SuperSport's Delphi 2013.2.2 Mashup EASY INSTALLER!!! Video Tutorial Included!
Delphi 2013.2.2 MashUp EASY Installer!
NO Manual Activation Needed!
This is my attempt at making my and your lives easier. I've had trouble with getting Delphi/Autocom 2013.2.2 activated, and each time I make a change to my computer, it needs to be activated AGAIN!
With these files, NO NEED to send your XML file for activation. It's automatic on these installers!
Description:
What I've done here is taken the Activated 2013.1.1 'Main.exe' file found in these forums and added the functions, data, drivers, and firmware of 2013.2.2! This allows you to EASILY install the functions and features of 2013.2.2 in TWO EASY steps!
NO Manual Activation Necessary!
Download:
First, download both of the files below. Also download the Key Generator if you need it. (You only need it if your Serial Number is NOT 100251)
SuperSport 2013.1.1 EASY INSTALLER - This installs Delphi 2013.1.1 Super Easily!
SuperSport 2013.2.2 MASHUP - This installs the files and functions of 2013.2.2 and keeps the program ACTIVATED! 12cbkg001 WooHoo!
Delphi/Autocom Keygen - Use this if your serial number is not 100251
Instructions:
1. Double Click the SuperSport Delphi 2013.1.1Installer you downloaded above and follow install instructions. When asked, select product DS150E (new vci). Use all other defaults as they come up. Do not change the install directory.
2. After the First part completes, the second part of the installer will start up (Update + Activator). Be sure to use all the defaults again, and do not change the install directory.
3. Start the program from the DS150E (New VCI) Icon on your desktop. Click the right arrows to get to where it asks for the Serial Number and Hardware Key, use the following:
Serial Number: 100251
Hardware Key: OUQFPFEBUHBK
*If your Serial# is different, see Key Generator Above
Press "Start". The program will Automatically Activate and start for the first time. It will tell you there is an updated program, just ignore this. That is the 2013.2 update that's not included here.
After you've Activated the 2013.1.1 program, close the program.
Now, start the SuperSport 2013.2.2 MashUp program and again, follow the instructions. After this has completed installing, you are finished! Just run the program and ENJOY 2013.2.2!
Let me know if you have any trouble using this. *Also, if your CDP+ has a different serial number, use the Key Generator above to get your Hardware Key.
Video Tutorials Will be here when completed...
Install 2013.1.1
Install 2013.1.1
- Delphi/AuTocom 2013.2 with update 1 [Activation, CDP, CDP+,ADP186,SDP]
- Mitchell OnDemand 2015 + Mitchell Manager Torrent
- Autocom/delphi 2013.1 Full
- AutoCom/Delphi 2013.3 Activator!!!! Also Including My Delphi 2013.3 Super Easy Installer by SuperS
- Delphi/Autocom 2013.R3 How to install
- Autocom & Delphi 2013 R1 Activator patch Works Fine
- Autocom 2013 R2 Full
- TachoSoft Mileag Calculator 25.9 - 2016 full
- Autocom CDP 2013.R1 FULL
- KG Vivid Workshop DATA ATI v.10.2 + Instruction
- Autocom CDP+ Delphi 2014.Release 1 Update Full
- DELPHI DIAMAND [02.2016]
- Delphi><Autocom Keygen 2013.3 Xml file activator
- Autocom - Delphi 2012.3 Full
- NYO4 calculator Torrent
