bizbyinc
Well-Known Member
3
1,883
MAN Industrial Diesel Engines D 2866 LUE 602 D 2866 LUE 605 Repair Manual
Brand: MAN Industrial
Type of Machine: Diesel Engines
Type of Manual: Repair Manual, Electrical Schematic Diagram
Model: MAN D 2866 LUE 602, D 2866 LUE 605 Engines
Number of Pages: 174 Pages
Instructions
Contents
Engine type classification
Safety instructions
General notes on engine overhaul
Commissioning after engine overhaul
Fault table
Troubleshooting chart
Engine views
Engine lubrication diagram
Fuel system diagram
Cooling system diagram
Engine management diagram
Fuel system
Checking and adjusting start of fuel delivery
Removing and Installing Injection Pump
Removing and Installing Injection Nozzles
Checking and repairing fuel injectors
Fuel prefilter
Removing and attaching fuel filter, exchanging filter cartridge
Flame starter sheathed-element glow plug, removing and installing
Cooling system
Draining and filling coolant
Removing and installing thermostats
Removing and installing engine water pump
Repairing engine water pump D 2866 LUE 602
Repairing coolant pump with high-temperature and low-temperature parts D 2866 LUE 605
Cleaning cooling system
Lubrification
Changing the oil filter
Removing and installing the oil cooler
Removing and installing the oil pan
Removing and installing / Repairing Oil Pump
Removing and Installing Oil Spray Nozzle
Flywheel / Crankshaft seal
Removing and fitting vibration damper, replacing front crankshaft gasket
Removing and installing flywheel, replacing starter gear ring
Removing and installing crankshaft seal (flywheel end)
Exchanging bearing race
Crankshaft seals
Intake / exhaust system
Removing and installing the intake manifold
Removing and installing exhaust manifold
Turbocharger, troubleshooting
Checking charging pressure
Removing and installing the turbocharger
Measuring the axial / radial clearance or the turbocharger shaft
Cylinder head
Removing and installing cylinder head
Setting valve clearance
Disassembling and Assembling Rocker Arm Mechanism
Removing and installing valves
Removing and installing valve guides
Replacing valve seat insert
Reworking valve seat
Refacing valves
Checking compression pressure
Crank gear, pistons
Removing and installing the gear case
Removing and installing the camshaft, replacing camshaft bearings
Checking the valve timing
Removing and installing the crankshaft
Removing and installing pistons with conrods
Removing pistons from conrod and fitting, checking - replacing conrod
Removing and installing / replacing piston rings
Replacing cylinder liners
Measuring Piston Protrusion
Removing and installing the starter motor
V-belts
Pilot clutch
Service Data
Specifications
Crankcase
Cylinder liner
Flywheel and starter motor gear ring
Conrods
Conrod bearings
Conrod bolts
Pistons
Cylinder head
Valve gear
Engine lubrication D 2866 LUE 602
Engine lubrication D 2866 LUE 605
Engine coolant pump D 2866 LUE 602
Turbocharger S3A - 91H39GAVM- 1.40CF6
Fuel system
Torque guide values
Cylinder-head bolts
Special tools
Index
