Momed80
150
35,046
LS Tractor G Series G3033 G3033H G3038 G3038H Parts Catalog
Brand: LS
Model: LS G Series G3033 G3033H G3038 G3038H Tractor
Number of Pages: 246 Pages
01. ENGINE
Q065S01-01 OVERHAUL GASKET KIT (33,38PS)
Q110S01-01 CRANKCASE ASSY (33,38PS)
Q110S02-01 CRANKCASE (33,38PS)
Q115S01-01 ROCKER COVER & CAMSHAFT (33,38PS)
Q116S01-01 CYLINDER HEAD (33,38PS)
Q120S01-01 MAIN MOVING PARTS (33,38PS)
Q121S01-01 VALVE MECHANISM (33,38PS)
Q125S01-01 FUEL SYSTEM (33,38PS)
Q125S02-01 FUEL FILTER (L3A,S4Q)
Q130S01-01 TIMING GEAR & CASE (33,38PS)
Q135S01-01 COOLING SYSTEM (38PS)
Q135S01-02 COOLING SYSTEM (33PS)
Q140S01-01 OIL SYSTEM (33,38PS)
Q145S01-01 OIL PAN (33,38PS)
Q160S01-01 INLET & OUTLET MANIFOLD (33,38PS)
Q180S01-01 ELECTRIC PARTS (33,38PS)
02. ENGINE APPLICATION
G040S01-01 FUEL TANK
G100S01-01 THROTTLE LEVER (C-LOOK)
G100S01-02 ENGINE CONTROL (MEC)
G150S01-01 MUFFLER (L3A,EXP)
G170S01-01 RADIATOR (L3A,EXP,LSTA)
G190S01-01 AIR CLEANER
G210S01-01 ENGINE FRAME (C-LOOK,LSTA,LSMB)
G215S01-01 FRONT BALLAST (WEIGHT-4)
03. TRANSMISSION
G250S01-01 CLUTCH (MEC,wo-damper)
G250S02-01 CLUTCH HOUSING (MEC)
G250S02-02 CLUTCH HOUSING (HST)
G250S03-01 DAMPER (HST)
G260S01-01 CLUTCH PEDAL (MEC,EXP)
G270S01-01 HST (HST)
G270S01-02 HST ROTATING KIT (HST)
G270S01-03 HST SEAL KIT (HST)
G280S01-01 TRANSMISSION CASE (MEC,INDP)
G280S01-02 TRANSMISSION CASE (HST,INDP)
G281S01-01 MAIN SHAFT (MEC,INDP)
G285S01-01 RANGE GEAR SHAFT (HST)
G285S01-02 RANGE GEAR SHAFT (MEC)
G310S01-01 REAR DIFFERENTIAL
04. PTO DRIVE
G280S02-01 PTO SHIELD (STD,LSTA,LSMB)
G283S01-01 PTO CLUTCH & SHAFT (HST,INDP)
G283S01-02 PTO SHAFT (MEC,INDP)
G287S01-03 PTO GEAR & SHAFT (INDP,PTO1)
G287S01-04 PTO DRIVE SHAFT COVER (WO-M PTO)
G287S04-01 PTO SHAFT CAP
05. FOUR WHEEL DRIVE (4WD)
G288S01-02 4WD SHAFT (4WD,DRY,LSTA,LSMB)
G288S01-03 4WD SHAFT (2WD,LSTA)
G400S01-01 FRONT AXLE ASSY (4WD)
G400S01-02 FRONT AXLE ASSY (2WD,LSTA)
G400S02-01 FRONT AXLE CASE (4WD)
G400S02-02 FRONT AXLE CASE (4WD)
G400S02-03 FRONT AXLE CASE (2WD,LSTA)
G400S03-01 FRONT DIFFERENTIAL (4WD)
G400S04-01 FRONT DRIVE (4WD)
G610S01-02 TIE-ROD & STEERING CYLINDER (2WD,LSTA)
G610S01-03 TIE-ROD (4WD)
G630S01-06 STEERING CYLINDER (4WD)
07. REAR AXLE & BRAKE
G480S01-01 REAR AXLE
G650S01-01 BRAKE
G670S01-01 BRAKE PEDALS (MEC,WO-SWITCH,EXP)
G670S01-03 BRAKE PEDALS (HST,WO-SWITCH,EXP)
08. SHIFT FORK & LINKAGE
G290S02-01 LEVER&FORK(MAIN GEAR) (MEC)
G290S03-01 SHIFT LEVER&FORK(F-R GEAR) (F-R,MEC,C-LOOK,LSTA,LSMB)
G291S01-01 LEVER&FORK(RANGE GEAR)
G291S02-01 SHIFT LEVER & FORK(4WD) (PTO1)
G291S02-02 SHIFT LEVER & FORK(4WD) (2WD,LSTA)
G291S03-01 LEVER&FORK(PTO) (PTO1)
G292S01-01 HST CONTROL (HST CONTROL,EXP)
G320S01-01 DIFF-LOCK (MEC)
G320S01-02 DIFF-LOCK (HST)
G630S01-01 STEERING LINES
G630S01-02 STEERING LINES (MEC,INDP,Drain line)
G630S01-03 STEERING CYLINDER & LINES (HST,INDP,Drain line)
G640S01-01 T-M OIL COOLER (HST)
G822S02-01 INDP PTO VALVE (INDP)
G822S03-01 FRONT OUTLET VALVE (F-O)
G823S01-03 HYD. SUCTION LINES
G823S02-01 HYD. PRESSURE LINES
G827S01-03 REMOTE CONTROL VALVE (F-O,W-O RCV,M-Pressure)
G730S01-01 ELECTRICAL WIRING (C-LOOK)
G740S01-01 BATTERY (80A)
G750S01-01 METER PANEL (C-LOOK)
G750S01-03 METER PANEL (C-LOOK,RELAY)
G750S05-01 AUTOMATIC PTO-ON-OFF (PTO ON-OFF)
G760S01-01 LAMP (C-LOOK)
11. HYDRAULIC LIFT UNIT
G820S01-01 HYD. HOUSING ASSY
G820S02-01 HYDRAULIC HOUSING
G822S01-01 LIFT CTRL. VALVE & LINK
G824S01-01 POSITION & DRAFT LINK
G825S01-01 HYD. LEVER GUIDE
G825S01-03 HYD. CONTROL LEVER
G825S01-04 LEVER STOPPER
G826S01-01 HYDRAULIC CYLINDER
G828S01-01 UPPER LINK BRACKET (W-O DRAFT)
12. 3-POINT LINKAGE & HITCH
G891S01-02 DRAWBAR & HITCH (TELESCOPIC DRAWBAR)
G896S01-01 UPPER LINK
G896S01-03 LOWER LINK (GENERAL)
G896S01-06 TOP LINK HOOK
G896S02-01 LIFT ROD (NO-NEVEL,CAT1)
G896S03-02 CHECK LINK (TELESCOPIC STABILIZER)
13. SHEET METALS & MOUNTS
G830S01-03 HOOD (C-LOOK,S-BLUE)
G830S02-01 HOOD SUPPORT (C-LOOK,S-BLUE)
G840S01-01 STEP & MOUNT RUBBER (HST,S-BLUE)
G840S01-02 STEP & MOUNT RUBBER (MEC,S-BLUE)
G840S01-05 SUB STEP
14. DRIVER’S STATION
G630S02-01 STEERING WHEEL & COLUMN
G630S03-01 STEERING WHEEL & CAP (LS-CAP)
G850S01-01 SEAT (F,TAEKWANG,MEC)
G850S01-02 SEAT (F,TAEKWANG,HST)
G870S01-03 FENDER (S-BLUE,LSTA)
G880S01-01 SAFETY FRAME (R-ROPS(LOWER ONLY))
G880S01-02 SAFETY FRAME (R-ROPS(FOLDERBLE))
G880S01-03 SAFETY FRAME (R-ROPS(RIGID))
15. TIRES, WHEELS & REAR BALLAST
G490S01-01 WHEEL BOLTS & NUTS (4WD)
G490S01-02 WHEEL BOLTS & NUTS (2WD)
G490S01-24 WHEEL & TIRE (STD,7-16,12.4-24(NW))
16. ACCESSORY & ETC
G868S02-01 SLOW MOVING VEHICLES (LSTA)
G920S05-01 BOLT CAP
17. DECALS
G980S01-01 DECAL (LSTA)
18. DIA KIT & SVC KIT
G990S01-01 DIA KIT LIST (LSTA)
