Hyundai
Driver
17
61,686
Steyr Motors Marine Engine SE144E38 Spare Parts Catalogue
Brand: Steyr Motors
Type of Machine: Marine Engine
Type of Manual: Spare Parts Catalogue
Model: Steyr Motors SE144E38 Marine Engine
Part Number: 500247
Serial Number: 482350378 and up
Date: 2021
Number of Pages: 113 Pages
MOUNT BRACKET, BELT GUARD, GASKET SET
CRANKCASE
CRANKSHAFT, BEARING, DAMPER
FLYWHEEL, FLYWHEELHOUSING
PISTON, RINGS AND PIN, CONNECTION ROD
CAMSHAFT HOUSING
OILPAN, OIL DIPSTICK
OIL PUMP, SUPPORT RING
OIL SEPARATOR, BLOWBY LINES
OIL COOLER, OILFILTER, OIL LINES
INTERCOOLER
POWER TAKE OFF FRONT
EXHAUST, HEAT EXCHANGER, GASKETS
TORSIONAL COUPLING
COUPLER
FUEL PUMP, UNIT INJECTOR, PIPE
AIRFILTER, INVERSIONVALVE SOLAS
TURBO
CONTR.SOLENOID, INJ. TIMING DEVICE
FUEL FILTER
GLOW PIN
POTENTIOMETER ACCELERATOR
HIGH RISER, EXHAUSTPIPE
WATERPIPE
WATERPUMP
DRIVE BELTS, PULLEYS, TENSIONER
RAW WATER PUMP
RAW WATER PIPES
ALTERNATOR
STARTER
ENGINE HARNESS
SECURITYSYSTEM, FUSES, ECU, E- BOX
INSTRUMENT PANEL
INSTRUMENT PANEL SOLAS
SCC-DISPLAY (STEYR CONTROL CENTER)
SCC KEY IGNITION PANEL
SCC PUSH BUTTON IGNITION PANEL
EXTENSION CABLE INSTRUMENTS
TRANSMISSION, BRACKETS, PIPES
TRANSMISSION SHAFT, PTO SHAFT (ALU)
DRIVE ADAPTOR VOLVO STERNDRIVE
DRIVE SHAFT EXT. MERCURY STERNDRIVE
HYDRAULIC PUMP
HYDRAULIC PIPES
ENGINE PREHEATING
INTEGR. FLYWHEELGENERATOR (IFG)
IFG PUSH BUTTON PANEL
HYBRID STAGE I
OIL SUCTION PUMP
CABIN HEATER, CIRCULATION PUMP
OPERATING MATERIAL
