Toyota Techstream on VAG K+CAN Commander 1.4 or VAG KKL 409.1
FAQ: Toyota Techstream on VAG K+CAN Commander 1.4 or VAG KKL 409.1
Hello all.
I found this on the Russian forum
Unfortunately I do not have Toyota and I do not like this check.
Looks good but n e know whether it is true. Please check.
Installing Techstream
1 Install the program Toyota TechStream, running the file Techstream_Setup_V9.10.037.exe.
2 File C:\Program Files\Toyota Diagnostic\Techstream\Env\IT3System.ini open notepad, find
; Available Function Setting
[AvailableFunction]
MinorFunction = 1
TISFunction = 1
UserFunction = 1
and change TISFunction = 0. This parameter is included with the program mode without technical support official the
techstrima site.
Installing the adapter K-Line (For example VAG-COM 409.1) or VAG K + CAN Commander 1.4
1/ For TechStream adapter KLine (eg VAG-COM) or VAG K + CAN Commander 1.4, you must install the driver USB-COM, from the adapter. Usually, it comes with a disk for the adapter.
2/ Copy the folder J2534KCANv1.0.0.9 of the archive in the folder C: Program FilesToyota DiagnosticsTechstream.
3/ Next, go to the copied folder and run the file j2534KCAN.exe.
4/ In the settings, select the COM-port adapter and type - KLine or VAG K + CAN, and then click "Save" and "Exit".
5/ Run TechStream, in Setup-> VIM Select select "J2534 (04.04) K + CAN Driver".
6/ We useWink
P.S. According to the latest works with chip FT232BQ, FT232RL (such as a trowel or similar). Must also earn an iron com-port adapter and COM-KLine. Adapters chip FT232 is useful to reduce in the driver com port reception with 16ms delay (the default) to 10ms. Other adapters K-Line have not been tested and therefore may be a problem with them.
With some units may be connection problems. Then you must select the settings dTiniL / dTiniH - that is adjusted Fast-pulse. Adjusting the max + -5ms (usually -). Adjusting the settings made ??in the configuration of my driver (j2534KCAN.exe).
For CAN protocol ISO-15765 is possible to adjust the parameters STmin and BS using settings dSTmin and dBS in the configurator. Adjustment is required if there are problems in the exchange of this protocol.
Important zamemchanie!
If you are using Chinese adapters based on the chip FTDI (eg adapter K + CAN Commander 1.4 for this chip)
I recommend to install the driver from the folder J2534KCANv1.0.0.9. The latest official drivers
with the majority of Chinese FTDI chips do not work!
Installing the adapter Mini-VCI (This archive contains all existing versions of drivers for this adapter)
1/ For TechStream adapter Mini-VCI (aka Mongoose, Mangoose and so in general from China) to a folder from the archive MiniVCI
unzip it to drive C.
2/ sticks adapter into an available USB slot and install the drivers on the request specify the path C: MiniVCI? TDI.
3/ After installing the drivers USB-COM (p. Above), you must run the setup.exe file in the folder C: MiniVCI and select one of the
Passthru drivers and click "Select".
4/ Start TechStream, in Setup-> VIM Select select "XHorce - MVCI".
5/ When it is necessary, you can change the version of the driver directly in Passthru TechStream in paragraph VIM clicking the "Detail".
files from mongose and minivci/ mvci32.dll detects a virus themida but I'm not sure if this is definitely a virus. Please bear with us.
Techstream_V9.10.037
http://www.autorepairmanuals.ws/f94/toyota-techstream-v9-10-037-a-20468/
Vag k+can commander info
http://data.autorepairmanuals.ws/27a875bcff1cc3bbcf16fa26359f9aca
Hello all.
[AvailableFunction]
MinorFunction = 1
TISFunction = 1
UserFunction = 1
techstrima site.
6/ We useWink
- DELPHI 2015 Release 3 (Cars and Trucks) + Activation
- Wurth WoW! 5.03 Multilanguage
- Scanxlpro V3.2.1.Patch (Build 1865)
- Wurth WoW! 5.00.8 Multilanguage
- Autocom Delphi 2013 Release 1 (2.13.1) CARS and TRUCK
- Wurth WoW! 5.00.12 Multilanguage
- Autocom, Delphi 2015.3 + KG
- BMW DIS v57 + TIS 12/07 VmWare Link Bittorent
- Software GM MDI 7.14 + Tech2win 1.702 + GM GDS2 Update 28.2.2012 link MF
- AlfaOBD 1.9.2 for Android cracked
- Hyundai/KIA GDS Multilingual (2010-2015) Free on torrent
- Peugeot Planet 2000 v24.99 Multilanguage
- TachoSoft 23.1 added
- Autocom Delphi Software 2.13.2 (2013.2)
- Toyota Techstream 8.20.019 Activation
