GSI Portable Dryer 1114 CFAB320 Parts Catalog 652077
Brand: GSI
Type of Machine: Portable Dryer
Model:
GSI 1114 Portable Dryer
FFI CFAB320 Portable Dryer
Part Number: 652077
Number of Pages: 319 Pages
Main Structure Assembly
Frame Assembly
Basket Assembly Meter Rolls And Drive, 7 Meter Roll
Basket Bulk Head, 7 Meter Roll
Clean-Out Door, 7 Meter Roll
Basket Assembly Meter Rolls And Drive, 4 Ac 2015 - (Gsi Only)
Basket Bulk Head, 4 Ac 2015 - (Gsi Only)
Clean-Out Door, 4 Ac 2015 - (Gsi Only)
Inside Bottom Screen, Galvanize (0.094)
Inside Bottom Screen, Galvanize, 7 Meter Roll (0.094)
Inside Bottom Screen, Galvanize, 7 Meter Roll (0.055) - (Gsi Only-2015)
Inside Top Screen, Galvanize, One Piece Screen (0.094)
Inside Top Screen, Galvanize, One Piece Screen (0.055) - (Gsi Only-2015)
Inside Wall Screen, Galvanize (0.094)
Inside Wall Screen, Galvanize (0.055) - (Gsi Only-2015)
Outside Bottom Screen, Galvanize (0.094)
Outside Bottom Screen, Galvanize, 7 Meter Roll (0.094)
Outside Bottom Screen, Galvanize, 7 Meter Roll (0.055) - (Gsi Only-2015)
Outside Bottom Screen, Stainless Steel (0.094) - (Gsi Only)
Outside Bottom Screem Btm, Stainless Steel (0.094), 7 Meter Roll - (Ffi Only-2015)
Outside Top Screen, Galvanize (0.094)
Outside Top Screen, Galvanize (0.055) - (Gsi Only-2015)
Outside Top Screen - Stainless Steel (0.094)
Outside Wall Screen, Galvanize (0.094)
Outside Wall Screen, Galvanize (0.055) - (Gsi Only-2015)
Outside Wall Screen, Stainless Steel (0.094)
Column End Panels
Wet Bin Components, Galvanize - (2015)
Wet Bin Components, Galvanize 2016
Wet Bin Components - No Perf Sides - (Gsi Only-2015)
Ladder, Panel And Hitch, Orange Black 2012 - Front Side - (Ffi Only-2015)
Ladder And Panel, Orange Black 2012 - Rear Side - (Ffi Only-2015)
Ladder, Panel And Hitch, Fdth Ochre Black 2012 - Front Side - (Gsi Only-2015)
Ladder And Panel, Fdth Ochre Black 2012 - Rear Side - (Gsi Only-2015)
Ladder, Panel And Hitch, Ochre Black 2012 - Front Side - (Gsi Only-2015)
Ladder And Panel, Ochre Black 2012 - Rear Side - (Gsi Only-2015)
Ladder, Panel And Hitch, Ochre Black 2016 - Front Side (Gsi Only)
Ladder And Panel, Ochre Black 2016 - Rear Side (Gsi Only)
Ladder, Panel And Hitch, Orange Black 2016 - Front Side - (Ffi Only)
Ladder And Panel, Orange Black 2016 - Rear Side - (Ffi Only)
Grain Inverter, Single Module - (Gsi Only-2017)
Auger And Metering Roll Drive Trains
Bottom Auger And Drive Components - (Ffi Only-2015)
Discharge Assembly - (Ffi Only-2015)
Bottom Auger And Drive Components, 7 Meter Roll, New Discharge - (Gsi Only-2015)
Discharge Assembly, 7 Meter Roll, New Discharge - (Gsi Only-2015)
Bottom Auger And Drive Components, New Discharge - (Ffi Only)
Discharge Assembly, New Discharge - (Ffi Only)
Bottom Auger And Drive Components, New Discharge, 7 Meter Roll - (Gsi Only)
Discharge Assembly, New Discharge, 7 Meter Roll - (Gsi Only)
Bottom Auger And Drive Components, New Discharge - (Gsi Only-2015)
Discharge Assembly, New Discharge - (Gsi Only-2015)
Bottom Auger And Drive Components, New Discharge2016 - (Gsi Only)
Discharge Assembly, New Discharge2016 - (Gsi Only)
Bottom Auger And Drive Components, New Front Discharge - (Gsi Only-2015)
Discharge Assembly, New Front Discharge - (Gsi Only-2015)
Top Auger Assembly, Vision
Top Auger, Vision Black, Front Fill - (Gsi Only)
Top Auger, Vision Black, Without Lift Kit - (2017)
Top Auger Drive Components, 18' Galvanized Wb Och Vis 2016 - (Gsi Only)
Top Auger Drive Components, Wb Dritek + 2012 - (Ffi Only-2015)
Top Auger Drive Components, Wb Gsi 7 Meter Roll - (Gsi Only-2015)
Top Auger Drive Components, Wb Och Vision 2007 - (Gsi Only-2015)
Top Auger Drive Components, Wb Ffi Vision, 7 Meter Roll - (Ffi Only-2016)
Top Auger Drive Components, Galv. Perf. Wb Och Vision, 7 Meter Roll - (Gsi Only-2016)
Fan And Heater
Supply Line, Csa, Lp - (Gsi Only-2015)
Supply Line, Vision, Lp
Supply Line, Vision, Ng - (Gsi Only-2015)
Fan And Heater Housing, 40in, 15hp, 1 Phase, Vision
Heater Burner Assembly, 40in, 15hp, 1 Phase, Vision
Fan And Heater Housing, 40in, 15hp, 1 Phase, Vision - (Gsi Only-2015)
Heater Burner Assembly, 40in, 15hp, 1 Phase, Vision - (Gsi Only-2015)
Fan And Heater Housing, 40in, 15hp, 3 Phase, Vision
Heater Burner Assembly, 40in, 15hp, 3 Phase, Vision
Fan And Heater Housing, 40in, 15hp, 440v, 3 Phase, Vision - (Gsi Only-2015)
Heater Burner Assembly, 40in, 15hp, 440v, 3 Phase, Vision - (Gsi Only-2015)
Fan And Heater Housing, 40in, 15hp, 575v, 3 Phase, Vision Csa 2015 - (Gsi Only-2015)
Heater Burner Assembly, 40in, 15hp, 575v, 3 Phase, Vision Csa 2015 - (Gsi Only-2015)
Moisture Sampler Blower, 220v
Moisture Sampler Blower, 220v, Front Discharge - (Gsi Only-2015)
Moisture Sampler Blower, 220v, Front Fill - (Gsi Only)
Moisture Sampler Blower, 440v - (Gsi Only-2015)
Moisture Sampler Blower, 575v - (Gsi Only-2015)
Auger Drive Motor Assembly, 3hp, 1phase
Auger Drive Motor Assembly, 3hp, 3phase
Auger Drive Motor Assembly, 3hp, 3phase, 575v - (Gsi Only-2015)
Mbc Motor Circuit - 10hp, 1 Phase, Load Aux - (Gsi Only-2015)
Mbc Motor Circuit - 10hp, 1 Phase, Unload Aux - (Gsi Only-2015)
Mbc Motor Circuit - 7.5hp, 3 Phase, Load Aux - (2015)
Mbc Motor Circuit - 7.5hp, 3 Phase, Unload Aux - (2015)
Mbc Motor Circuit - 10hp, 3 Phase, Load Aux, 440v - (Gsi Only-2015)
Mbc Motor Circuit - 10hp, 3 Phase, Unload Aux, 440v - (Gsi Only-2015)
Mbc Motor Circuit - 10hp, 3 Phase, Load Aux, 575v - (Gsi Only-2015)
Mbc Motor Circuit - 10hp, 3 Phase, Unload Aux, 575v - (Gsi Only-2015)
Electrical Package, Tilt Switch Box, Vision, 1 Phase - (Gsi Only)
Electrical Package, Timing Gear, Vision, 1 Phase - (Gsi Only)
Electrical Package, Tilt Switch Box, Vision, 3 Phase, 220v - (Gsi Only)
Electrical Package, Timing Gear, Vision, 3 Phase, 220v - (Gsi Only)
Electrical Package, Tilt Switch Box, Vision, 3 Phase, Csa, 7 Meter Roll - (Gsi Only-2015)
Electrical Package, Timing Gear, Vision, 3 Phase, Csa, 7 Meter Roll - (Gsi Only-2015)
Electrical Package, Tilt Switch Box, Vision, 1 Phase, Csa, 220v, 7 Meter Roll
Electrical Package, Timing Gear, Vision, 1 Phase, Csa, 220v, 7 Meter Roll
Electrical Package, Tilt Switch Box, Vision, 3 Phase, 7 Meter Roll - (Gsi Only-2015)
Electrical Package, Timing Gear, Vision, 3 Phase, 7 Meter Roll - (Gsi Only-2015)
Electrical Package, Tilt Switch Box, Vision, 3 Phase, 208v - (Gsi Only-2016)
Electrical Package, Timing Gear, Vision, 3 Phase, 208v - (Gsi Only-2016)
Electrical Package, Tilt Switch Box, Vision, 3 Phase, 220v, 7 Meter Roll - (2016)
Electrical Package, Timing Gear, Vision, 3 Phase, 220v, 7 Meter Roll - (2016)
Front Fill Option, Vision - (Gsi Only-2017)
Precision Farming Systems
Upper Control Box, Vision, 1 Phase - (Gsi Only-2015)
Lower Control Box, Vision, 1 Phase - (Gsi Only-2015)
Upper Control Box, Vision, 1 Phase, 7.5hp Load Unload - (Gsi Only)
Lower Control Box, Vision, 1 Phase, 7.5hp Load Unload - (Gsi Only)
Upper Control Box, Vision, 1 Phase, 10 Hp Load, 7.5hp Unload - (Gsi Only)
Lower Control Box, Vision, 1 Phase, 10 Hp Load, 7.5hp Unload - (Gsi Only)
Upper Control Box, Vision, 3 Phase, 15 Hp Load, 7.5hp Unload - (Gsi Only)
Lower Control Box, Vision, 3 Phase, 15 Hp Load, 7.5hp Unload - (Gsi Only)
Upper Control Box, Vision Hybrid, 1 Phase, 7 Meter Roll - (Gsi Only-2015)
Lower Control Box, Vision Hybrid, 1 Phase, 7 Meter Roll - (Gsi Only-2015)
Upper Control Box, Vision, 3 Phase, 7 Meter Roll - (Gsi Only-2015)
Lower Control Box, Vision, 3 Phase, 7 Meter Roll - (Gsi Only-2015)
Upper Control Box, Vision, 3 Phase, Csa, 7 Meter Roll - (Gsi Only-2015)
Lower Control Box, Vision, 3 Phase, Csa, 7 Meter Roll - (Gsi Only-2015)
Upper Control Box, Vision Hybrid, 1 Phase, 7 Meter Roll - (Ffi Only-2015)
Lower Control Box, Vision Hybrid, 1 Phase, 7 Meter Roll - (Ffi Only-2015)
Upper Control Box, 3 Phase, 208v, Vision Hybrid, 10hp Load Unload Auxs. - (Gsi Only-2016)
Lower Control Box, 3 Phase, 208v, Vision Hybrid, 10hp Load Unload Auxs. - (Gsi Only-2016)
Upper Control Box, 3 Phase, 230v, Vision Hybrid, 7 Meter Roll, 7.5hp Load 15hp Unload - (Gsi Only-2016)
Lower Control Box, 3 Phase, 230v, Vision Hybrid, 7 Meter Roll, 7.5hp Load 15hp Unload - (Gsi Only-2016)
Upper Control Box, 1 Phase, 220v, Vision Hybrid, 7 Meter Roll, 7.5hp Load Unload - (Ffi Only-2016)
Lower Control Box, 1 Phase, 220v, Vision Hybrid, 7 Meter Roll, 7.5hp Load Unload - (Ffi Only-2016)
Upper Control Box, 3 Phase, 220v, Vision Hybrid, 7 Meter Roll, 10hp Load Unload - (Ffi Only-2016)
Lower Control Box, 3 Phase, 220v, Vision Hybrid, 7 Meter Roll, 10hp Load Unload - (Ffi Only-2016)
Upper Control Box, 1 Phase, 220v, Vision Hybrid, 7.5hp Load Unload - (Gsi Only)
Lower Control Box, 1 Phase, 220v, Vision Hybrid, 7.5hp Load Unload - (Gsi Only)
Upper Control Box, Vision Hybrid, 1 Phase, 220v, 10hp Load Unload - (Gsi Only-2017)
Lower Control Box, Vision Hybrid, 1 Phase, 220v, 10hp Load Unload - (Gsi Only-2017)
Upper Control Box, Vision Hybrid, 1 Phase, 220v, 10hp Load 15hp Unload - (Gsi Only-2017)
Lower Control Box, Vision Hybrid, 1 Phase, 220v, 10hp Load 15hp Unload - (Gsi Only-2017)
Upper Control Box, Vision Hybrid, 1 Phase, 220v, 7.5hp Load Unload, 7 Meter Roll - (Gsi Only-2017)
Lower Control Box, Vision Hybrid, 1 Phase, 220v, 7.5hp Load Unload, 7 Meter Roll - (Gsi Only-2017)
Upper Control Box, Vision Hybrid, 1 Phase, 220v, 7.5hp Load Unload, 7 Meter Roll - (Ffi Only-2017)
Lower Control Box, Vision Hybrid, 1 Phase, 220v, 7.5hp Load Unload, 7 Meter Roll - (Ffi Only-2017)
Decal
Decals - Front - (Gsi Only)
Decals - Rear - (Gsi Only)
Decals - Right Hand Side - (Gsi Only)
Decals - Left Hand Side - (Gsi Only)
Decals - Front Inner - (Gsi Only)
Decal - Front - (Ffi Only)
Decal - Rear - (Ffi Only)
Brand: GSI
Model:
Part Number: 652077
Frame Assembly
Column End Panels
Fan And Heater
Decal
- GSI Agridry Gravity Grain Spreaders Parts Catalog 652169
- GSI Direct Gear Drive Bin Sweep 10” Heavy Duty Parts Catalog 652164
- GSI Direct Gear Drive Bin Sweep 8” And 10” Standard Duty Parts Catalog 652163
- GSI Modular Tower Dryers 1008 Parts Catalog 652289
- GSI Modular Tower Dryers 1010 Parts Catalog 652290
- GSI Modular Tower Dryers 1012 Parts Catalog 652291
- GSI Modular Tower Dryers 1015 Parts Catalog 652292
- GSI Portable Dryer 1108 CFAB190 Parts Catalog 652072
- GSI Portable Dryer 1112 CFAB270 Parts Catalog 652074
- GSI Portable Dryer 1116 CFAB370 Parts Catalog 652073
- GSI Portable Dryer 1118 CFAB400 Parts Catalog 652081
- GSI Portable Dryer 1120 Parts Catalog 652079
- GSI Portable Dryer 1122 Parts Catalog 652084
- GSI Portable Dryer 1126 Parts Catalog 652082
- GSI Portable Dryer 1214 Parts Catalog 652085
