705,263
GSI Portable Dryer 1118 CFAB400 Parts Catalog 652081
Brand: GSI
Type of Machine: Portable Dryer
Model:
GSI 1118 Portable Dryer
FFI CFAB400 Portable Dryer
Part Number: 652081
Number of Pages: 226 Pages
Main Structure Assembly
Frame Assembly
Basket Assembly Meter Rolls And Drive, 7 Meter Roll
Basket Bulk Head, 7 Meter Roll
Clean-Out Door, 7 Meter Roll
Basket Assembly Meter Rolls And Drive, 4 Ac 2015 - (Gsi Only)
Basket Bulk Head, 4 Ac 2015 - (Gsi Only)
Clean-Out Door, 4 Ac 2015 - (Gsi Only)
Inside Bottom Screen, Galvanize (0.094) - (Gsi Only)
Inside Bottom Screen, Galvanize, 7 Meter Roll (0.094) - (2015)
Inside Bottom Screen, Galvanze, 7 Meter Roll (0.055)
Inside Top Screen, Galvanize, One Piece Screen (0.094)
Inside Top Screen, Galvanize, One Piece Screen (0.055)
Inside Wall Screen, Galvanize (0.094)
Inside Wall Screen, Galvanize (0.055)
Outside Bottom Screen, Galvanize (0.094) - (Gsi Only)
Outside Bottom Screen, Galvanize, 7 Meter Roll (0.094) - (2015)
Outside Bottom Screen, Galvanize, 7 Meter Roll (0.055)
Outside Bottom Screen, Stainless Steel (0.094) - (Gsi Only-2015)
Outside Top Screen, Galvanize (0.094)
Outside Top Screen, Galvanize (0.055)
Outside Top Screen, Stainless Steel (0.094) - (Gsi Only-2015)
Outside Wall Screen, Galvanize (0.094)
Outside Wall Screen, Galvanize (0.055)
Outside Wall Screen, Stainless Steel (0.094) - (Gsi Only-2015)
Column End Panels
Ladder, Panel And Hitch, Orange Black 2012 - Front Side - (Ffi Only-2015)
Ladder And Panel, Orange Black 2012 - Rear Side - (Ffi Only-2015)
Ladder, Panel And Hitch, Ochre Black 2012 - Front Side - (Gsi Only-2015)
Ladder And Panel, Ochre Black 2012 - Rear Side - (Gsi Only-2015)
Ladder, Panel And Hitch, Ochre Black - Front Side - (Gsi Only-2016)
Ladder And Panel, Ochre Black - Rear Side - (Gsi Only-2016)
Wet Bin Components, Full Stainles - (Gsi Only-2015)
Wet Bin Components, Galvanized - (2015)
Wet Bin Components - Galvanized - (Gsi Only-2016)
Wet Bin Components, No Perf Sides - (Gsi Only-2016)
Auger And Metering Roll Drive Trains
Bottom Auger And Drive Components, New Discharge - (Ffi Only-2015)
Discharge Assembly, New Discharge - (Ffi Only-2015)
Bottom Auger And Drive Components, 7 Meter Roll, New Discharge - (Gsi Only-2015)
Discharge Assembly, 7 Meter Roll, New Discharge - (Gsi Only-2015)
Bottom Auger And Drive Components, New Discharge, 7 Meter Roll - (Gsi Only-2016)
Discharge Assembly, New Discharge, 7 Meter Roll - (Gsi Only-2016)
Bottom Auger And Drive Components, New Discharge - (Gsi Only-2015)
Discharge Assembly, New Discharge - (Gsi Only-2015)
Bottom Auger And Drive Components, New Discharge - (Gsi Only-2016)
Discharge Assembly, New Discharge - (Gsi Only-2016)
Top Auger Assembly, Vision Black
Top Auger Drive Package, 18' Std Top Dritek Plus - (Ffi Only-2015)
Top Auger Drive Package, 18' Wb Dritek Plus, 2012 - (Ffi Only-2015)
Top Auger Drive Components, 7 Meter Roll - (Gsi Only-2015)
Top Auger Drive Components, Wb Och Vision 2007 - (Gsi Only-2015)
Top Auger Drive Components, Np Wb Och Vision, 7 Meter Roll - (Gsi Only-2016)
Top Auger Package, Standard Top, Galvanized - (Ffi Only-2015)
Fan And Heater
Supply Line, Csa, Lp
Supply Line, Vision, Lp
Supply Line, Vision, Ng - (Gsi Only-2015)
Fan And Heater Housing, 42in, 20hp, 208-230v, 3 Phase, Vision
Heater Burner Assembly, 42in, 20hp, 208-230v, 3 Phase, Vision
Fan And Heater Housing, 42in, 20hp, 208-230v, 3 Phase, Vision - (Gsi Only-2015)
Heater Burner Assembly, 42in, 20hp, 208-230v, 3 Phase, Vision - (Gsi Only-2015)
Fan And Heater Housing, 42in, 20hp, 440v, 3 Phase, Vision - (Gsi Only-2015)
Heater Burner Assembly, 42in, 20hp, 440v, 3 Phase, Vision - (Gsi Only-2015)
Fan And Heater Housing, 42in, 20hp, 575v, 3 Phase, Vision, Csa 2015
Heater Burner Assembly, 42in, 20hp, 575v, 3 Phase, Vision, Csa 2015
Moisture Sampler Blower, 220v
Moisture Sampler Blower, 440v - (Gsi Only-2015)
Moisture Sampler Blower, 575v
Auger Drive Motor Assembly, 5hp, 3 Phase
Auger Drive Motor Assembly, 5hp, 3 Phase, 575v
Electrical Package, Tilt Switch Box, Vision, 3 Phase, 220v - (Gsi Only)
Electrical Package, Timing Gear, Vision, 3 Phase, 220v - (Gsi Only)
Electrical Package, Tilt Switch Box, Vision, 3 Phase, 575v, Csa, 7 Meter, Roll Standard Top - (Ffi Only-2015)
Electrical Package, Timing Gear, Vision, 3 Phase, 575v, Csa, 7 Meter Roll, Standard Top - (Ffi Only-2015)
Electrical Package, Tilt Switch Box, Vision, 3 Phase, 220v, 7 Meter Roll - (Ffi Only-2015)
Electrical Package, Timing Gear, Vision, 3 Phase, 220v, 7 Meter Roll - (Ffi Only-2015)
Electrical Package, Tilt Switch Box, Vision, 3 Phase, 440v, 7 Meter Roll - (Gsi Only-2015)
Electrical Package, Timing Gear, Vision, 3 Phase, 440v, 7 Meter Roll - (Gsi Only-2015)
Electrical Package, Tilt Switch Box, Vision, 3 Phase, 575v, Csa, 7 Meter Roll - (Gsi Only-2016)
Electrical Package, Timing Gear, Vision, 3 Phase, 575v, Csa, 7 Meter Roll - (Gsi Only-2016)
Mbc Motor Circuit - 10hp, 3 Phase, 220v, Load Aux - (2015)
Mbc Motor Circuit - 10hp, 3 Phase, 220v, Unload Aux - (2015)
Mbc Motor Circuit - 10hp, 3 Phase, 440v, Load Aux - (Gsi Only-2015)
Mbc Motor Circuit - 10hp, 3 Phase, 440v, Unload Aux - (Gsi Only-2015)
Mbc Motor Circuit - 15hp, 3 Phase, 440v, Unload Aux - (Gsi Only-2015)
Mbc Motor Circuit - 10hp, 3 Phase, 575v, Unload Aux - (Ffi Only-2015)
Mbc Motor Circuit - 7.5hp, 3 Phase, 575v, Load Aux - (Ffi Only-2015)
Precision Farming Systems
Upper Control Box, Vision Hybrid, 3 Phase, 220v, 7 Meter Roll - (Gsi Only-2015)
Lower Control Box, Vision Hybrid, 3 Phase, 220v, 7 Meter Roll - (Gsi Only-2015)
Upper Control Box, Vision Hybrid, 3 Phase, 440v, 7 Meter Roll - (Gsi Only-2015)
Lower Control Box, Vision Hybrid, 3 Phase, 440v, 7 Meter Roll - (Gsi Only-2015)
Upper Control Box, Vision Hybrid, 3 Phase, 220v, 7 Meter Roll - (Ffi Only-2015)
Lower Control Box, Vision Hybrid, 3 Phase, 220v, 7 Meter Roll - (Ffi Only-2015)
Upper Control Box, Vision Hybrid, 3 Phase, 575v - (Ffi Only-2015)
Lower Control Box, Vision Hybrid, 3 Phase, 575v - (Ffi Only-2015)
Upper Control Box, Vision Hybrid, 3 Phase, 220v, 10hp Load Unload - (Gsi Only-2016)
Lower Control Box, Vision Hybrid, 3 Phase, 220v, 10hp Load Unload - (Gsi Only-2016)
Upper Control Box, Vision Hybrid, 3 Phase, 575v, 10hp Load Unload, 7 Meter Roll - (Gsi Only-2016)
Lower Control Box, Vision Hybrid, 3 Phase, 575v, 10hp Load Unload, 7 Meter Roll - (Gsi Only-2016)
Decal
Decals - Front - (Gsi Only)
Decals - Rear - (Gsi Only)
Decals - Right Hand Side - (Gsi Only)
Decals - Left Hand Side - (Gsi Only)
Decals - Front Inner - (Gsi Only)
Decals - Front - (Ffi Only-2015)
Decals - Rear - (Ffi Only-2015)
