Steyr Motors Marine Engine MO94K43 Spare Parts Catalogue
Brand: Steyr Motors
Type of Machine: Marine Turbo Diesel Engine
Type of Manual: Spare Parts Catalogue
Model: Steyr Motors MO94K43 Marine Turbo Diesel Engine
Part Number: Z001023-0
Serial Number: 48217 001 and up
Date: 2018
Number of Pages: 133 Pages
MOUNT BRACKET, LIFTING EYE, GASKET SET
CRANKCASE
CRANKSHAFT, BEARING, DAMPER
FLYWHEEL, FLYWHEEL HOUSING
PISTON, RINGS AND PIN, CONNECTION ROD
CAMSHAFT, CAMSHAFT HOUSING
OILPUMP, OILPIPE, OILPAN
INTERCOOLER
POWER TAKE OFF FRONT
OILCOOLER
EXHAUST -->482341169
EXHAUST 482341170-->
COUPLER
FUEL PUMP, UNIT INJECTOR, PIPE
AIRFILTER
TURBO
CONTR. SOLENOID, POTENTIOMETER
FUEL FILTER
GLOW PLUG
POT. ACCELER., BOOST PRESSURE SENSOR
HIGH RISER, EXHAUST PIPE
WATER PIPE, THERMOSTAT
WATER PUMP
DRIVE BELTS, PULLEYS, TENSIONER
RAW WATER PUMP
RAW WATER PIPES, FUEL-OIL COOLER
ALTERNATOR
STARTER
ENGINE HARNESS 48221067 --> 48226999
ENGINE HARNESS 48227001-->
SECURETY SYSTEM, ECU, E-BOX
INSTR. PANEL STANDARD TILL 2010
INSTR. PANEL STANDARD 2013/08-->
INSTR
INSTR. PANEL SOLAS 2010-2013/08
INSTR. PANEL SOLAS 2013/08-->
DISPLAY (ACCESSORY)
SWITCH PANEL FOR DISPLAY TILL 2010
SWITCH PANEL FOR DISPLAY FROM 2010
PUSH BUTTON PANEL FOR DISPLAY TILL 2010
PANEL
EXTENSION CABLE INSTR. (ACCESSORY)
TRANSMISS., MOUNTING BRACKETS, PIPES
TRANSMISSION-SHAFT, PTO-SHAFT (ALU)
HYDRAULIC PUMP
HYDRAULIC PIPES
ENGINE PREHEATING
INTEGR. FLYWHEEL GENERATOR (IFG)
PUSH BUTTON PANEL "IFG" TILL 2010
PUSH BUTTON PANEL "IFG" FROM 2010
HYBRID
OIL SUCTION PUMP
HEATING UNIT, CIRCULATION PUMP
GENERAL OPERATING MATERIAL
Brand: Steyr Motors
Date: 2018
CRANKCASE
INTERCOOLER
OILCOOLER
COUPLER
AIRFILTER
TURBO
FUEL FILTER
GLOW PLUG
WATER PUMP
RAW WATER PUMP
ALTERNATOR
STARTER
INSTR
DISPLAY (ACCESSORY)
PANEL
HYDRAULIC PUMP
HYDRAULIC PIPES
ENGINE PREHEATING
HYBRID
OIL SUCTION PUMP
- Steyr Motors Marine Diesel Engine Spare Parts Catalogue
- Steyr Motors Marine Engine MO84K32 Spare Parts Catalogue
- Steyr Motors Marine Engine MO114K33 Spare Parts Catalogue
- Steyr Motors Marine Engine MO126K25 Spare Parts Catalogue
- Steyr Motors Marine Engine MO126M28 Spare Parts Catalogue
- Steyr Motors Marine Engine MO144V38 MO144M38 Spare Parts Catalogue
- Steyr Motors Marine Engine MO156K25 Spare Parts Catalogue
- Steyr Motors Marine Engine MO164M40 Spare Parts Catalogue
- Steyr Motors Marine Engine MO166K28 Spare Parts Catalogue EN DE
- Steyr Motors Marine Engine MO166M28 Spare Parts Catalogue
- Steyr Motors Marine Engine MO174V40 Spare Parts Catalogue
- Steyr Motors Marine Engine MO196K35 Spare Parts Catalogue
- Steyr Motors Marine Engine MO236FDE Spare Parts Catalogue EN DE
- Steyr Motors Marine Engine MO236K42 Spare Parts Catalogue
- Steyr Motors Marine Engine MO236K43 Spare Parts Catalogue EN DE
