Guest viewing is limited
Hyundai
Driver
17
61,911
Steyr Motors Marine Engine MO236K43 Spare Parts Catalogue EN DE
Language: English, German
Brand: Steyr Motors
Type of Machine: Marine Turbo Diesel Engine
Type of Manual: Spare Parts Catalogue
Model: Steyr Motors MO236K43 Marine Turbo Diesel Engine
Part Number: Z011796/1
Serial Number: 68 218 000 to 68 226 999
Date: 2007
Number of Pages: 185 Pages
MOUNT BRACKET, LIFTING EYE, GASKET SET
CRANKCASE > 68224399
CRANKCASE 68224400 >
CRANKSHAFT, BEARING, DAMPER
FLYWHEEL, FLYWHEELHOUSING
PISTON, RINGS AND PIN, CONNECTION ROD
CAMSHAFT, HOUSING > 68224399
CAMSHAFT, HOUSING 68224400 >
OILPUMP, OILPIPE, OILPAN,OIL DIPSTICK
INTERCOOLER
POWER TAKE OFF FRONT
OILCOOLER
EXHAUST, HEAT EXCHANGER, GASKET
COUPLER
COUPLER
FUEL PUMP, UNIT INJECTOR, PIPE
AIRFILTER > 68219174
AIRFILTER 68219175 >
AIRFILTER 68226173>68226999
TURBOCHARGER
CONTR. SOLENOID, POTENTIOMETER
FUEL FILTER
GLOW PIN
REM.CONTR POTENTIOM., BOOST PRESS. SENSOR
HIGH RISER, EXHAUSTPIPE
WATERPIPE, THERMOSTAT > 68225170
WATERPIPE, THERMOSTAT 68225171 >
WATERPUMP
RAW WATER PUMP BESIDE >68222237
FUEL
CENTRIFUGAL RAW WATER PUMPSPEZIAL-OPTION
ALTERNATOR 14V / 90A
ALTERNATOR - STANDARD 14V / 90A 68224419 >
ALTERNATOR 28V / 80A (OPTIONAL)
ALTERNATOR 28V / 55A (OPTIONAL)
ALTERNATOR 24V / 55A DOUBLE (OPTION)
STARTING MOTOR > 68224399
STARTING MOTOR 68224400 >
ENGINE HARNESS >68221158
ENGINE HARNESS 68221159 >
SECURETYSYSTEM, FUSES, EMS, E-BOX > 68221158
SECURETYSYSTEM, FUSES, EMS, E-BOX 68221159 >
INSTRUMENTPANEL (STANDARD)
INSTRUMENTPANEL SOLAS (STANDARD)
INSTRUMENTPANEL SOLAS 24V
DISPLAY (ACCSESSORY)
SWITCH PANEL FOR DISPLAY (ACCSESSORY)
PUSH BUTTON PANEL SOLAS FOR DISPAY (AY)
EXTENSION CABLE INSTRUMENTS (ACCESSORY)
TRANSM., CASE, MOUNTINGBRACKETS, FILLER PIPES
Transm.-shafts, Bearings, Power-take-off shaft (STEEL)
Transm.-shafts, Bearings, Power-take-off shaft (ALU)
TRANSMISSION, Gear shift, Vacuum booster and controls
DRIVE ADAPTOR VOLVO STERNDRIVE
DRIVE SHAFT EXTENSIONMERCURY STERNDRIVE
HYDRAULIC PUMP
HYDRAULIC PIPES
ENGINE PREHEATING (ACCSESSORY)
INTEGR. FLYWHEELGENERATOR (IFG)
PUSH BUTTON PANEL „IFG“
HEATING UNIT, CIRCULATION PUMP (ACCSESSORY)
