Autorepair
Driver
57
799,353
John Deere Service Advisor 5.2 Agriculture AG EN 2019.11
John Deere Service Advisor 5.2 Agriculture AG EN_[2019.11] Full
Languages: English
Type: Service and Repair Information
Make: John Deere
Region: WorldWide
Developer: John Deere
Brand: AG Agricultural
Version: 05.2.471
Win: Windows 7 32 bit, Windows 7 64 bit, Windows 8/8.1 32 bit, Windows 8/8.1 64 bit, Windows 10 32 bit, Windows 10 64 bit
Year: 2019.11
High Speed On Mega Link
John Deere Service Advisor 5.2 Agriculture models list: "CLICK HERE"
John Deere Service Advisor 5.2 Agriculture 2019 workshop service manual, repair manual, electrical wiring diagram, hydraulic diagram, assembly and disassembly engine, transmission for tractors, combine.
John Deere Service Advisor 5.2 service and workshop manual, repair manual, dealer technical assistance, diagnostics, connection readings, calibrations, interactive tests, specification, tools.
John Deere Service Advisor 5.2 conists AG Management Solutions, Attachments, Backhoes, Combines and Headers, Cotton Harvestings, Excavators, ForkLifts, Hay and Forages, MAte Hand Cut and Shredderses, Plantings and Seedings, Skid Steers, Sprayers, Sugar Cane Harvesters, Tillages, Tractors, Worksite Pro Attachments.
SA5012 AG NON EN 2019.11 Multilanguage
SA5012_AG_TU_AR_201911
SA5012_AG_TU_BG_201911
SA5012_AG_TU_CS_201911
SA5012_AG_TU_DA_201911
SA5012_AG_TU_DE_201911
SA5012_AG_TU_EL_201911
SA5012_AG_TU_ES_201911
SA5012_AG_TU_ET_201911
SA5012_AG_TU_FI_201911
SA5012_AG_TU_FR_201911
SA5012_AG_TU_HE_201911
SA5012_AG_TU_HI_201911
SA5012_AG_TU_HR_201911
SA5012_AG_TU_HU_201911
SA5012_AG_TU_IS_201911
SA5012_AG_TU_IT_201911
SA5012_AG_TU_JA_201911
SA5012_AG_TU_KO_201911
SA5012_AG_TU_LT_201911
SA5012_AG_TU_LV_201911
SA5012_AG_TU_NL_201911
SA5012_AG_TU_NO_201911
SA5012_AG_TU_PL_201911
SA5012_AG_TU_PT_201911
SA5012_AG_TU_RO_201911
SA5012_AG_TU_RU_201911
SA5012_AG_TU_SK_201911
SA5012_AG_TU_SL_201911
SA5012_AG_TU_SR_201911
SA5012_AG_TU_SV_201911
SA5012_AG_TU_TR_201911
SA5012_AG_TU_ZH_201911
Instruction Installation: Same version 05.2018
Prerequisites:
1. Adobe Reader must be installed and set as the defualt PDF viewer.
2. Java 8.181 x64 must be installed.
3. WINRAR or a extraction program of your choise must be installed.
4. Disable User Account Control.
5. Set Interenet Explorer as the defualt browser.
6. You will need at least 180GB of free storage for the installation of this program
Installation
1. Run and install Service ADVISOR_20190326. Run through the wizard installation and
if needed change the defualt location for the installation of the program, however this doucument is writen with the defualt C drive in mind.
2. Restart the PC after installation completes.
3. Install the SA5Update.
4. Restart the PC after installation completes.
5. Once Windows has rebooted open Services. Then stop Service ADVISOR Node and Servce ADVISOR Solr Search.
6. Open File Explorer and go to the following folder: C:\ProgramData\Service ADVISOR Delete the db and solr folders
7. Extract the solr.rar file provided in the download and move the solr folder to C:\ProgramData\Service Advisor. Make sure that the folder structure matches the below picture.
8. Extract the db.rar file provided in the download and move the db folder to C:\ProgramData\Service Advisor. Make sure that the folder structure matches the below picture.
9. Move the jblm.lic file provided in the download to C:\Programdata\Service Advisor\JDLM
10. Extract the Data.rar file provided in the download and move the Data and Data Sets folder to C:\ProgramData\Service Advisor. Make sure that the folder structure matches the below picture.
Note: By default this is where JDSA is configured to look for these two folders. These folders can be relocated to a different folder on the same drive or too another storage location. Once the install is completed JDSA can be reconfigured to look for these folders and files in another location. Howerver do not modify the subfolder structure of the Data or Data Sets Folder or this will break JDSA.
11. Extract the js.rar file provided in the download. Replace the files config.js and server.jst files in C:\Program Files (x86)\Service ADVISOR\Node WebServer\lib\node_modules\apps\FrontEndServer\app with the ones provided in the js.rar
12. Replace the file connector.js in C:\Program Files (x86)\Service ADVISOR\Node WebServer\lib\node_modules\apps\Connector\app\connector with the one provided in the js.rar
13. Replace the file environment.js in C:\Program Files (x86)\Service ADVISOR\Node WebServer\lib\node_modules\Environment with the one provided in the js.rar
14. Replace the file server.js in C:\Program Files (x86)\Service ADVISOR\Node WebServer\lib\node_modules\apps\JDLicenseManagement\app with the one provided in the subfodler server within the js.rar
15. Restart the PC, or start the Service ADVISOR Node and Servce ADVISOR Solr Search.
16. Double click the Service ADVISOR 5.2 icon on the desktop and it should load the following page.
17. Select Offiline and login with the provided User Name x187550.
18. Agree to the User Agreement License and that will then load this page.
19. To reconfigure JDSA Data and Data Sets folder as noted on step 10 Click the Offline link on this page, and then select Data on the next page. From there you can redirect JDSA to the Data and Data Sets folder location.
Master
Cleaner
717
2,859,982
#4
Master
Cleaner
717
2,859,982
#8
Languages: English
Make: John Deere
Region: WorldWide
Version: 05.2.471
Year: 2019.11
