mrriadh
Active Member
5
15,273
Cat SIS full Iinstallation Guide + SIS 2011B + NetworkSISID 2012
I hope this clears up any confusion with the installation of Cat SIS full guide
How to Install SIS 2011B
Make a Folder on ANY place in the harddrive. I name mine CatSISData. Example: C:\Catsisdata
Copy all folders that are Labeled DVDD0001-02 to DVDR0014-02 to that folder.
Folder Descriptions and Contents.
You can copy all, or whichever folders you want. All Folders have different stuff in them. Example, I just wanted Truck Engines, So I only copied DVDD0001-02,DVDD0003-02
And DVDD0007-02 to the folder.
Open folder DVD_Image. Click Setup. Let it install completely.
Next open Folder RERD0010-02, then click setup. Let it install.
Last folder to open is RERD0011-02, then click that setup file, let it install.
Next is Licensing.
Open up KEYGEN.RAR
TURN OFF VIRUS PROGRAM
Select the File NetworkSISID_2012.exe
It will pop up with a Network adapter, and the ID below it, Click Apply serial. Cut and Paste the serial.
Run. KEYGEN.EXE
Paste the serial in the box for the KEYGEN, remove ALL spaces out of the serial. Set the date to expire about 10yrs is what I do, Click generate. If your original files
are not extracted, then the LiCENSE.DAT file will be asked to be transfered to the RAR file, the LICENSE.DAT file will generate in the same folder as the KEYGEN.exe file is located
Make a folder in the C:\ directory labeled FLEXLM. C:\FLEXLM
Copy the License.dat file to that folder.
Right Click, MY COMPUTER. Click on advance, and go down to Enviroment Variables
Make New variable.
Top Box will say CATLMD_LICENSE_File
Next Box will say C:\flexlm\license.dat
Run SIS, in the SIS Icon in tray, RIGHT CLICK, Click Configure. Add the DVD folder directorys so SIS can find them. For Example. C:\CATSISDATA\DVDD0001-02. Do this for all
Folders you Copied.
How to Install.
after you install you need to replace de sis.exe and sisserver.exe whit others that are patch (as i understand Smile) then you need to use a keygen to generate a license and copy the license (license.dat) to the folder named "flexlm" (you need to create a folder name flexlm in C:/flexlm/license.dat) then finally open sis.exe
so what you need is:
1. patched sis.exe and sisserver.exe
2. keygen for sis 2011b (2012 in other words)
3. your mac address (you need to copy your mac address to the keygen so it can generate a valid "license.dat")
4. make folder "flexlm" in C:/flexlm/
5. copy license.dat to flexlm folder like this (C:/flexlm/license.dat)
6. finally run sis.exe
7. almost forgot: you need also a sis user login and you need to import it to sis
thats all i rememmber if any one know more or if i missed something please help finish this guide
Disk 1:
TRUCK ENGINES
TRACK MATERIAL HANDLERS
ELECTRIC POWER GENERATION
EST
WHEEL SKIDDERS
LOAD HAUL DUMP
INDUSTRIAL ENGINES
MARINE ENGINES
EMAC
Disk 2:
MACHINE ENGINES
INDUSTRIAL ENGINES
MARINE ENGINES
Disk 3:
ELECTRICAL POWER GENERATION
INDUSTRIAL ENGINES
MARINE ENGINES
MACHINE ENGINES
COMPACTORS
OEM PRODUCTS
WHEEL TYPE TRACTORS
Disk 4:
WHEEL TYPE LOADERS
WHEEL TRACTOR SCRAPERS
WHEEL TYPE TRACTORS
Disk 5:
EXCAVATORS
WHEEL TYPE LOADER
Disk 6:
ARTICULATED DUMP TRUCKS
ASPHALT PAVERS
BACKHOE LOADERS
COLD PLANERS
MOTOR GRADERS
UNDERGROUND ARTICULATED TRUCKS
WORK TOOLS
INDUSTRIAL ENGINES
MACHINE ENGINES
Disk 7:
CHALLENGERS
COMBINES
EXCAVAORS
INTEGRATED TOOLCARRIERS
MINI EXCAVATORS
ON HIGHWAY TRUCK
PIPELAYERS, TILLAGE
TRACK TYPE TRACTORS
Disk 8:
ROAD RECLAIMER
TRACK TYPE TRACTORS
TRACK TYPE LOADERS
TRACK TYPE SKIDDERS
SKID STEER LOADERS
INDUSTRIAL ENGINE
MACHINE ENGINE
TRUCK ENGINE
EXCAVATORS
Disk 9:
EXCAVATORS
COMBINES
MINI EXCAVATORS
FORESTRY PRODUCTS
Disk 10:
EXCAVATORS
COMPACTORS
IENG
WTL
EMAC
BACKHOE LOADER
WKTL
Disk 11:
WHEEL TYPE SCRAPERS
WHEEL TYPE LOADERS
Disk 12: EXCAVATORS
Disk 13: TRACK TYPE TRACTORS
iman irawanto
1
550
#4
Next is Licensing.
Open up KEYGEN.RAR
Run. KEYGEN.EXE
Make New variable.
Folders you Copied.
How to Install.
Disk 1:
TRUCK ENGINES
EST
WHEEL SKIDDERS
LOAD HAUL DUMP
INDUSTRIAL ENGINES
MARINE ENGINES
EMAC
Disk 2:
MACHINE ENGINES
INDUSTRIAL ENGINES
MARINE ENGINES
Disk 3:
INDUSTRIAL ENGINES
MARINE ENGINES
MACHINE ENGINES
COMPACTORS
OEM PRODUCTS
WHEEL TYPE TRACTORS
Disk 4:
WHEEL TYPE LOADERS
WHEEL TYPE TRACTORS
Disk 5:
EXCAVATORS
WHEEL TYPE LOADER
Disk 6:
ASPHALT PAVERS
BACKHOE LOADERS
COLD PLANERS
MOTOR GRADERS
WORK TOOLS
INDUSTRIAL ENGINES
MACHINE ENGINES
Disk 7:
CHALLENGERS
COMBINES
EXCAVAORS
MINI EXCAVATORS
ON HIGHWAY TRUCK
PIPELAYERS, TILLAGE
TRACK TYPE TRACTORS
Disk 8:
ROAD RECLAIMER
TRACK TYPE TRACTORS
TRACK TYPE LOADERS
TRACK TYPE SKIDDERS
SKID STEER LOADERS
INDUSTRIAL ENGINE
MACHINE ENGINE
TRUCK ENGINE
EXCAVATORS
Disk 9:
EXCAVATORS
COMBINES
MINI EXCAVATORS
FORESTRY PRODUCTS
Disk 10:
EXCAVATORS
COMPACTORS
IENG
WTL
EMAC
BACKHOE LOADER
WKTL
Disk 11:
WHEEL TYPE SCRAPERS
WHEEL TYPE LOADERS
Disk 12: EXCAVATORS
Dear Team,
I have been donated 10$ but why I still can't download the file?
How many gallon needed?
Master
Cleaner
720
4,234,453
#5
Dear you, thank for your contribution. But to download this soft we need at least 700 Gallons. Please check again. Now you have 550 Gallons.
Fezza
964
#6
Hi There, can you please help me with the file, I have paid gallons and grabbed the download link, but it reports it as a virus??? cant download, all my browsers report the same, i have disabled my virus checker too. please help.
Cheers
Jason
