meteoros
380
Mitchell Issue
Hi i'm trying to install mitchell ondemand,when copying repair data at "repair6" i have an error "invalid MS-dos function" with the file "REPTIFF832.MPZ, any one knows how to solve this?Thanks View attachment 8270
mrriadh
Active Member
5
15,273
#2
Hey mate
Try these steps to fix this issue:
1. Click Start, type regedit in the Start Search box, and then press ENTER.
2. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\System
3. On the Edit menu, point to New, and then click DWORD Value.
4. Type CopyFileBufferedSynchronousIo to name the new entry, and then press ENTER.
5. Right-click CopyFileBufferedSynchronousIo, and then click Modify.
6. In the Value data box, type 1, and then click OK.
7. Exit Registry Editor.
Registry Disclaimer:
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it.
meteoros
380
#4
i did a chkdsk /r and encounter an error...any way i'm gone try to use robocopy(you dont need to install a software,robocopy it's allready in win7) a powerfull tool to handle folders/files Robocopy
meteoros
380
#5
it gave an error using robocopy,try it in other external hdd gives the same error"invalid MS dos function",probably the file is corrupted,i need to know if i can download only the repair6 file...
