Hyundai
Driver
17
61,911
Steyr Motors Marine Engine MO84K32 Spare Parts Catalogue
Brand: Steyr Motors
Type of Machine: Marine Turbo Diesel Engine
Type of Manual: Spare Parts Catalogue
Model: Steyr Motors MO84K32 Marine Turbo Diesel Engine
Part Number: Z001025-0
Serial Number: 48227 001 and up
Date: 2014
Number of Pages: 119 Pages
MOUNT BRACKET, LIFTING EYE, GASKET SET
CRANKCASE
CRANKSHAFT, BEARING, DAMPER
FLYWHEEL, FLYWHEELHOUSING
PISTON, RINGS AND PIN, CONNECTION ROD
CAMSHAFT, HOUSING
OILPUMP, OILPIPE, OILPAN
INTAKE MANIFOLD
POWER TAKE OFF FRONT
OILCOOLER
EXHAUST, HEAT EXCHANGER, GASKET
COUPLER
FUEL PUMP, UNIT INJECTOR, PIPE
AIRFILTER
TURBO
CONTR. SOLENOID, POTENTIOMETER
FUEL FILTER
GLOW PIN
POT. ACCELE., BOOST PRESSURE SENSOR
HIGH RISER, EXHAUSTPIPE
WATERPIPE, THERMOSTAT
WATERPUMP
DRIVE BELTS, PULLEYS, TENSIONER
RAW WATER PUMP
RAW WATER PIPES, FUEL-OIL COOLER
ALTERNATOR
STARTING
ENGINE HARNESS
SECURETYSYSTEM, FUSES, ECU, E-BOX
INSTRUMENT PANEL (STANDARD)
INSTRUMENT PANEL SOLAS (STANDARD)
DISPLAY
SWITCH
SWITCH PANEL FOR DISPLAY
PUSH BUTTON PANEL SOLAS FOR DISPLAY
EXTENSION CABLE INSTRUMENTS
TRANSMISS., MOUNTING BRACKETS, PIPES
TRANSMISSION-SHAFT, PTO-SHAFT (ALU)
HYDRAULIC PUMP
HYDRAULIC PIPES
ENGINE PREHEATING
INTEGR. FLYWHEELGENERATOR (IFG)
PUSH BUTTON PANEL „IFG“
HYBRID
HEATING UNIT, CIRCULATION PUMP
