Momed80
150
35,046
LS Tractor I Series i3030 i3030H i3040 i3040H Parts Catalog
Brand: LS
Model: LS I Series i3030 i3030H i3040 i3040H Tractor
Number of Pages: 288 Pages
01. ENGINE
G010S01-01 ENGINE (28,36)
Q065S01-02 OVERHAUL GASKET KIT (28,36)
Q110S01-03 CRANKCASE ASSY (28)
Q110S01-04 CRANKCASE ASSY (36)
Q110S01-05 CRANKCASE ASSY (28,36)
Q110S01-06 CRANKCASE ASSY (28,36)
Q110S01-07 CRANKCASE ASSY (28,36)
Q115S01-02 ROCKER COVER & CAMSHAFT (28,36)
Q115S01-03 ROCKER COVER & CAMSHAFT (28,36)
Q115S02-01 AIR BREATHER (28,36)
Q116S01-03 CYLINDER HEAD (28)
Q116S01-04 CYLINDER HEAD (36)
Q116S02-01 LIFTING EYE (28,36)
Q120S02-01 PISTON (28,36)
Q120S03-01 CONNECTION ROD (28)
Q120S03-02 CONNECTION ROD (36)
Q120S04-01 CRANKSHAFT (28)
Q120S04-02 CRANKSHAFT (36)
Q121S01-02 VALVE MECHANISM (28,36)
Q125S01-02 FUEL SYSTEM (28,36)
Q125S01-03 FUEL SYSTEM (28)
Q125S01-04 FUEL SYSTEM (36)
Q125S01-05 FUEL SYSTEM (28)
Q125S01-06 FUEL SYSTEM (36)
Q125S01-07 FUEL SYSTEM (28,36)
Q125S01-08 FUEL SYSTEM (28,36)
Q125S02-02 FUEL PUMP & FILTER (28,36)
Q125S02-03 FUEL PUMP & FILTER (28,36)
Q130S01-02 TIMING GEAR & CASE (28,36)
Q130S01-03 TIMING GEAR & CASE (28,36)
Q135S01-02 COOLING SYSTEM (28,36)
Q140S01-02 OIL SYSTEM (28,36)
Q140S01-03 OIL SYSTEM (28,36)
Q140S01-04 OIL SYSTEM (28,36)
Q145S01-02 OIL PAN (28,36)
Q150S01-02 FLY WHEEL (36,MEC)
Q150S01-03 FLY WHEEL (28,36,HST)
Q155S02-01 FLYWHEEL HOUSING (28)
Q155S02-02 FLYWHEEL HOUSING (36)
Q160S01-02 INLET & OUTLET MANIFOLD (28,36)
Q165S01-01 EXHAUST MANIFOLD (28,36)
Q170S01-01 STARTER (28,36)
Q175S01-01 ALTERNATOR (28,36)
Q180S01-02 ELECTRIC PARTS (28,36)
Q180S01-03 ELECTRIC PARTS (28,36)
Q180S01-04 ELECTRIC PARTS (28)
Q180S01-05 ELECTRIC PARTS (36)
02. ENGINE APPLICATION
G040S01-02 FUEL TANK (28,36,S4L)
G100S01-04 ENGINE CONTROL (28,36,S4L)
G150S01-04 MUFFLER (28,36,S4L,NH-P-LOOK,CIH-P-LOOK,TWIN-LOOK)
G170S01-02 RADIATOR (28,36,S4L,C-LOOK)
G190S01-02 AIR CLEANER (28,36,S4L,EXP)
G210S01-03 ENGINE FRAME (28,36,S4L,C,MC-LOOK,DO,MC,LD,EX)
03. TRANSMISSION
G250S01-02 CLUTCH (28,36,S4L,MEC)
G250S02-02 CLUTCH HOUSING (28,36,S4L,MEC,EXP)
G250S03-01 DAMPER (28,36,HST)
G260S01-01 CLUTCH PEDAL (MEC)
G270S01-01 HST (28,36,HST)
G270S01-03 HST ROTATING KIT (HST)
G270S01-04 HST SEAL KIT (HST)
G280S01-01 TRANSMISSION CASE (MEC,CIH(AU))
G280S01-02 TRANSMISSION CASE (HST,CIH(AU))
G280S01-08 PTO SHIELD (STD,PTO Shield)
G281S01-01 MAIN SHAFT (MEC)
G285S01-01 RANGE GEAR SHAFT (MEC)
G285S01-02 RANGE GEAR SHAFT (HST)
G310S01-01 REAR DIFFERENTIAL
04. PTO DRIVE
G283S01-02 PTO SHAFT (28,36,MEC)
G283S01-03 PTO SHAFT (HST)
G287S01-02 PTO DRIVE SHAFT (M-PTO)
G287S01-03 PRO DRIVE SHAFT (PTO-1)
G287S01-04 MID PTO LEVER (M-PTO,W-DIA KIT)
G287S02-05 MID PTO HOUSING (M-PTO)
G287S04-01 PTO SHAFT CAP
05. FOUR WHEEL DRIVE (4WD)
G288S01-02 4WD SHAFT (28,30,36,38 EXP,CIH(AU))
G400S01-02 FRONT AXLE ASSY
G400S02-01 FRONT AXLE CASE
G400S02-03 FRONT AXLE CASE
G400S03-01 FRONT DIFFERENTIAL
G400S04-02 FRONT DRIVE
G610S01-01 TIE-ROD
G610S01-02 TIE-ROD
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE(LH)
G480S01-03 REAR AXLE(RH)
G650S01-01 BRAKE
G670S01-01 BREAK PEDALS (MEC)
G670S01-03 BRAKE PEDALS (HST)
G670S02-01 PARKING BRAKE LEVER
08. SHIFT FORK & LINKAGE
G290S01-01 SHIFT LEVER & FORK (MEC,F-R)
G290S01-02 SHIFT LEVER & FORK (MEC)
G290S01-03 SHIFT LEVER & FORK (HST)
G292S01-01 HST CONTROL (HST)
G320S01-01 DIFF-LOCK (MEC)
G320S01-02 DIFF-LOCK (HST)
G630S01-02 STEERING CYLINDER & LINES
G630S01-03 STEERING CYLINDER
G630S01-05 STEERING UNIT SVC KIT (40289688 SVC KIT)
G640S01-02 T-M OIL COOLER (28,36,HST,C,M-LOOK,MC,LD,EX)
G822S02-03 TM CONTROL VALVE (INDP)
G822S03-07 FRONT OUTLET & LOADER VALVE (F-OUTLET)
G827S01-01 REMOTE CONTROL VALVE (SD5-2)
G730S01-02 ELECTRICAL WIRING (28,36,S4L,R-LOOK,C-LOOK)
G730S02-01 7 POLE CONNECTOR-SVC OFF
G740S01-01 BATTERY-SVC OFF (DO,EXP)
G750S01-04 METER PANEL (28,36,MEC)
G750S01-08 METER PANEL (HST)
G760S01-01 LAMP (C-LOOK,DO,MY,EX)
11. HYDRAULIC LIFT UNIT
G820S01-02 HYDRAULIC HOUSING ASSY (W-DRAFT)
G820S02-02 HYDRAULIC HOUSING (W-DRAFT)
G822S01-02 LIFT CONTROL VALVE & LINK (W-DRAFT)
G824S01-02 POSITION & DRAFT CONTROL LINK (W-DRAFT)
G825S01-02 HYDRAULIC CONTROL LEVER (W-DRAFT)
G826S01-01 HYDRAULIC CYLINDER
G828S01-02 UPPER LINK BRACKET (W-DRAFT)
12. 3-POINT LINKAGE & HITCH
G891S01-02 DRAWBAR HITCH (TELESCOPIC DRAWBAR,AG,USMC,USLD,LSTA)
G896S01-01 UPPER & LOWER LINK (GENERAL)
G896S01-04 TOP LINK HOOK (F)
G896S02-01 LIFT ROD (NO LEVEL)
G896S03-02 CHECK LINK (TELESCOPIC,AG,LSTA,AUCI,AUNH)
13. SHEET METALS & MOUNTS
G830S01-02 HOOD (C-LOOK,S-BLUE.DO,LSTA)
G830S02-01 HOOD SUPPORT (28,36,S4L,C-LOOK,MC-LOOK,DO,MC,LD,SA,UK,EX)
G840S01-03 STEP & MOUNT RUBBER (MEC)
G840S01-04 STEP & MOUNT RUBBER (HST)
14. DRIVER’S STATION
G630S02-01 STEERING WHEEL & COLUMN (LS-CAP)
G830S04-01 INSTRUMENT CONSOLE GRP (DO,EXP)
G835S01-01 PEDAL FRAME (36,MEC,DO or MEC,EXP,CIH(AU))
G835S01-02 PEDAL FRAME (HST)
G850S01-02 SEAT (MEC,EXP,MY,TLNH)
G850S01-03 SEAT (HST,EXP)
G863S01-01 FRONT WINDOW (DO,USNH,CIH(AU),MY,TLNH,USCI,AUCI,AUNH)
G870S01-03 FENDER (S-BLUE,USLD,LSTA,EXP)
G870S02-01 LEVER GUIDE&SEALS (DO,EXP,TLNH)
G880S01-02 SAFETY FRAME (R-ROPS,FOLDERBLE)
15. TIRES, WHEELS & REAR BALLAST
G490S01-06 WHEEL BOLTS & NUTS
16. ACCESSORY & ETC
G868S02-01 SLOW MOVING VEHICLES (SMV,LSTA)
G920S05-01 BOLT CAP
17. DECALS
G980S01-07 DECAL (28,36,C-LOOK)
18. DIA KIT & SVC KIT
G990S01-01 DIA KIT LIST (LSTA)
