BMW Road Map Europe MOTION EAST & WEST 2017-2 Torrent
USB Instructions:
As MOTION maps update, please keep your car driving around during the update, otherwise update will stop.
1. Please use FAT32 formatted USB drive to install this update.
(8GB or larger)
2. Use WinRAR or 7-Zip to extract BMW Road Map Europe West MOTION 2017-2
3. You will be left a folder called NAVD_00000939_255_004_198 and Instructions.txt (this file)
4. Open NAVD_00000939_255_004_198 folder
5. Copy the config.nfm and pkgdb to
the root of your USB drive
6. Insert the USB stick into the USB port in the Glovebox (the center console will NOT work)
7. Follow the onscreen prompts, it will prompt for the FSC code (see below for information on getting an FSC code)
8. The update will begin to load
9. Wait for it to finish loading the data and you're done!
Notes:
1. Also, some USB drives come with a hidden partition at the front of the drive. Make
sure to go into Disk Management (for Windows) or Disk Utility (OSX) and delete all partitions.
Then recreate a single partition formatted FAT32 (Windows) or FAT (OSX, it's FAT32 by default).
DVD Instructions:
1. Use WinRAR or 7-Zip to extract BMW Road Map Europe West MOTION 2017-2
2. You will be left a folder called NAVD_00000939_255_004_198 and Instructions.txt (this file)
3. Open NAVD_00000939_255_004_198 folder and you'll see config.nfm and pkgdb
4. Burn the config.nfm and pkgdb to a Dual-Layer DVD disc (those two items should be the only thing on the disc)
5. Put Dual-Layer DVD into the DVD slot on the CIC and it should prompt for update.
6. Follow the onscreen prompts, it will prompt for the FSC code (see below for information on getting an FSC code)
7. The update will begin to load
8. Wait for it to finish loading the data and you're done!
USB Instructions:
(8GB or larger)
Notes:
DVD Instructions:
- OPEL GLOBAL TIS V.366.0.FULL TORRENT + Activation Install Instructions
- ATRIS Stahlgruber + Technik [01.2016] Bittorent File
- [Bittorent] Opel EPC 4.25 (10.2014) + Instruction
- Autocom 2015 Release 1 [2015.1] Bittorent
- FORD ETIS (12.2016) on Torrent
- All Hyundai,KIA GDS Multilingual (2010-2016) on torrent
- VIVID WORKSHOPDATA ATI v11.2
- SIMPLO 2019
- [Bit Torrent] Caterpillar SIS 2015-1
- [Bit Torrent] BMW WDS [Wiring Diagram System] 12.3 2009
- TecDoc 4Q2016 FULL Torrent
- [Bit Torrent] DVD Mitsubishi MUT - III (2012) + Service Manuals
- [Bit Torrent] Ford TIS 2004 DVD
- [Bit Torrent] Mercedes DAS,XENTRY 12.2015
- [Bit Torrent] SAAB WIS [01.2013]
