Steyr Motors Marine Engine MO166M28 Spare Parts Catalogue
Brand: Steyr Motors
Type of Machine: Marine Turbo Diesel Engine
Type of Manual: Spare Parts Catalogue
Model: Steyr Motors MO166M28 Marine Turbo Diesel Engine
Part Number: Z011797-0
Serial Number: 68227001 and up
Date: 2009
Number of Pages: 115 Pages
MOUNT BRACKET, LIFTING EYE, GASKET SET
CRANKCASE
CRANKSHAFT, BEARING, DAMPER
FLYWHEEL, FLYWHEELHOUSING
PISTON, RINGS AND PIN, CONNECTION ROD
CAMSHAFT, HOUSING
OILPUMP, OILPIPE, OILPAN, OIL DIPSTICK
INTERCOOLER
POWER TAKE OFF FRONT
OILCOOLER , OILFILTER, OILHOSES
EXHAUST, HEAT EXCHANGER, GASKET
TORSIONAL COUPLING
COUPLER
FUEL PUMP, UNIT INJECTOR, PIPE
AIRFILTER, INVERSION VALVE SOLAS
TURBOCHARGER
CONTR. SOLENOID, SENSOR CONTR. RACK POS.
FUEL FILTER
GLOW PIN
POTENTIOMETER ACCELERATOR
HIGH RISER, EXHAUSTPIPE
WATERPIPE, THERMOSTAT
WATERPUMP
RAW WATER PUMP
RAW WATER PIPES, FUEL-HYDR. OIL COOLER
CENTRIFUGAL RAW WATER PUMP
ALTERNATOR - STANDARD 14V / 90A
ALTERNATOR 28V / 80A
ALTERNATOR 28V / 55A
STARTING MOTOR
ENGINE HARNESS
SECURETYSYSTEM, FUSES, ECU, E-BOX
INSTRUMENTPANEL (STANDARD)
INSTRUMENTPANEL SOLAS (STANDARD)
INSTRUMENTPANEL SOLAS 24V
SCC - DISPLAY
SWITCH PANEL FOR DISPLAY
PUSH BUTTON PANEL SOLAS FOR DISPLAY
EXTENSION CABLE INSTRUMENTS
TRANSMISS., MOUNTING BRACKETS, PIPES
TRANSMISSION-SHAFT, PTO-SHAFT (ALU)
DRIVE ADAPTOR VOLVO STERNDRIVE
DRIVE SHAFT EXT. MERCURY STERNDRIVE
HYDRAULIC PUMP
HYDRAULIC PIPES
ENGINE PREHEATING
INTEGR. FLYWHEELGENERATOR (IFG)
PUSH BUTTON PANEL „IFG“
HEATING UNIT, CIRCULATION PUMP
Brand: Steyr Motors
Date: 2009
CRANKCASE
CAMSHAFT, HOUSING
INTERCOOLER
TORSIONAL COUPLING
COUPLER
TURBOCHARGER
FUEL FILTER
GLOW PIN
WATERPUMP
RAW WATER PUMP
STARTING MOTOR
ENGINE HARNESS
SCC - DISPLAY
HYDRAULIC PUMP
HYDRAULIC PIPES
ENGINE PREHEATING
- Steyr Motors Marine Diesel Engine Spare Parts Catalogue
- Steyr Motors Marine Engine MO84K32 Spare Parts Catalogue
- Steyr Motors Marine Engine MO94K43 Spare Parts Catalogue
- Steyr Motors Marine Engine MO114K33 Spare Parts Catalogue
- Steyr Motors Marine Engine MO126K25 Spare Parts Catalogue
- Steyr Motors Marine Engine MO126M28 Spare Parts Catalogue
- Steyr Motors Marine Engine MO144V38 MO144M38 Spare Parts Catalogue
- Steyr Motors Marine Engine MO156K25 Spare Parts Catalogue
- Steyr Motors Marine Engine MO164M40 Spare Parts Catalogue
- Steyr Motors Marine Engine MO166K28 Spare Parts Catalogue EN DE
- Steyr Motors Marine Engine MO174V40 Spare Parts Catalogue
- Steyr Motors Marine Engine MO196K35 Spare Parts Catalogue
- Steyr Motors Marine Engine MO236FDE Spare Parts Catalogue EN DE
- Steyr Motors Marine Engine MO236K42 Spare Parts Catalogue
- Steyr Motors Marine Engine MO236K43 Spare Parts Catalogue EN DE
