GSI Portable Dryer 1112 CFAB270 Parts Catalog 652074
Brand: GSI
Type of Machine: Portable Dryer
Model:
GSI 1112 Portable Dryer
FFI CFAB270 Portable Dryer
Part Number: 652074
Number of Pages: 446 Pages
Main Structure Assembly
Frame Assembly
Basket Assembly Meter Rolls And Drive, 7 Meter Roll
Basket Bulk Head, 7 Meter Roll
Clean-Out Door, 7 Meter Roll
Basket Assembly Meter Rolls And Drive, 4 Ac 2015 - (Gsi Only)
Basket Bulk Head, 4 Ac 2015 - (Gsi Only)
Clean-Out Door, 4 Ac 2015 - (Gsi Only)
Basket Assembly Meter Rolls And Drive, 4 Ac 2015 (0.055) - (Gsi Only)
Basket Bulk Head, 4 Ac 2015 (0.055) - (Gsi Only)
Clean-Out Door, 4 Ac 2015 (0.055) - (Gsi Only)
Inside Bottom Screen, Galvanize (0.094) - (Gsi Only)
Inside Bottom Screen, Galvanize, 7 Meter Roll (0.094) - (2015)
Inside Bottom Screen, Galvanize (0.055) - (Gsi Only)
Inside Bottom Screen, Galvanze, 7 Meter Roll (0.055)
Inside Top Screen, Galvanize, One Piece Screen (0.094)
Inside Top Screen, Galvanize, One Piece Screen (0.055)
Inside Wall Screen, Galvanize (0.094)
Inside Wall Screen, Galvanize (0.055)
Outside Bottom Screen, Galvanize (0.094) - (Gsi Only)
Outside Bottom Screen, Galvanize, 7 Meter Roll (0.094)
Outside Bottom Screen, Galvanize (0.055) - (Gsi Only)
Outside Bottom Screen, Galvanize, 7 Meter Roll (0.055)
Outside Bottom Screen, Stainless Steel (0.094) - (Gsi Only)
Outside Bottom Screem Btm, Stainless Steel (0.094), 7 Meter Roll - (2015)
Outside Top Screen, Galvanize (0.094)
Outside Top Screen, Galvanize (0.055)
Outside Top Screen, Stainless Steel (0.094) - (Gsi Only)
Outside Wall Screen, Galvanize (0.094)
Outside Wall Screen, Galvanize (0.055)
Outside Wall Screen, Stainless Steel (0.094) - (Gsi Only)
Column End Panels
Wet Bin Components, Galvanized
Wet Bin Components, No Perf Sides - (2015)
Wet Bin Components, No Perf Sides 2016 - (Gsi Only)
Ladder, Panel And Hitch, Ochre Black 2012 - Front Side - (Gsi Only)
Ladder And Panel, Ochre Black 2012 - Rear Side - (Gsi Only)
Ladder, Panel And Hitch, Orange Black 2012 - Front Side - (Ffi Only-2015)
Ladder And Panel, Orange Black 2012 - Rear Side - (Ffi Only-2015)
Ladder, Panel And Hitch, Orange Black 2016 - Front Side - (Ffi Only)
Ladder And Panel, Orange Black 2016 - Rear Side - (Ffi Only)
Ladder, Panel And Hitch, Ochre Black 2016 - Front Side - (Gsi Only)
Ladder And Panel, Ochre Black 2016 - Rear Side - (Gsi Only)
Grain Inverter Package, 12',.050 - (Gsi Only-2016)
Auger And Metering Roll Drive Trains
Bottom Auger And Drive Components, 7 Meter Roll, New Discharge - (Gsi Only-2015)
Discharge Assembly, 7 Meter Roll, New Discharge - (Gsi Only-2015)
Bottom Auger And Drive Components, New Discharge 2016 - (Ffi Only)
Discharge Assembly, New Discharge 2016 - (Ffi Only)
Bottom Auger And Drive Components, 7 Meter Roll New Discharge 2016 - (Gsi Only)
Discharge Assembly, 7 Meter Roll New Discharge 2016 - (Gsi Only)
Bottom Auger And Drive Components, New Discharge 2016 - (Gsi Only)
Discharge Assembly, New Discharge 2016 - (Gsi Only)
Bottom Auger And Drive Components, New Discharge - (Gsi Only)
Discharge Assembly, New Discharge - (Gsi Only)
Bottom Auger And Drive Components, With Bypass - (Gsi Only)
Discharge Assembly, With Bypass - (Gsi Only)
Bottom Auger And Drive Components, New Discharge - (Ffi Only-2015)
Discharge Assembly, New Discharge - (Ffi Only-2015)
Top Auger Package, Standard Top, Galvanized - (Ffi Only)
Top Auger Assembly, Vision - (Gsi Only)
Top Auger Assembly, Vision, Front Fill - (Gsi Only)
Top Auger Assembly, Vision Black, Without Lift Kit - (2017)
Top Auger Assembly, Vision Black, Without Lift Kit, Front Fill - (Gsi Only-2017)
Top Auger Drive Components, 7 Meter Roll - (Gsi Only-2015)
Top Auger Drive Components, Vision 2008 - (Gsi Only-2015)
Top Auger Drive Components, Vision 2007 - (Gsi Only)
Top Auger Drive Package, 12' Wb Dritek Plus, 2012 - (Ffi Only-2015)
Top Auger Drive Package, 12' Std Top Dritek Plus - (Ffi Only-2015)
Top Auger Drive Components, Np Wb Och Vision 7 Meter Roll 2016 - (Gsi Only-2016)
Top Auger Drive Components, No Wb Ffi Vision 7 Meter Roll 2016 - (Ffi Only-2016)
Top Auger Drive Components, Np Wb Och Vision 2016 - (Gsi Only-2016)
Top Auger Drive Components, Galv. Perf. Wb Och Vision 2016 - (Gsi Only-2016)
Fan And Heater
Supply Line, Csa, Lp
Supply Line, Vision, Lp
Supply Line, Vision, Ng - (Gsi Only)
Supply Line, Csa Ng
Fan And Heater Housing, 36in, 15hp, 1 Phase, Vision
Heater Burner Assembly, 36in, 15hp, 1 Phase, Vision
Fan And Heater Housing, 36in, 15hp, 1 Phase, Vision - (Gsi Only)
Heater Burner Assembly, 36in, 15hp, 1 Phase, Vision - (Gsi Only)
Fan And Heater Housing, 36in, 15hp, 3 Phase, Vision - (Gsi Only)
Heater Burner Assembly, 36in, 15hp, 3 Phase, Vision - (Gsi Only)
Fan And Heater Housing, 36in, 15hp, 3 Phase, Vision - (Gsi Only-2015)
Heater Burner Assembly, 36in, 15hp, 3 Phase, Vision - (Gsi Only-2015)
Fan And Heater Housing, 36in, 15hp, 440v, 3 Phase, Vision - (Gsi Only)
Heater Burner Assembly, 36in, 15hp, 440v, 3 Phase, Vision - (Gsi Only)
Fan And Heater Housing, 36in, 15hp, 1ph, Vision, Csa 2015
Heater Burner Assembly, 36in, 15hp, 1ph, Vision, Csa 2015
Fan And Heater Housing, 36in 15hp, 230v, 1ph-Ng Vis Csa 2015
Heater Burner Assembly, 36in 15hp, 230v, 1ph-Ng Vis Csa 2015
Fan And Heater Housing, 36in 15hp, 1ph-Lp Vis 2015 Cast Blade - (Ffi Only-2015)
Heater Burner Assembly, 36in 15hp, 1ph-Lp Vis 2015 Cast Blade - (Ffi Only-2015)
Fan And Heater Housing, 36in, 15hp, 3 Phase, Vision, Csa 2015 - (Gsi Only-2016)
Heater Burner Assembly, 36in, 15hp, 3 Phase, Vision, Csa 2015 - (Gsi Only-2016)
Fan And Heater Housing, 36in, 15hp, 440v 3 Phase, Vision, Csa 2015, Cast Blade - (2017)
Heater Burner Assembly, 36in, 15hp, 440v 3 Phase, Vision, Csa 2015, Cast Blade - (2017)
Moisture Sampler Blower, 220v
Moisture Sampler Blower - Front Fill - (Gsi Only)
Moisture Sampler Blower, 440v
Moisture Sampler Blower, 575v - (Gsi Only)
Auger Drive Motor Assembly, 2hp, 1phase
Auger Drive Motor Assembly, 2hp, 3 Phase
Auger Drive Motor Assembly, 2hp, 3 Phase, 575v - (Gsi Only-2016)
Mbc Motor Circuit, 10hp, 1 Phase, Load Aux - (Gsi Only-2015)
Mbc Motor Circuit, 10hp, 1 Phase, Unload Aux - (Gsi Only-2015)
Mbc Motor Circuit - 7.5hp, 1 Phase, Load Aux - (Gsi Only)
Mbc Motor Circuit - 7.5hp, 1 Phase, Unload Aux - (Gsi Only)
Mbc Motor Circuit - 10hp, 3 Phase, Load Aux - (Gsi Only-2015)
Mbc Motor Circuit - 10hp, 3 Phase, Unload Aux - (Gsi Only-2015)
Mbc Motor Circuit - 7.5hp, 3 Phase, Load Aux - (Gsi Only-2015)
Mbc Motor Circuit - 7.5hp, 3 Phase, Unload Aux - (Gsi Only-2015)
Mbc Motor Circuit - 10hp, 3 Phase, Load Aux, 440v - (Gsi Only-2015)
Mbc Motor Circuit - 10hp, 3 Phase, Unload Aux, 440v - (Gsi Only-2015)
Electrical Package, Tilt Switch Box, Vision, 1 Phase - (Gsi Only)
Electrical Package, Timing Gear, Vision, 1 Phase - (Gsi Only)
Electrical Package, Tilt Switch Box, Vision, 1 Phase, Standard Top - (Gsi Only-2015)
Electrical Package, Timing Gear, Vision, 1 Phase, Standard Top - (Gsi Only-2015)
Electrical Package, Tilt Switch Box, Vision, 3 Phase - (Gsi Only)
Electrical Package, Timing Gear, Vision, 3 Phase - (Gsi Only)
Electrical Package, Tilt Switch Box, Vision, 3 Phase, 440v - (Gsi Only)
Electrical Package, Timing Gear, Vision, 3 Phase, 440v - (Gsi Only)
Electrical Package, Tilt Switch Box, Vision, 1 Phase, Csa - (Gsi Only)
Electrical Package, Timing Gear, Vision, 1 Phase, Csa - (Gsi Only)
Electrical Package, Tilt Switch Box, Vision, 1 Phase, Csa, 7 Meter Roll - (Gsi Only)
Electrical Package, Timing Gear, Vision, 1 Phase, Csa, 7 Meter Roll - (Gsi Only)
Electrical Package, Tilt Switch Box, Vision, 1 Phase, 7 Meter Roll
Electrical Package, Timing Gear, Vision, 1 Phase, 7 Meter Roll
Electrical Package, Tilt Switch Box, Vision, 1 Phase, 7 Meter Roll, Standard Top - (2015)
Electrical Package, Timing Gear, Vision, 1 Phase, 7 Meter Roll, Standard Top - (2015)
Electrical Package, Tilt Switch Box, Csa Vision, 1 Phase, 7 Meter Roll Standard Top - (Ffi Only)
Electrical Package, Timing Gear, Csa Vision, 1 Phase, 7 Meter Roll Standard Top - (Ffi Only)
Electrical Package, Tilt Switch Box, Vision, 3 Phase - (Gsi Only-2016)
Electrical Package, Timing Gear, Vision, 3 Phase - (Gsi Only-2016)
Electrical Package, Tilt Switch Box, Csa Vision, 3 Phase, 575v, 7 Meter Roll - (Gsi Only-2016)
Electrical Package, Timing Gear, Csa Vision, 3 Phase, 575v, 7 Meter Roll - (Gsi Only-2016)
Electrical Package, Tilt Switch Box, Csa Vision, 3 Phase, 440v, 7 Meter Roll - (Gsi Only-2017)
Electrical Package, Timing Gear, Csa Vision, 3 Phase, 440v, 7 Meter Roll - (Gsi Only-2017)
Electrical Package, Tilt Switch Box, Csa Vision, 3 Phase, 440v, 7 Meter Roll Standard Top - (Ffi Only-2017)
Electrical Package, Timing Gear, Csa Vision, 3 Phase, 440v, 7 Meter Roll Standard Top - (Ffi Only-2017)
Electrical Package, Front Fill Option, 12' Vision - (Gsi Only)
Precision Farming Systems
Upper Control Box, Vision, 1 Phase - (Gsi Only)
Lower Control Box, Vision, 1 Phase - (Gsi Only)
Upper Control Box, Vision, 1 Phase, Csa - (Gsi Only-2015)
Lower Control Box, Vision, 1 Phase, Csa - (Gsi Only-2015)
Upper Control Box, Vision, 1 Phase, 7 Meter Roll - (Gsi Only-2015)
Lower Control Box, Vision, 1 Phase, 7 Meter Roll - (Gsi Only-2015)
Upper Control Box, Vision, 3 Phase, 440v - (Gsi Only-2015)
Lower Control Box, Vision, 3 Phase, 440v - (Gsi Only-2015)
Upper Control Box, Vision, 1 Phase, 7.5hp Load, 10hp Unload - (Gsi Only-2015)
Lower Control Box, Vision, 1 Phase, 7.5hp Load, 10hp Unload - (Gsi Only-2015)
Upper Control Box, Vision, 1 Phase, 7 Meter Roll, Csa - (Gsi Only-2015)
Lower Control Box, Vision, 1 Phase, 7 Meter Roll, Csa - (Gsi Only-2015)
Upper Control Box, Vision, 3 Phase, 7.5hp Load And Unload - (Gsi Only-2015)
Lower Control Box, Vision, 3 Phase, 7.5hp Load And Unload - (Gsi Only-2015)
Upper Control Box, Vision, 3 Phase, 220v - (Gsi Only-2015)
Lower Control Box, Vision, 3 Phase, 220v - (Gsi Only-2015)
Upper Control Box, 220v 1 Phase, Vision Hybrid, 7 Meter Roll - (Ffi Only-2015)
Lower Control Box, 220v 1 Phase, Vision Hybrid, 7 Meter Roll - (Ffi Only-2015)
Upper Control Box, Csa 220v 1 Phase, Vision Hybrid, 7 Meter Roll - (Ffi Only-2015)
Lower Control Box, Csa 220v 1 Phase, Vision Hybrid, 7 Meter Roll - (Ffi Only-2015)
Upper Control Box, Vision Hybrid, 1 Phase, 7.5hp Load Unload Auxs, 220v - (Gsi-2016)
Lower Control Box, Vision Hybrid, 1 Phase, 7.5hp Load Unload Auxs, 220v - (Gsi-2016)
Upper Control Box, Vision Hybrid, 3 Phase, 7.5hp Load Unload, 440v - (Gsi Only-2016)
Lower Control Box, Vision Hybrid, 3 Phase, 7.5hp Load Unload, 440v - (Gsi Only-2016)
Upper Control Box, Vision, 3 Phase, 7.5hp Load Unload, 208v - (Gsi Only-2016)
Lower Control Box, Vision, 3 Phase, 7.5hp Load Unload, 208v - (Gsi Only-2016)
Upper Control Box, Vision Hybrid, 1 Phase, 7.5hp Load, 10hp Un, 220v - (Gsi Only-2016)
Lower Control Box, Vision Hybrid, 1 Phase, 7.5hp Load, 10hp Un, 220v - (Gsi Only-2016)
Upper Control Box, Vision Hybrid, 1 Phase, 7.5hp Load Un, 220v, 7 Meter Roll - (Gsi Only)
Lower Control Box, Vision Hybrid, 1 Phase, 7.5hp Load Un, 220v, 7 Meter Roll - (Gsi Only)
Upper Control Box, Vision Hybrid, 3 Phase, 7.5hp Load Un, 575v, 7 Meter Roll - (Gsi Only-2016)
Lower Control Box, Vision Hybrid, 3 Phase, 7.5hp Load Un, 575v, 7 Meter Roll - (Gsi Only-2016)
Upper Control Box, Vision Hybrid, 1 Phase, 7.5hp Load Un, 220v, 7 Meter Roll - (Ffi Only-2016)
Lower Control Box, Vision Hybrid, 1 Phase, 7.5hp Load Un, 220v, 7 Meter Roll - (Ffi Only-2016)
Upper Control Box, Vision Hybrid, 1 Phase, 7.5hp Load Un, 220v - (Gsi Only)
Lower Control Box, Vision Hybrid, 1 Phase, 7.5hp Load Un, 220v - (Gsi Only)
Upper Control Box, Vision Hybrid, 1 Phase, 7.5hp Load Un, Csa 220v - (Ffi Only)
Lower Control Box, Vision Hybrid, 1 Phase, 7.5hp Load Un, Csa 220v - (Ffi Only)
Upper Control Box, Vision Hybrid, 1 Phase, 10hp Load, 7.5hp Unload, 220v - (Gsi Only-2017)
Lower Control Box, Vision Hybrid, 1 Phase, 10hp Load, 7.5hp Unload, 220v - (Gsi Only-2017)
Upper Control Box, Vision Hybrid, 3 Phase, 7.5hp Load Unload, 220v - (Gsi Only-2017)
Lower Control Box, Vision Hybrid, 3 Phase, 7.5hp Load Unload, 220v - (Gsi Only-2017)
Upper Control Box, Vision Hybrid, 3 Phase, 7.5hp Load, 10hp Unload, 440v - (Gsi Only-2017)
Lower Control Box, Vision Hybrid, 3 Phase, 7.5hp Load, 10hp Unload, 440v - (Gsi Only-2017)
Upper Control Box, Vision Hybrid, 1 Phase, 7.5hp Load, 10hp Unload, Csa 220v - (Gsi Only-2017)
Lower Control Box, Vision Hybrid, 1 Phase, 7.5hp Load, 10hp Unload Csa 220v - (Gsi Only-2017)
Upper Control Box, Vision Hybrid, 1 Phase, 7.5hp Load Unload, 220v, 7 Meter Roll - (Gsi Only-2017)
Lower Control Box, Vision Hybrid, 1 Phase, 7.5hp Load Unload, 220v, 7 Meter Roll - (Gsi Only-2017)
Upper Control Box, Vision Hybrid, 1 Phase, 7.5hp Load, 10hp Unload, 220v, 7 Meter Roll, Csa - (Gsi Only-2017)
Lower Control Box, Vision Hybrid, 1 Phase, 7.5hp Load, 10hp Unload, 220v, 7 Meter Roll, Csa - (Gsi Only-2017)
Upper Control Box, Vision Hybrid, 1 Phase, 10hp Load Unload, 220v, 7 Meter Roll, Csa - (Gsi Only-2017)
Lower Control Box, Vision Hybrid, 1 Phase, 10hp Load Unload, 220v, 7 Meter Roll, Csa - (Gsi Only-2017)
Upper Control Box, Vision Hybrid, 3 Phase, 7.5hp Load, 10hp Unload, 440v, 7 Meter Roll, Csa - (Gsi Only-2017)
Lower Control Box, Vision Hybrid, 3 Phase, 7.5hp Load, 10hp Unload, 440v, 7 Meter Roll, Csa - (Gsi Only-2017)
Upper Control Box, Vision Hybrid, 1 Phase, 7.5hp Load Unload, D270, 220v, 7 Meter Roll - (Ffi Only-2017)
Lower Control Box, Vision Hybrid, 1 Phase, 7.5hp Load Unload, D270, 220v, 7 Meter Roll - (Ffi Only-2017)
Upper Control Box, Vision Hybrid, 3 Phase, 7.5hp Load Unload, D270, 440v, 7 Meter Roll, Csa - (Ffi Only-2017)
Lower Control Box, Vision Hybrid, 3 Phase, 7.5hp Load Unload, D270, 440v, 7 Meter Roll, Csa - (Ffi Only-2017)
Decal
Decals - Front - (Gsi Only)
Decals - Rear - (Gsi Only)
Decals - Right Hand Side - (Gsi Only)
Decals - Left Hand Side - (Gsi Only)
Decals - Front Inner - (Gsi Only)
Decal - (Ffi Only)
Brand: GSI
Model:
Part Number: 652074
Frame Assembly
Column End Panels
Fan And Heater
Supply Line, Csa Ng
Decal
Decal - (Ffi Only)
- GSI Agridry Gravity Grain Spreaders Parts Catalog 652169
- GSI Direct Gear Drive Bin Sweep 10” Heavy Duty Parts Catalog 652164
- GSI Direct Gear Drive Bin Sweep 8” And 10” Standard Duty Parts Catalog 652163
- GSI Modular Tower Dryers 1008 Parts Catalog 652289
- GSI Modular Tower Dryers 1010 Parts Catalog 652290
- GSI Modular Tower Dryers 1012 Parts Catalog 652291
- GSI Modular Tower Dryers 1015 Parts Catalog 652292
- GSI Portable Dryer 1108 CFAB190 Parts Catalog 652072
- GSI Portable Dryer 1114 CFAB320 Parts Catalog 652077
- GSI Portable Dryer 1116 CFAB370 Parts Catalog 652073
- GSI Portable Dryer 1118 CFAB400 Parts Catalog 652081
- GSI Portable Dryer 1120 Parts Catalog 652079
- GSI Portable Dryer 1122 Parts Catalog 652084
- GSI Portable Dryer 1126 Parts Catalog 652082
- GSI Portable Dryer 1214 Parts Catalog 652085
