (C,S-HST)
G750S03-08 PTO SENSOR PLUG (NO-EPTO,NO-REV-PTO)
G760S01-02 REAR LAMP (C)
G760S01-03 HEAD LAMP
G760S01-06 REAR LAMP (F)
G760S01-08 TURN SIGNAL LAMP (F)
G760S01-12 REAR WORK LAMP (C,W-DIA KIT)
G760S01-18 WORK LAMP (C)
G760S01-19 TURN SIGNAL LAMP (C)
G760S03-02 BEACON CONNECTOR (C)
11. HYDRAULIC LIFT UNIT
G820S01-01 HYD. HOUSING ASSY (C)
G820S01-02 HYD. HOUSING ASSY (F)
G820S02-01 HYDRAULIC HOUSING
G822S01-02 LIFT CTRL. VALVE & LINK (W-DRAFT)
G824S01-01 POSITION & DRAFT CONTROL LINK (W-DRAFT)
G825S01-01 HYD. CONTROL LEVER (F)
G825S01-02 HYD. CONTROL LEVER (C)
G825S01-03 HYD. HOUSING LEVER (C)
G825S02-01 EXTERNAL POSITION CONTROL LEVER (C, Optional)
G825S02-02 EXTERNAL POSITION CONTROL LEVER (F, Optional)
G826S01-01 HYDRAULIC CYLINDER (F)
G826S01-02 HYDRAULIC CYLINDER (C)
G826S02-01 DOWN SPEED CONTROL VALVE (C)
G826S02-02 DOWN SPEED CONTROL VALVE (F)
G828S01-02 UPPER LINK BRACKET (F,W-DRAFT)
G828S01-03 UPPER LINK BRACKET (C,W-DRAFT)
12. 3-POINT LINKAGE & HITCH
G891S01-01 DRAWBAR & HITCH (TELESCOPIC DRAWBAR)
G896S01-01 UPPER & LOWER LINK (TELESCOPIC,CAT1)
G896S01-02 UPPER & LOWER LINK (TELESCOPIC,CAT2)
G896S01-05 TOP LINK HOOK (C)
G896S01-06 TOP LINK HOOK (F,STD TOP LINK)
G896S02-01 LIFT ROD
G896S03-04 CHECK LINK (TELESCOPIC,Ball type)
13. SHEET METALS & MOUNTS
G830S01-08 HOOD (S-BLUE)
G830S01-09 GRILLE ASSY (S-BLUE)
G830S02-06 HOOD SUPPORT (C)
G830S02-07 HOOD SUPPORT (F)
G840S01-01 MOUNT RUBBER (F,NO-LEVEL,MEC,C-HST)
G840S01-02 MOUNT RUBBER (F,NO-LEVEL,MPC)
G840S01-09 MOUNT RUBBER (C)
G840S03-01 SUB STEP (C)
G840S03-02 SUB STEP (F)
14. DRIVER’S STATION
G630S02-02 STEERING WHEEL
G630S02-03 STEERING COLUMN (F)
G630S02-04 STEERING COLUMN (C,MEC,MPC)
G630S02-05 STEERING COLUMN (C,S-HST)
G825S01-05 HYD. LEVER GUIDE (F)
G825S01-06 HYD. LEVER GUIDE (C)
G835S01-01 PEDAL FRAME (F,C-HST)
G835S01-02 PEDAL FRAME (F,MEC,MPC)
G835S01-03 PEDAL FRAME (C,MEC,MPC)
G835S01-04 PEDAL FRAME (C,S-HST)
G850S01-01 SEAT (C,GRMMER,LS-GRAY)
G850S01-02 SEAT (F)
G861S01-01 FRAME (F,MEC,C-HST)
G861S01-02 FRAME (C)
G861S01-03 FRAME (C,MPC)
G861S01-05 FRAME (F,MPC)
G862S01-01 DOOR(LH) (C)
G862S01-02 DOOR(RH) (C)
G862S02-01 DOOR HANDLE ASSY (C)
G863S01-01 FRONT WINDOW (C)
G863S01-02 FRONT WINDOW (F)
G863S01-03 SIDE WINDOW (C)
G863S02-01 REAR WINDOW (C)
G864S01-01 INTERIOR(FRONT)
G864S01-02 INTERIOR(TOP) (C)
G864S01-03 INTERIOR(RH) (C)
G864S01-04 INTERIOR(LH) (C)
G864S01-06 INTERIOR(RH,LH) (F,H-RANGE)
G864S01-10 JOYSTICK COVER (C)
G864S01-11 JOYSTICK COVER (F)
G865S01-01 AIR-CON COMPRESSOR (C)
G865S01-02 AIR-CON LINE (C)
G865S01-03 AIR-CON BLOWER (C)
G865S02-02 AIR-CON UNIT (C)
G866S01-01 ELECTRICAL WIRING (F)
G866S01-02 ELECTRICAL WIRING (C,MEC)
G866S01-03 ELECTRICAL WIRING (C,S-HST)
G866S01-04 ELECTRICAL WIRING (C,MPC)
G866S02-01 WINDOW WIPER(FRONT) (C)
G866S02-02 WINDOW WIPER(REAR) (C)
G866S02-03 WINDOW WASHER TANK (C,W-REAR WASH)
G866S03-01 AUDIO SYSTEM (C)
G867S01-01 ROOF (C,S-BLUE)
G868S01-01 EXTERIOR (C,S-BLUE)
G869S01-02 MIRROR ASSY (C)
G869S01-05 MISCELLANY (C,MEC,MPC)
G869S01-06 MISCELLANY (F)
G869S01-07 MISCELLANY (C,S-HST)
G870S01-01 FENDER (F,S-BLUE)
G880S01-01 SAFETY FRAME (F)
15. TIRES, WHEELS & REAR BALLAST
G490S01-01 WHEEL BOLTS & NUTS
16. ACCESSORY & ETC
G868S02-01 SLOW MOVING VEHICLES (C)
G868S02-02 SLOW MOVING VEHICLES (F)
G920S02-01 TOOL BOX (F)
G920S05-01 BOLT CAP
G920S05-02 RUBBER PLUGS
G920S07-01 CUP HOLDER (F)
17. DECALS
G980S01-01 MODEL DECAL
G980S01-02 SAFETY DECAL (C)
G980S01-03 SAFETY DECAL (F)
18. DIA KIT & SVC KIT
G990S01-01 DIA KIT LIST (LSTA)
G991S01-01 SVC KIT LIST (ERAE to KAMTEC)
