JPRO 2024v1 JPRO 2024v2
JPRO 2024v1 v2
PC Multi Install
JPRO Commercial Vehicle Diagnostics JPRO 2024 v2
OS: Windows 10, 11 32 64 bit (Tested on Windows 10, 11 pro 64bit)
The following operating systems are supported:
JPRO 2024 v2 WHAT’S NEW
Fault Guidance is Now on the Fault Grid
• Access Fault Guidance by clicking the Fault Guidance
button on the Fault Grid.
JPRO® Heavy-Duty Features
Engine Support
Heavy-Duty Support for PACCAR
• Fixed an issue that prevented some aftertreatment tests from displaying for EPA13 to GHG17 MX engines.
• Bi-Directional support for PACCAR engines:
Bi-Directional Test Supported On
Activate Air Shut Off Valve GHG17 to GHG21 all MX engines
Prime the System with the Pump for DEF GHG17 all MX engines
Transmission Support
Heavy-Duty Support for Detroit Diesel
• Now supports proprietary sensor data for:
✓ DT12 TCM01T
• Supports reading SAE faults and proprietary sensor data for:
✓ DT12 TCM05T
• Bi-Directional support for Detroit Diesel transmissions:
2024 v22
©2008 - 2024 Noregon Systems, LLC. All Rights Reserved.
JPRO® is a registered trademark of Noregon Systems, LLC.
JPRO® 2024 v2
Bi-Directional Test or Calibration Supported On
Clutch Apply Leak Test
DT12 TCM01T and TCM05T transmissions
Tilt Sensor Calibration
DT12 TCM05T transmissions
Transmission Learn Procedure Test Now Supports DT12 TCM05T transmission
PC Multi Install
- Windows 8 and 8.1 Pro (both 32 and 64-bit versions)
- Windows 10 and 11 (both 32 and 64-bit versions)
- Note: Spanish operating systems are supported.
- Minimum: 4GB RAM, 20 GB of available hard drive space, at least an Intel Core i3 processor and minimum of a 1024×768 sized monitor
- Recommended: 8GB RAM, 20 GB of available hard drive space, Intel Core i5 processor
- USB port for DLA+ 2.0 adapter or other RP1210C-compliant vehicle adapter
- Noregon recommends using a Panasonic Toughbook, but JPRO will work on any current PC running Windows 8, Windows 10, or Windows 11
- Only the Noregon® DLA+ 2.0, DLA+ 2.0 Wireless, Trailer Diagnostic Adapter, DLA+, DLA+ Wireless, and DLA+ PLC adapters are supported.
Engine Support
✓ DT12 TCM01T
✓ DT12 TCM05T
2024 v22
JPRO® 2024 v2
- Noregon JPRO Commercial Fleet Diagnostics 2016.1
- JPRO Commercial Fleet Diagnostics 2016 v2.3 [05.2016] Full Instruction
- JPRO 2016v1 Activator and Keymaker + Instruction
- JPRO Diagnostics 2017A Version
- JPRO 2016 v2 Patch
- JPRO Commercial Fleet Diagnostics 2019 v2.0 (JPRO 2019 v2.0)
- JPRO 2017 Unlocked
- JPRO 2016v1-v2
- JPRO Commercial Fleet Diagnostics v2.1 08.2015
- JPRO 2016 v.2.2 + activator
- Hyster Forklift Truck Service Manuals
- JPRO Commercial Fleet Diagnostics 2019 v1.0
- Noregon JPRO Commercial Fleet Diagnostics 2017 v1
- JPRO Commercial Vehicle Diagnostics JPRO 2021 v1.1 Install + Active License
- Jpro 2016 v2.3 Repack
