Steyr Motors Marine Engine MO166K28 Spare Parts Catalogue EN DE
Language: English, German
Brand: Steyr Motors
Type of Machine: Marine Turbo Diesel Engine
Type of Manual: Spare Parts Catalogue
Model: Steyr Motors MO166K28 Marine Turbo Diesel Engine
Part Number: Z011796/1
Serial Number: 68 218 000 to 68 226 999
Date: 2007
Number of Pages: 185 Pages
MOUNT BRACKET, LIFTING EYE, GASKET SET
CRANKCASE > 68224399
CRANKCASE 68224400 >
CRANKSHAFT, BEARING, DAMPER
FLYWHEEL, FLYWHEELHOUSING
PISTON, RINGS AND PIN, CONNECTION ROD
CAMSHAFT, HOUSING > 68224399
CAMSHAFT, HOUSING 68224400 >
OILPUMP, OILPIPE, OILPAN,OIL DIPSTICK
INTERCOOLER
POWER TAKE OFF FRONT
OILCOOLER
EXHAUST, HEAT EXCHANGER, GASKET
COUPLER
COUPLER
FUEL PUMP, UNIT INJECTOR, PIPE
AIRFILTER > 68219174
AIRFILTER 68219175 >
AIRFILTER 68226173>68226999
TURBOCHARGER
CONTR. SOLENOID, POTENTIOMETER
FUEL FILTER
GLOW PIN
REM.CONTR POTENTIOM., BOOST PRESS. SENSOR
HIGH RISER, EXHAUSTPIPE
WATERPIPE, THERMOSTAT > 68225170
WATERPIPE, THERMOSTAT 68225171 >
WATERPUMP
RAW WATER PUMP BESIDE >68222237
SEAWATERPIPES, FUEL-HYDRAULICOILCOOLER
CENTRIFUGAL RAW WATER PUMPSPEZIAL-OPTION
ALTERNATOR 14V / 90A
ALTERNATOR - STANDARD 14V / 90A 68224419 >
ALTERNATOR 28V / 80A (OPTIONAL)
ALTERNATOR 28V / 55A (OPTIONAL)
ALTERNATOR 24V / 55A DOUBLE (OPTION)
STARTING MOTOR > 68224399
STARTING MOTOR 68224400 >
ENGINE HARNESS >68221158
ENGINE HARNESS 68221159 >
SECURETYSYSTEM, FUSES, EMS, E-BOX > 68221158
FUSES
INSTRUMENTPANEL (STANDARD)
INSTRUMENTPANEL SOLAS (STANDARD)
INSTRUMENTPANEL SOLAS 24V
DISPLAY (ACCSESSORY)
SWITCH PANEL FOR DISPLAY (ACCSESSORY)
PUSH BUTTON PANEL SOLAS FOR DISPAY (AY)
EXTENSION CABLE INSTRUMENTS (ACCESSORY)
TRANSM., CASE, MOUNTINGBRACKETS, FILLER PIPES
Transm.-shafts, Bearings, Power-take-off shaft (STEEL)
Transm.-shafts, Bearings, Power-take-off shaft (ALU)
TRANSMISSION, Gear shift, Vacuum booster and controls
DRIVE ADAPTOR VOLVO STERNDRIVE
DRIVE SHAFT EXTENSIONMERCURY STERNDRIVE
HYDRAULIC PUMP
HYDRAULIC PIPES
ENGINE PREHEATING (ACCSESSORY)
INTEGR. FLYWHEELGENERATOR (IFG)
PUSH BUTTON PANEL „IFG“
HEATING UNIT, CIRCULATION PUMP (ACCSESSORY)
Brand: Steyr Motors
Date: 2007
INTERCOOLER
OILCOOLER
COUPLER
COUPLER
TURBOCHARGER
FUEL FILTER
GLOW PIN
WATERPUMP
FUSES
HYDRAULIC PUMP
HYDRAULIC PIPES
- Steyr Motors Marine Diesel Engine Spare Parts Catalogue
- Steyr Motors Marine Engine MO84K32 Spare Parts Catalogue
- Steyr Motors Marine Engine MO94K43 Spare Parts Catalogue
- Steyr Motors Marine Engine MO114K33 Spare Parts Catalogue
- Steyr Motors Marine Engine MO126K25 Spare Parts Catalogue
- Steyr Motors Marine Engine MO126M28 Spare Parts Catalogue
- Steyr Motors Marine Engine MO144V38 MO144M38 Spare Parts Catalogue
- Steyr Motors Marine Engine MO156K25 Spare Parts Catalogue
- Steyr Motors Marine Engine MO164M40 Spare Parts Catalogue
- Steyr Motors Marine Engine MO166M28 Spare Parts Catalogue
- Steyr Motors Marine Engine MO174V40 Spare Parts Catalogue
- Steyr Motors Marine Engine MO196K35 Spare Parts Catalogue
- Steyr Motors Marine Engine MO236FDE Spare Parts Catalogue EN DE
- Steyr Motors Marine Engine MO236K42 Spare Parts Catalogue
- Steyr Motors Marine Engine MO236K43 Spare Parts Catalogue EN DE
