Audi Flashdaten (Flash Disk) [05.03.2018]
Year / Release Date : 2018
Version : 03.2018
Language : English
Tabletka : not required
Description : Firmware for Audi (flashdaten) from 03/05/2018.
Official software updates for vehicle control units. For the convenience of users in the unpacked form
- you can download only the necessary firmware.
For use with VAS-PC and ODIS Engineering.
You can download it on the tracker: VAS PC v19.01.01 RUS + Updates ODIS Engineering 6.6.1 + PostSetup FE + Projects FE ODIS Engineering 6.2.2 + PostSetup + Projects
To work with VAS-PC / ODIS-E, a VAS 505X diagnostic adapter is required. With ODIS-E, you can use the J2534 PassThru interface (Tactrix Open Port 2.0).
There is the possibility of firmware via Vag Can Pro (It uses the same name cable), as well as converting .sgo to ordinary binary files. Through VCDS and the like Vasi-Diagnostics to implement the firmware will not work.
Version : 03.2018
Language : English
- OPEL GLOBAL TIS V.366.0.FULL TORRENT + Activation Install Instructions
- ATRIS Stahlgruber + Technik [01.2016] Bittorent File
- [Bittorent] Opel EPC 4.25 (10.2014) + Instruction
- Autocom 2015 Release 1 [2015.1] Bittorent
- FORD ETIS (12.2016) on Torrent
- All Hyundai,KIA GDS Multilingual (2010-2016) on torrent
- VIVID WORKSHOPDATA ATI v11.2
- SIMPLO 2019
- [Bit Torrent] Caterpillar SIS 2015-1
- [Bit Torrent] BMW WDS [Wiring Diagram System] 12.3 2009
- TecDoc 4Q2016 FULL Torrent
- [Bit Torrent] DVD Mitsubishi MUT - III (2012) + Service Manuals
- [Bit Torrent] Ford TIS 2004 DVD
- [Bit Torrent] Mercedes DAS,XENTRY 12.2015
- [Bit Torrent] SAAB WIS [01.2013]
