VAG Dataflash [06.2018]
VAG dataflash 06.2018
Pass: wordwide-autosoftware-epc
Year : 2018 Version : 18.06 ( 20,011 file)
Developer : VAG encoding on D2
Language : English + Russian
Tabletka : not required
Format : data array
Description : Firmware files for VAG: Audi , Volkswagen , Skoda , SEAT for software : ODIS and VCP (Vag Can Pro) All files you use at your own risk.
Before firmware, it is strongly recommended to consult TPI, which can be downloaded here.
Duplicate files from old databases are replaced by identical ones from the new ones (ie in the release date, not the weight of the file). Respect: The bulk is taken from VAGopedia comrade SanchoPanso998 and AsergeyV materials , and we respect them first! Extras. Information: Update is done by adding new files, do not forget to update the torrent: 1) delete the torrent client and the old download; 2) download a new torrent file and add it to the download; 3) specify the download path to existing folders and files, then not all the volume will be downloaded, but only changes. I ask you not to leave the distribution, i.e. Do not delete the download, do not rename or move files. Thank you!
Format : data array
- OPEL GLOBAL TIS V.366.0.FULL TORRENT + Activation Install Instructions
- ATRIS Stahlgruber + Technik [01.2016] Bittorent File
- [Bittorent] Opel EPC 4.25 (10.2014) + Instruction
- Autocom 2015 Release 1 [2015.1] Bittorent
- FORD ETIS (12.2016) on Torrent
- All Hyundai,KIA GDS Multilingual (2010-2016) on torrent
- VIVID WORKSHOPDATA ATI v11.2
- SIMPLO 2019
- [Bit Torrent] Caterpillar SIS 2015-1
- [Bit Torrent] BMW WDS [Wiring Diagram System] 12.3 2009
- TecDoc 4Q2016 FULL Torrent
- [Bit Torrent] DVD Mitsubishi MUT - III (2012) + Service Manuals
- [Bit Torrent] Ford TIS 2004 DVD
- [Bit Torrent] Mercedes DAS,XENTRY 12.2015
- [Bit Torrent] SAAB WIS [01.2013]
