GSI Modular Tower Dryers 1008 Parts Catalog 652289
Brand: GSI
Type of Machine: Modular Tower Dryers
Model: GSI 1008 Modular Tower Dryers
Part Number: 652289
Number of Pages: 251 Pages
Rooftop Plenum
Rooftop Solid Sheet And Vertical Channel
Inner Roof Assembly
Outer Roof Assembly
Roof Peak Walk Around Assembly
Handrail And Walk Around
Catwalk & Ladder Assembly
Catwalk Package
Ladder Safety Cage - 800
Unload Section
Unload Auger - W 3hp Motor
Half Wall Stainless Sheet And Vertical Channel - 1008f, 460v, Lp - (Ffi Only)
Inside Wall Stainless Sheet And Rolled Plenum Channel - 1008f, 460v, Lp - (Ffi Only)
Pipe Train - 1008f, 460v, Lp - (Ffi Only)
Outside Platform Section With Handrails - 1008f, 460v, Lp - (Ffi Only)
Contoured Door Opening Section - 1008f, 460v, Lp - (Ffi Only)
Window And Louvered Door Kit - 1008f, 460v, Lp - (Ffi Only)
Sweep Section - 1008f, 460v, Lp - (Ffi Only)
Flat Unload Hopper - 1008f, 460v, Lp - (Ffi Only)
Bottom Channels And Support Column - 1008f, 460v, Lp - (Ffi Only)
Moisture Sensor Housing Assembly - 1008f, 460v, Lp - (Ffi Only)
Half Wall Stainless Sheet And Vertical Channel - 1008t, 240v, Lp - (Gsi Only)
Inside Wall Stainless Sheet And Rolled Plenum Channel - 1008t, 240v, Lp - (Gsi Only)
Pipe Train - 1008t, 240v, Lp - (Gsi Only)
Outside Platform Section With Handrails - 1008t, 240v, Lp - (Gsi Only)
Contoured Door Opening Section - 1008t, 240v, Lp - (Gsi Only)
Window And Louvered Door Kit - 1008t, 240v, Lp - (Gsi Only)
Sweep Section - 1008t, 240v, Lp - (Gsi Only)
Flat Unload Hopper - 1008t, 240v, Lp - (Gsi Only)
Bottom Channels And Support Column - 1008t, 240v, Lp - (Gsi Only)
Moisture Sensor Housing Assembly - 1008t, 240v, Lp - (Gsi Only)
Half Wall Stainless Sheet And Vertical Channel - 1008t, 460v, Ng - (Gsi Only)
Inside Wall Stainless Sheet And Rolled Plenum Channel - 1008t, 460v, Ng - (Gsi Only)
Pipe Train - 1008t, 460v, Ng - (Gsi Only)
Outside Platform Section With Handrails - 1008t, 460v, Ng - (Gsi Only)
Contoured Door Opening Section - 1008t, 460v, Ng - (Gsi Only)
Window And Louvered Door Kit - 1008t, 460v, Ng - (Gsi Only)
Sweep Section - 1008t, 460v, Ng - (Gsi Only)
Flat Unload Hopper - 1008t, 460v, Ng - (Gsi Only)
Bottom Channels And Support Column - 1008t, 460v, Ng - (Gsi Only)
Moisture Sensor Housing Assembly - 1008t, 460v, Ng - (Gsi Only)
Half Wall Stainless Sheet And Vertical Channel - 1008t, 230v, Lp - (Gsi Only)
Inside Wall Stainless Sheet And Rolled Plenum Channel - 1008t, 230v, Lp - (Gsi Only)
Pipe Train - 1008t, 230v, Lp - (Gsi Only)
Outside Platform Section With Handrails - 1008t, 230v, Lp - (Gsi Only)
Contoured Door Opening Section - 1008t, 230v, Lp - (Gsi Only)
Window And Louvered Door Kit - 1008t, 230v, Lp - (Gsi Only)
Sweep Section - 1008t, 230v, Lp - (Gsi Only)
Flat Unload Hopper - 1008t, 230v, Lp - (Gsi Only)
Bottom Channels And Support Column - 1008t, 230v, Lp - (Gsi Only)
Moisture Sensor Housing Assembly - 1008t, 230v, Lp - (Gsi Only)
Half Wall Stainless Sheet And Vertical Channel - 1008t, 240v, Mod Valve - (Gsi Only)
Inside Wall Stainless Sheet And Rolled Plenum Channel - 1008t, 240v, Mod Valve - (Gsi Only)
Pipe Train - 1008t, 240v, Mod Valve - (Gsi Only)
Outside Platform Section With Handrails - 1008t, 240v, Mod Valve - (Gsi Only)
Contoured Door Opening Section - 1008t, 240v, Mod Valve - (Gsi Only)
Window And Louvered Door Kit - 1008t, 240v, Mod Valve - (Gsi Only)
Sweep Section - 1008t, 240v, Mod Valve - (Gsi Only)
Flat Unload Hopper - 1008t, 240v, Mod Valve - (Gsi Only)
Bottom Channels And Support Column - 1008t, 240v, Mod Valve - (Gsi Only)
Moisture Sensor Housing Assembly - 1008t, 240v, Mod Valve - (Gsi Only)
Half Wall Stainless Sheet And Vertical Channel - 1008f, 240v, Mod Valve - (Ffi Only)
Inside Wall Stainless Sheet And Rolled Plenum Channel - 1008f, 240v, Mod Valve - (Ffi Only)
Pipe Train - 1008f, 240v, Mod Valve - (Ffi Only)
Outside Platform Section With Handrails - 1008f, 240v, Mod Valve - (Ffi Only)
Contoured Door Opening Section - 1008f, 240v, Mod Valve - (Ffi Only)
Window And Louvered Door Kit - 1008f, 240v, Mod Valve - (Ffi Only)
Sweep Section - 1008f, 240v, Mod Valve - (Ffi Only)
Flat Unload Hopper - 1008f, 240v, Mod Valve - (Ffi Only)
Bottom Channels And Support Column - 1008f, 240v, Mod Valve - (Ffi Only)
Moisture Sensor Housing Assembly - 1008f, 240v, Mod Valve - (Ffi Only)
Heat Section With Turners
Half Wall Stainless Sheet And Vertical Channel, W Turners
Inside Wall Stainless Sheet, W Turners
Heat Section With Door
Half Wall Stainless Sheet And Vertical Channel, W Door 15 Chan
Inside Wall Stainless Sheet, W Door 15 Chan
Free Air Opending Kit, W Door 15 Chan
Burner Blower Section
Half Wall Stainless Sheet And Vertical Channel - 1008, 230v - (Gsi Only)
Inside Wall Stainless Sheet And Vertical Support - 1008, 230v - (Gsi Only)
Divider Hopper - 1008, 230v - (Gsi Only)
Fan And Blower Housing - 1008, 230v - (Gsi Only)
Burner Assembly - 1008, 230v - (Gsi Only)
Half Wall Stainless Sheet And Vertical Channel - 1008, 230v - (Ffi Only)
Inside Wall Stainless Sheet And Vertical Support - 1008, 230v - (Ffi Only)
Divider Hopper - 1008, 230v - (Ffi Only)
Fan And Blower Housing - 1008, 230v - (Ffi Only)
Burner Assembly - 1008, 230v - (Ffi Only)
Half Wall Stainless Sheet And Vertical Channel - 1008, 460v - (Ffi Only)
Inside Wall Stainless Sheet And Vertical Support - 1008, 460v - (Ffi Only)
Divider Hopper - 1008, 460v - (Ffi Only)
Fan And Blower Housing - 1008, 460v - (Ffi Only)
Burner Assembly - 1008, 460v - (Ffi Only)
Half Wall Stainless Sheet And Vertical Channel - 1008, 460v - (Gsi Only)
Inside Wall Stainless Sheet And Vertical Support - 1008, 460v - (Gsi Only)
Divider Hopper - 1008, 460v - (Gsi Only)
Fan And Blower Housing - 1008, 460v - (Gsi Only)
Burner Assembly - 1008, 460v - (Gsi Only)
Moisture Sampler Blower
Moisture Sampler Blower - 1008f, 460v, Lp - (Ffi Only)
Moisture Sampler Blower - 1008t, 240v, Lp - (Gsi Only)
Moisture Sampler Blower - 1008t, 460v, Ng - (Gsi Only)
Moisture Sampler Blower - 1008t, 230v, Lp - (Gsi Only)
Moisture Sampler Blower - 1008t, 240v, Mod Valve - (Gsi Only)
Moisture Sampler Blower - 1008f, 240v, Mod Valve - (Ffi Only)
Precision Farming Systems
Upper Control Box, 40hp, 480v, Ab - (Ffi Only)
Lower Control Box, 40hp, 480v, Ab - (Ffi Only)
Upper Control Box, 40hp, 240v, Ab Acl - (Gsi Only)
Lower Control Box, 40hp, 240v, Ab Acl - (Gsi Only)
Upper Control Box, 40hp, 480v, Ab Acl - (Gsi Only)
Lower Control Box, 40hp, 480v, Ab Acl - (Gsi Only)
Upper Control Box, 40hp, 240v, Ab Softstart - (Gsi Only)
Lower Control Box, 40hp, 240v, Ab Softstart - (Gsi Only)
Upper Control Box, 40hp, 240v, Ab Softstart, Modutrol - (Gsi Only)
Lower Control Box, 40hp, 240v, Ab Softstart, Modutrol - (Gsi Only)
Upper Control Box, 40hp, 240v, Ab Acl, Modutrol - (Ffi Only)
Lower Control Box, 40hp, 240v, Ab Acl, Modutrol - (Ffi Only)
Decal
Decal - (Gsi Only)
Decal - (Ffi Only)
Brand: GSI
Part Number: 652289
Rooftop Plenum
Inner Roof Assembly
Outer Roof Assembly
Catwalk Package
Unload Section
Decal
Decal - (Gsi Only)
Decal - (Ffi Only)
- GSI Agridry Gravity Grain Spreaders Parts Catalog 652169
- GSI Direct Gear Drive Bin Sweep 10” Heavy Duty Parts Catalog 652164
- GSI Direct Gear Drive Bin Sweep 8” And 10” Standard Duty Parts Catalog 652163
- GSI Modular Tower Dryers 1010 Parts Catalog 652290
- GSI Modular Tower Dryers 1012 Parts Catalog 652291
- GSI Modular Tower Dryers 1015 Parts Catalog 652292
- GSI Portable Dryer 1108 CFAB190 Parts Catalog 652072
- GSI Portable Dryer 1112 CFAB270 Parts Catalog 652074
- GSI Portable Dryer 1114 CFAB320 Parts Catalog 652077
- GSI Portable Dryer 1116 CFAB370 Parts Catalog 652073
- GSI Portable Dryer 1118 CFAB400 Parts Catalog 652081
- GSI Portable Dryer 1120 Parts Catalog 652079
- GSI Portable Dryer 1122 Parts Catalog 652084
- GSI Portable Dryer 1126 Parts Catalog 652082
- GSI Portable Dryer 1214 Parts Catalog 652085
