Noregon JPRO Commercial Fleet Diagnostics 2017 v1
Original file, without any medicine
WHAT’S NEW
JPRO Professional Diagnostic Software
Dashboard Brake Lamp Tests on all Wabco braking systems.
Wheel Speed Window Test and Wheel Speed Chart Test used to verify and test wheel speed sensors on all
tractor and trailer braking systems.
Access to historical fault data from previous JPRO connections which can be used to identify intermittent
vehicle issues. NOTE: Requires internet access.
Ability to remove access to setting road and cruise speed limits. If interested in limiting these capabilities,
contact Noregon support (support@noregon.com).
JPRO Heavy-Duty Command Module – Detroit
DPF Ash Accumulator Reset for EPA 07 Series 60 and DD15 engines.
Set Road Speed Limits for EPA 10 to EPA 13 for all DD13, DD15 and DD16 engines.
Set Cruise Control Limits for EPA 10 to EPA 13 for all DD13, DD15 and DD16 engines.
JPRO Heavy-Duty Command Module – International
Aftertreatment Reset for EPA 07 and EPA 10 Maxxforce 11 and 13 engines.
CDPF Reset for EPA 10 Maxxforce 7, DT, 9, and 10 engines.
SCR Fault Reset for EPA 13 N series engines.
DOC/DPF Replacement Reset for EPA 13 N series engines.
KOER Standard Test for EPA 07, EPA 10 and EPA 13 Maxxforce 7, 9, and 10
KOER Standard Test for EPA 13 N9 and N10 engines.
JPRO Heavy-Duty Command Module – Mack and Volvo
DPF System Reset for all EPA 07, EPA 10 and EPA 13 Mack and Volvo engines (including GHG17)
JPRO Heavy-Duty Command Module – Paccar
Automated Cylinder Performance Test for EPA 10 and EPA 13 Paccar engines
JPRO Medium-Duty Command Module – Isuzu
Added support for model year 2017 5.2L (4HK1) or 3.0L (4JJ1) diesel engines.
Added support for DEF controller on supported vehicles.
Add bi-directional support:
Cylinder Cut Out test on 2008-2017 5.2L (4HK1) or 3.0L (4JJ1) diesel engines in North America.
DPF Regen on 2008-2017 (4HK1) or 3.0L (4JJ1) diesel engines in North America.
NOTE: Bi-directional tests only available on supported North American vehicles.
JPRO Heavy-Duty Features
Support reading Bendix Proprietary Fault Codes on all EC-80 braking systems.
WHAT’S NEW
- Noregon JPRO Commercial Fleet Diagnostics 2016.1 + Patch
- JPRO Commercial Vehicle Diagnostic 2015v1 + KG
- JPro 2015 KG
- JPRO Commercial Fleet Diagnostics 2016 v2.3 [05.2016] Full Instruction
- JPRO 2016v1 Activator and Keymaker + Instruction
- JPRO Commercial Fleet Diagnostics 2017 v1.0 [01.2017] + ACTIVATION
- Jpro 2015 Download + KG
- JPRO Diagnostics 2017A Version 1 + KM
- JPRO 2016 v2 Patch
- JPRO Commercial Fleet Diagnostics 2019 v2.0 (JPRO 2019 v2.0)
- JPRO 2016 v.2.1 + Activator + Instruction
- Keymaker - JPRO 2017 Unlocked
- JPRO 2016v1-v2 Activator and Keymaker
- JPRO Commercial Fleet Diagnostics v2.1 08.2015
- JPRO 2016 v.2.2 + activator
