JPRO Commercial Fleet Diagnostics v2.1 08.2015
Languages: English
Operating System: XP,Windows 7,WIN8
Version: v2.0 & 2.1
Year: 08/2015
Noregon JPRO Commercial Vehicle Diagnostics
Support for the new International N13 Engine.
Coverage Updates (Available as a part of JPRO Fleets 2015 v2.1):
Auxiliary Components
Freightliner
M2 Bulkhead Module
Bendix Wingman Systems
NEW! JPRO Command Module — Mack and Volvo — Available NOW!
New functionality in JPRO Command Module — Mack and Volvo includes:
Bi-directional testing and controls on 2007 and newer Mack or Volvo vehicles with Mack and Volvo engines.
Reads vehicle controllers on the truck and displays detailed fault codes and component data. Displays information on all Mack and Volvo components and other non-Mack and Volvo components (such as ABS, Electronic transmissions and power units.) In one glance, a technician can see vehicle temps, battery life, gauges and switches.
Performs critical commanded tests and bi-directional testing and functions on Mack and Volvo engines, including: Manual Regeneration of the diesel particulate filter; cylinder cut out tests for fuel injectors; set road and cruise control speed tests, set parameters for idle shutdown times; reset trip data. Generate trip report information, including: total running time and distance, fuel economy, average driving speed, idle times, hard braking and other data related to the vehicle driver performance.
WHAT'S NEW
- Support for the new JPRO with ASIST module which provides the ability to upload vehicle connection data to the ASIST platform, developed by Decisiv for Volvo and Mack Trucks
NOTE: Installing the ASIST module will require personnel with ASIST Admin level
access to provide ASIST Username and Password.
NOTE: The ASIST module require either a heavy-duty or medium-duty module to be able
to connect to vehicles.
- JPRO Heavy-Duty Module
- Data Monitor update to show Power Diagram to aid in the diagnosis
of electrical problems
- Support for Paccar 2010 and newer CAN Body Controllers
- Clear faults support for Paccar engine controllers
- Support for more proprietary sensor data on Detroit engines
- JPRO Heavy-Duty Command Module - Detroit
- Additional Bi-Directional support for Detroit engines:
- Cylinder Cut-Off now available for 2000-2014
- DPF Service Regen now available for 2007-2014
JPRO® Commercial Vehicle Diagnostics 2015 v2
WHAT'S NEW
- Support for the new JPRO® with ASIST module which provides the ability to
- JPRO® Heavy-Duty Module
- JPRO® Heavy-Duty Command Module - Detroit
FEATURE LIST
- Displays fault codes for all components on the supported databus protocols.
- Displays manufacturer flash codes and descriptions for faults when available.
- Provides key data points in graphical displays for vehicle and components.
- Prints reports containing faults and key data.
- Automatically displays all component parameters of interest in the Data Monitor.
- Sort or filter by component to limit the data displayed.
- Text search supported to identify parameters of interest.
- Graph parameter change over time to troubleshooting.
- Automatically detects OEM applications and gives the ability to launch them.
- Diagnoses all vehicle components in a single application.
- Displays information about components on each databus using the Vehicle
Readiness List.
- Automatically connects to all supported and available databuses to see data
from all vehicle components.
- Troubleshooting information to help resolve issues connecting to a truck.
- Easy access to JPRO DLA+ test tools to aid in diagnosing connection problems.
- Links to contact Noregon support or sales from within the application.
- Support for automatic updates.
- Ability to perform customized Preventative Maintenance Inspections. Inspection
available in XML format as well as in PDF report format.
- Support for Navistar OnCommand web service integration with the optional OnCommand Module.
- Ability to configure the application to launch at computer startup.
- Demo mode in Vehicle History enables users to explore JPRO features
quickly and easily without needing access to vehicles.
- Heavy Duty Module supports all standard Heavy Duty vehicles.
- Supports the heavy duty SAE J1587/J1708, J1939, and ISO 15765 messages.
- Support for trailer diagnostics using the JPRO® Trailer Diagnostic adapter or
the JPRO® DLA+ PLC and the PLC 7-way connector.
- Graphically displays data using thermometers, gauges, etc. on the Data Monitor.
- Display of data related to reported faults in Data Monitor.
- Ability to define custom groups of related data parameters to display in Data Monitor.
- Power Diagram available in Data Monitor to aid in the diagnosis of electrical problems.
- Clear indication of overall vehicle health taking into account:
- Active Faults Present
- Consumable Fluid(s) Low
- Cannot Detect ABS (on 2001 or newer vehicles)
- Battery Voltage Low
- No 1939 Data (on 2009 or newer vehicles)
- Search mechanism to link to troubleshooting guides.
- Provides databus utilization statistics on live heavy duty vehicle connections.
- Launches OEM component diagnostic applications in Fault Code Information and
Diagnostic Message screens. Simply click on the OEM application icon to launch
the application for more information about that component.
- Displays selected J1939 Diagnostic Messages, including Freeze Frames, Emissions
information, Broadcasts, etc.
- Aftertreatment screen display of data, including EGR data for rapid troubleshooting
of the aftertreatment system.
- Displays the trailer lamp status on tractor brake key data points window.
- Consumable Fluid screen to monitor fluids used by vehicle and inform user of
low levels.
- Support for proprietary sensor data on Detroit, Cummins and International engines
- Support for Paccar 2010 and newer CAN Body Controllers and engines
JPRO® Heavy-Duty Command Module - Mack and Volvo
- Supports all Mack, Volvo and Prevost vehicles.
- Displays all standard and proprietary fault codes for all components.
- Mack and Volvo Specific Reports including:
- Trip Report
- Life of Vehicle Report
NOTE: Reports only available on Mack EPA07 and newer vehicles with the DataMax parameter enabled.
NOTE: Reports only available on Volvo 2012 and newer with the DataMax parameter enabled.
- Bi-Directional support for Mack and Volvo EPA07, EPA10 and EPA13 engines includes:
- Routines:
- Cylinder Cut-Off
- DPF Service Regen
- Learned Data Reset
- Set Parameters:
- Setting Cruise Max and Min Speeds
- Setting Road Speed Limit
- Setting Idle Shutdown Time
- Enable or Disable Cruise Control
NOTE: The JPRO® Heavy-Duty Command Module - Mack and Volvo requires internet access at least
once a month. Failure to provide internet access will result in the application limiting use
and eventually shutting off the module features.
NOTE: The JPRO Heavy-Duty Command Module - Mack and Volvo only supports the following adapters:
- Noregon DLA+, DLA+ Wireless and DLA+ PLC
- Vocom 88890300 and 88890020
- NEXIQ USB-Link
- Bi-Directional support for 2000-2014 Detroit engines:
- Cylinder Cut-Off
- DPF Service Regen (2007 and newer only)
JPRO® Medium-Duty Command Module - Ford
- Supports 2004 to 2015 Ford models:
- F-series
- Econoline E-series
- Transit Connect
- Transit vehicles
- Supports the medium duty ISO 15765 and ISO 14229 messages.
- Gives users the ability to read and clear faults, read freeze frames, read sensor data, and
display emission test results.
- Enables users to run diagnostic tests on components such as the KOEO On Demand Self Test.
JPRO® Medium-Duty Command Module - GM
- Supports the following vehicle models from 2002 to 2015:
- GMC and Chevy Full Sized Trucks 1500, 2500 and 3500
- GMC Express and Chevy Savana
- All GM Medium Duty vehicles
NOTE: Only the powertrain components are supported on 2014 and 2015 GM vehicles.
- Supports the medium duty J1850 VPW and GMLAN messages.
- Gives users the ability to read and clear faults, read freeze frames, read sensor data, and display
- Supports cylinder cutouts on all diesel and gasoline engines on years 2002-2013 (except in GM vehicles with CAT engines).
- Tests for 2010-2012 Express/Savana with 6.0L Gas Engines.
JPRO® Medium-Duty Command Module - Sprinter
- Supports 2007 to 2015 Sprinter vehicles.
- Sprinter Module gives users the ability to read and clear faults, read sensor data, and display
- Supports EPA 07 Diesel Engine tests:
- Cylinder Cut-Off
- Compression Test
- DPF Regen
- Injector Quantity Adjustment
- Mass Air Flow Sensor Initialization
- Initialize Rail Pressure
- Supports Instrument Cluster (2007-2015) tests:
- Oil Change Reset
- Display Dimmer Test Routine
- Gauge Sweep Test
- LCD Display Test Routine
- Speaker Test Routine
- Supports Tire Pressure Monitor tire pressure sensor test (2007-2015)
JPRO® Next Step Module
- Integration with Mitchell 1 Repair-Connect.
- View Mitchell 1 troubleshooting information for a particular engine fault with a
single click within JPRO Diagnostics.
- Automatically link to troubleshooting guides for Wabco, Bendix and Haldex brakes
as well as Eaton transmissions.
NOTE: The JPRO® Next Step Module requires internet access at least once a month.
Failure to provide internet access will result in the eventual shutting off the module features.
JPRO® Heavy-Duty with OnCommand™ Connection
- Upload vehicle connection data to Navistar's OnCommand™ service.
JPRO® with ASIST
- Upload vehicle connection data to the ASIST platform, developed by Decisiv for Volvo and Mack Trucks
NOTE: The OnCommand™ and ASIST module require either a heavy-duty or
medium-duty module to be able to connect to vehicles.
HARDWARE / SOFTWARE CONFIGURATION:
- The following operating systems are supported:
- Windows Vista (both 32 and 64 bit versions)
- Windows 7 (both 32 and 64 bit versions)
- Windows 8 and 8.1 Pro (both 32 and 64 bit versions)
Note: Spanish operating systems are supported.
INSTALLATION INSTRUCTIONS:
Note - You must have administrative privileges to install and authorize this program.
- DVD Install:
1 ) Insert the JPRO® Commercial Vehicle Diagnostics Suite DVD into the target machine.
2 ) The auto-run will begin the installation process. If Setup does not begin
automatically, use Windows Explorer to navigate to (CD-ROM drive):\setup.exe
and double-click the setup.exe file.
3 ) The setup program will install .NET Framework 4.0 if not already installed.
4 ) The JPRO® Commercial Vehicle Diagnostics Suite Install screen is displayed, and provides the
option to install JPRO® Commercial Vehicle Diagnostics.
5 ) Select the "Install JPRO®" button to begin the installation.
6 ) Follow the instructions to complete the installation.
NOTES:
1 ) Registration is required before the JPRO® Commercial Vehicle Diagnostics application can be
used. Valid license key(s) will be required in order to register the application.
Please ensure you have license key information available before you install.
Registration over the internet is available.
2 ) The appropriate vehicle adapter driver must be installed in order to connect to a
vehicle adapter device. This installation is separate and independent of the
JPRO® Commercial Vehicle Diagnostics installation.
3 ) The JPRO® DLA+ and JPRO® DLA+ Wireless adapters are required in order to connect
to the Ford, GM or Sprinter Medium Duty vehicles. Please ensure you have the latest
driver and firmware loaded.
To connect to Ford use the OBDII Cable for Ford (red).
To connect to GM use the OBDII Cable for GM (yellow).
To connect to Sprinter use the OBD Cable for Spinter (blue).
4 ) The JPRO Heavy-Duty Command Module - Mack and Volvo only supports the following adapters:
- NEXIQ USB-Link
5 ) The JPRO Heavy-Duty Command Module - Mack and Volvo and JPRO Next Step Module require
internet access at least once a month. Failure to provide internet access will result in the
application limiting use and eventually shutting off the module features.
6 ) To open the User Guide underneath the Help menu option, Adobe Reader version 6.0
or greater must be installed.
Languages: English
Version: v2.0 & 2.1
Year: 08/2015
Freightliner
M2 Bulkhead Module
WHAT'S NEW
WHAT'S NEW
FEATURE LIST
Readiness List.
low levels.
- Trip Report
- Routines:
- Cylinder Cut-Off
- DPF Service Regen
- Set Parameters:
- NEXIQ USB-Link
- Cylinder Cut-Off
- F-series
- Transit Connect
- Transit vehicles
- Cylinder Cut-Off
- Compression Test
- DPF Regen
- Oil Change Reset
- Gauge Sweep Test
JPRO® with ASIST
- DVD Install:
NOTES:
- NEXIQ USB-Link
- Noregon JPRO Commercial Fleet Diagnostics 2016.1
- JPRO Commercial Vehicle Diagnostic 2015v1 + KG
- JPro 2015 KG
- JPRO Commercial Fleet Diagnostics 2016 v2.3 [05.2016] Full Instruction
- JPRO 2016v1 Activator and Keymaker + Instruction
- Jpro 2015 Download + KG
- JPRO Diagnostics 2017A Version 1 + KM
- JPRO 2016 v2 Patch
- JPRO Commercial Fleet Diagnostics 2019 v2.0 (JPRO 2019 v2.0)
- JPRO 2016 v.2.1 + Activator + Instruction
- JPRO 2017 Unlocked
- JPRO 2016v1-v2
- JPRO 2016 v.2.2 + activator
- Hyster Forklift Truck Service Manuals
- JPRO Commercial Fleet Diagnostics 2019 v1.0
