Sany All Terrain Crane SAC3000C8 Operation and Maintenance Manual 2024
Brand: Sany
Type of Machine: All Terrain Crane
Type of Manual: Operation and Maintenance Manual
Model: Sany SAC3000C8 All Terrain Crane
Publication Date: 2024
Number of Pages: 750 Pages
1 Introduction
Brand: Sany
1 Introduction
1.1 Overview of Crane
1.1.1 General Instruction of Crane
1.1.2 Overview of Carrier
1.1.3 Description of Carrier
1.1.4 Overview of Superstructure
1.1.5 Description of Superstructure
1.1.6 Optional Equipment*
1.1.7 Description of Auxilary Equipment
1.1.8 Data Logger
1.2 Overview of Documentation
1.2.1 General Instruction of Documentation
1.2.2 General Instruction of SOM Manual
1.2.3 Overview of the SOM Manual
1.2.4 Symbols in the Manual
1.2.5 Terminology and Abbreviation
1.2.6 Units in the Manual
1.3 Identifications on the Crane
1.3.1 Identifications of the Crane
1.3.2 Identifications of the Components
1.4 CE Certification
1.5 Correction Request Form for the Manual
1.6 Service Form for the Crane
2 Safety2.1 General Instruction of Safety
2.2 Intended Use of the Crane
2.3 Non-approved Use of the Crane
2.4 Responsibilities and Personnel Requirements
2.4.1 Responsibilities of Manufacturer-Sany
2.4.2 Responsibilities of Supervisor
2.4.3 Responsibilities of Crane Owner and Authorized Personnel
2.4.4 Responsibilities of Crane Operator
2.4.5 Personnel Requirements
2.5 General Safety Instructions
2.5.1 Requirements for Breaking-in New Crane
2.5.2 California Proposition 65 Warning
2.5.3 Hand Signals for Guidance
2.5.4 Personal Protective Equipment
2.5.5 Aids for Work at Height
2.5.6 Fire Extinguisher
2.6 Safety Instructions of Crane
2.6.1 Danger on the Crane
2.6.2 Safety Decals on the Crane
2.6.3 Danger Zone of Crane
2.6.4 Emergency Exit of Crane
2.6.5 Grounding for Potential Equalization
2.6.6 Movement on the crane
2.6.7 Safety Instructions in Case of an External Power Supply
2.7 Safety Instructions for Transport
2.8 Safety Instructions for Travel
2.8.1 Traffic Regulations
2.8.2 General Safety for Travel
2.8.3 Safety for Travel Operation
2.8.4 Triangle Warning Sign
2.9 Worksite and Environment Requirements
2.9.1 Worksite Requirements
2.9.2 Altitude Requirements
2.9.3 Weather Requirements
2.9.4 Ground Requirements
2.10 Safety Instructions for Crane Operation
2.10.1 Technical Safety Instructions
2.10.2 Safety for Crane Operation
2.10.3 Safety Instructions for Support
2.10.4 Safety Instructions for Fastening
2.10.5 Work at Low Temperatures
2.10.6 Work in the Vicinity of Electric Source
2.10.7 Work in case of Bad Environments
2.10.8 Work in Sunshine
2.10.9 Work at Night
2.11 Safety Instructions for Maintenance
2.12 Safety Devices
2.12.1 Overview of the Safety Device
2.12.2 Turntable Locking Device
2.12.3 Battery Connect Switch
2.12.4 Emergency Stop Button
2.12.5 Tricolor Warning Light
2.12.6 Third Wrap Protector
2.12.7 Anti-two Block (A2B) Switch
2.12.8 Secondary Override Key Switch
2.12.9 Warning Light
2.12.10 Anemometer* and Aircraft Warning Light*
2.12.11 Load Moment Indicator Monitor (LMI)
2.12.12 Camera System
3 System Function3.1 Operating and Monitoring Instruments in the Driver's Cab
3.1.1 Overview of Driver's Cab
3.1.2 Combination Instrument
3.1.3 Infotainment Display
3.1.4 Switches
3.1.5 Rocker Switches
3.1.6 Multipurpose Switch
3.1.7 Steering Clusters
3.1.8 Ignition Switch
3.1.9 Cigarette Lighter
3.1.10 Climate Control System
3.1.11 Overview of Driver's Seat
3.2 Operating and Monitoring Instruments in the Operator‘s Cab
3.2.1 Overview of Operator's Cab_312
3.2.2 Superstructure Display
3.2.3 Auxiliary Control Panel
3.2.4 Joystick
3.2.5 Cigarette Lighter
3.2.6 Overview of Operator’s Seat
3.3 Remote Control Device
3.3.1 Smartkey
3.3.2 Remote Control
3.3.3 Remote Control Charger
4 Operation4.1 Safety Instructions for the Crane Operation
4.2 Terms and Definitions of the Crane Operation
4.3 Crane Operation Planning
4.4 Crane Accesses
4.4.1 Superstructure - Climb Up or Down
4.4.2 Walking Surfaces and Stepping Surfaces
4.4.3 Operator's Cab - Enter and Exit
4.5 Inspection before Travel
4.5.1 General Instruction of Inspection
4.5.2 Engine
4.5.3 Transmission Oil
4.5.4 Hydraulic Oil
4.5.5 Coolant
4.5.6 Windshield Fluid
4.5.7 Tires
4.5.8 Fuel Level-Check
4.5.9 Engine Oil
4.5.10 Adblue (DEF)*
4.5.11 Diesel Particle Filter (DPF)
4.5.12 Operating Instruments
4.5.13 Travel Condition
4.6 Before Travel
4.6.1 Steering Wheel - Adjust
4.6.2 Safety belt – Fasten
4.6.3 Driver's Seat -Adjust
4.6.4 Rearview Mirrors - Adjust
4.6.5 Climate Control
4.7 Operation of Engine
4.7.1 Battery Connect Switch
4.7.2 Engine - Start / Stop (with ignition switch in driver's cab)
4.8 Operation of Travel
4.8.1 Travel Displays
4.8.2 Transmission
4.8.3 Axle Suspension
4.8.4 Differential Locks
4.8.5 Steering
4.8.6 Lights Control
4.8.7 Horn
4.8.8 Window Wiper System
4.8.9 Brake
4.8.10 Ending Driving
4.9 Before Lifting
4.9.1 Operator’s Seat Adjustment
4.9.2 Inspection and Test before Lifting
4.10 Operation of Outriggers
4.10.1 Overview of Outriggers Assembly
4.10.2 Precautions for Outriggers Operation
4.10.3 Outrigger Floats
4.10.4 Outrigger Pins
4.10.5 Outrigger Lights
4.10.6 Outriggers - Extend (with remote control)
4.10.7 Outriggers - Retract (with remote control)
4.10.8 Outriggers - Align(with remote control)
4.11 Operation of Lifting
4.11.1 Slewing System
4.11.2 Luffing System
4.11.3 Boom Telescoping System
4.11.4 Hoisting System
4.12 Crane and Components Transport
4.12.1 Crane - Lift
4.12.2 Transporting the Crane
4.12.3 Short Distance Transport
4.13 Storage of the Crane
4.13.1 Short-term Storage
4.13.2 Long-term Storage
5 Equipment5.1 General Instructions for Assembly and Disassembly
5.1.1 Safety Instructions for Assembly and Disassembly
5.1.2 Assembling/Disassembling of Hydraulic Lines
5.1.3 Assembling/Disassembling of Electrical Lines
5.2 Jib
5.2.1 Jib Combinations
5.2.2 Fastening Points of Jib
5.2.3 Pins
5.2.4 Fixed Jib - Assemble
5.2.5 Fixed Jib - Disassemble
5.2.6 Jib - Reeve
5.2.7 Offset Angle - Adjust
5.2.8 Fixed Jib - Erect
5.2.9 Fixed Jib - Lay Down
5.3 Reeving Plan
5.3.1 General Instruction of Parts of Line
5.3.2 Parts of Line
5.4 Rope Reeving
5.4.1 Overview of the Reeving Parts
5.4.2 Hoist Drum
5.4.3 Wire Ropes and Rope End Connections
5.4.4 Hoist Rope Grab
5.4.5 Guide sheaves
5.4.6 Rope Lock
5.4.7 Overview of the A2B Assembly
5.4.8 Anti-two Block (A2B) Assembly
5.4.9 Hook Block
5.4.10 Auxiliary Hook
5.5 Counterweight
5.5.1 Overview of Counterweight
5.5.2 Counterweight Combinations
5.5.3 Fastening Points of Counterweight Bracket
5.5.4 Safety Instruction for Counterweight Operation
5.5.5 Counterweight - Install
5.5.6 Counterweight - Remove
5.6 Superlift
5.6.1 Overview of Superlift
5.6.2 Lifting Points of Superlift
5.6.3 Safety Instructions for Superlift Operation
5.6.4 Superlift - Assemble
5.6.5 Superlift - Disassemble
5.6.6 Assemble the Superlift on the Transport Device
5.7 Outrigger Pads Support
5.7.1 Precautions for Outrigger Pads Support Operation
5.7.2 Outrigger Pads Support - Use
6 Inspection and Maintenance6.1 General Instructions for the Crane Maintenance
6.2 Safety Instructions for Inspection and Maintenance
6.2.1 General Safety Instructions
6.2.2 Securing against Starting
6.2.3 Securing against Falling
6.2.4 Precaution against Fire
6.2.5 Defending against Burns
6.2.6 Defending against Scalding
6.2.7 Rotating Parts
6.2.8 Using Permissible Service Fluids
6.2.9 Defending against the Hazards of Service Fluids
6.2.10 Replacing Damaged Crane Components
6.3 Taking Care of the Crane
6.3.1 Washing the Crane
6.3.2 High Pressure Cleaner
6.4 Recommendation for Safe Disposal
6.4.1 Service Fluids and Lubricants
6.4.2 Batteries
6.4.3 Disposing of the Machine
6.5 Preparation before Maintenance
6.5.1 Read the Hours and Odometers
6.5.2 Secure the Crane for Maintenance
6.5.3 Tightening Torques
6.5.4 Lubricants and Fluids
6.6 Maintenance and Inspection Schedule
6.6.1 General Instruction of the Maintenance Interval
6.6.2 Maintenance and Inspection Schedule for SAC
6.7 Maintenance Tasks - Carrier
6.7.1 Power Train - Carrier
6.7.2 Axles and Suspension
6.7.3 Wheels and Tires
6.7.4 Steering System
6.7.5 Driveline
6.7.6 Brake System
6.7.7 Transmission
6.7.8 Transfer Case
6.7.9 Electrical System
6.7.10 Hydraulic System
6.7.11 Air Conditioner
6.7.12 Outriggers
6.7.13 Other Maintenance Work
6.8 Maintenance Tasks - Superstructure
6.8.1 Power Train - Superstructure
6.8.2 Ropes
6.8.3 Hook
6.8.4 Telescopic Boom and Jib
6.8.5 Central Lubrication System
6.8.6 Slewing Mechanism
6.8.7 Hoisting Mechanism
6.8.8 Hydraulic System
6.8.9 Electrical System
6.8.10 Air Conditioner
6.8.11 Other Maintenance Work
7 Troubleshooting7.1 Emergency Stop Switch
7.2 Emergency Operations - Carrier
7.2.1 Malfunctions during Crane Driving
7.2.2 Engine - Jump-start
7.2.3 Crane - Tow
7.3 Emergency Operations - Superstructure
7.3.1 Malfunctions during Crane Operation
7.4 Troubleshooting - Carrier
7.4.1 Engine Malfunctions
7.4.2 Transmission Malfunctions
7.4.3 Brake Malfunctions
7.4.4 Steering Malfunctions
7.4.5 Outrigger Malfunctions
7.4.6 Mechanical Malfunctions
7.4.7 Hydraulic System Malfunctions
7.4.8 Electrical System Malfunctions- Crane Carrier
7.5 Troubleshooting - Superstructure
7.5.1 Mechanical System Malfunctions - Superstructure
7.5.2 Hydraulic System Malfunctions
7.5.3 Counterweight Malfunctions
7.5.4 Malfunctions during Tilting the Operator's Cab
7.5.5 Hoisting Malfunctions
7.5.6 Luffing Malfunctions
7.5.7 Slewing Malfunctions
8 Technical Data8.1 Crane
8.1.1 Dimensions
8.1.2 Noise Emission
8.1.3 Weight and Axle Load
8.1.4 Performance
8.2 Engine - Carrier
8.3 Engine - Superstructure
8.4 Transmission
8.5 Transfer Case
8.6 Outriggers
8.7 Outrigger floats
8.8 Suspension
8.9 Tires and Wheel Rim
8.10 Counterweights
8.11 Boom
8.11.1 Telescopic Boom
8.12 Hook
8.13 Hoist Ropes
8.14 Outrigger Pads
- Sany Rough Terrain Crane SRC865XL Parts Book
- Sany Rough Terrain Crane SRC840 Parts Book
- SANY Crawler Crane SCC700 Partbook
- SANY Crawler Crane SCC1000C Operation Manual
- SANY Truck Crane STC250S5 Parts Book
- SANY Rough Terrain Crane SRC865 SRC865XL Safety Operation & Maintenance Manual
- Sany Crawler Crane SCC500E Maintenance Manual
- Sany Reach Stacker SRSC45H1 Parts Book
- Sany Reach Stacker SRSC45H1 Installation Guideline
- Sany Crane STC550T5 Safety Operation & Maintenance Manual
- Sany Reach Stacker SRSC45C30 to SRSC3615-3 Safety Operation Maintenance Manual
- Sany All Terrain Crane SAC1600S Electrical Hydraulic Preneumatic Schematics
- Sany Truck Crane STC250T5-4 Parts Book QZJ100000392
- Sany Truck Crane STC250T5-4 Electrical Hydraulic Pneumatic Schematics QZJ100000392
- Sany Truck Crane STC250T5-5 Parts Book QZJ100000390
