SuperSport
Well-Known Member
1
382
#11
So far, I'm not getting Trucks to work. The Main.exe file is patched for cars, but maybe not trucks. I'm still working on it...
dothetwist
New Member
34
#12
Hello,After upgrading 2013/02/02, initialize the software displays message ( Fatal error: Unknown error during init ).
Hi!Same here. Uninstalled previous versions (Delete from program files, Roaming, certificate delete). Installed everything as in first post, and got the fatal error. Did you managed to resolve this issue?Thanks.
SuperSport
Well-Known Member
1
382
#13
Hey guys, I'm still working on it. I can get it to work on my computer just fine (Windows 8 x64), but when I build the installer, it only works on 2 of my 3 computers (works on Win 8 x32, but not on Win 7 x64). I'm currently working on AutoCom 2013.2.2 because it's easier for me to keep the Activation after the 2.2 update. I am able to get it to work with Trucks too.
But, again, I'm having trouble getting my installer to work on ALL computers. Not sure why yet, still trying...
dothetwist
New Member
34
#14
Can confirm this, works from win 8 x64... Strange
SuperSport
Well-Known Member
1
382
#18
Hi!
No, all physical. Win 8 x64 works, Win 7 x64/x86 not.
Thank you, this helps. I'm building my installer in a Windows 8 Machine. Maybe if I try building it on a Windows 7 machine I might get different results. I might even need to create a Win7 and Win8 version for each. Then you just download the one that works.
mesrine_29
6
5,599
#19
Good work.
But you created new installer with different installation Windows or rename your destination path.
Are you source code and building installer?
SuperSport
Well-Known Member
1
382
#20
Good work.
I'm using an Installation Creator and a Patch Creator that modifies the Path Automatically depending on which version of Windows, x32 or x64. The path is not the issue, it appears to be a x32 issue. I'm still working on it.
