Land Pride Rotary Cutters RCM5020 RC5020 Series 2 Operation Manual 334-437M
- Download this document, you need 300 Gallons
Brand: Land Pride
Model: Land Pride RCM5020, RC5020 Series 2 Rotary Cutters
Serial Number: 1316082+
Part Number: 334-437M
Publication Date: 2023
Number of Pages: 70 Pages
Section 1: Assembly & Set-up
Tractor Requirements
Torque Requirements
Before You Start
Hitch Types
Tractor Shutdown Procedure
Hitch Assembly
Attach Park Jack
Standard Clevis Hitch Hook-up
LP Performance Hitch Hook-up
Bar-Tite Hitch Hook-up
Driveline Assembly
Driveline Hook-up to Tractor
Hydraulic Hook-up
Wing Axle Assembly to Center Axle
Remove Shipping Crossbar
Unfold Wings
Clearance Check
Driveline Hanger Adjustment
Purge Hydraulic System
Hook-up LED Lights
Remove Shipping Lugs
Unhook Rotary Cutters
Section 2: Adjustments
Park Jack Angle Alignment
LP Performance Hitch Hole Diameter
Level Cutter Decks
Adjust Deck Cutting Height
Wheel Spacing
Section 3: Operating Instructions
Startup Checklist
Safety Information
Tractor & Cutter Inspection
Avoid Extreme Turning Angles
Blade Operation Inspection
Transport Locks
Transporting
Road Side Cutting
Field Set-up
Section 4: Options & Accessories
Safety Guard Options
Hitch Options
Deck Ring Option
Blade Carrier Options
Tire & Axle Arrangement Options
Center Axle Options
Shredder Blade & Baffle Kit Options
Main Driveline Options
Hydraulic Accessories
Section 5: Maintenance & Lubrication
General Maintenance Information
Chain Guards
Skid Shoes
Gearbox Driveline Shielding
Gearbox Mounting Bolts
Tires
Cutter Blade Maintenance
Shredder Blades & Baffle Maintenance
Hitch Wear Points
Drivelines
Drivelines With Slip Clutches
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Section 6: Specifications & Capacities
Section 7: Features & Benefits
Section 8: Troubleshooting
Section 9: Torque & Tire Inflation Charts
Section 10: Warranty
Brand: Land Pride
Torque Requirements
Before You Start
Hitch Types
Hitch Assembly
Attach Park Jack
Driveline Assembly
Hydraulic Hook-up
Unfold Wings
Clearance Check
Hook-up LED Lights
Level Cutter Decks
Wheel Spacing
Startup Checklist
Safety Information
Transport Locks
Transporting
Road Side Cutting
Field Set-up
Hitch Options
Deck Ring Option
Center Axle Options
Chain Guards
Skid Shoes
Tires
Hitch Wear Points
Drivelines
Long-Term Storage
Lubrication Points
- Land Pride Grapple Buckets GB25 GBE25 GBE30 Series Operation Manual 380-192M
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Operation Manual 329-301M
- Land Pride Rotary Cutters RCF3696 RCFM3696 RCF3610 RCFM3610 Operator Manual 326-600M-FRC FR
- Land Pride Grapple Buckets GB25 GBE25 GBE30 Series Parts Manual 380-192P
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Operator Manual 329-301M-FRC FR
- Land Pride Rotary Cutters RCFM3696 RCF3696 Parts Manual 326-600P
- Land Pride Grapple Buckets SRB1566 to SSB1578 Operation Manual 380-101M
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Parts Manual 329-301P
- Land Pride Rotary Cutters RCFM4014 Operator Manual 326-730M
- Land Pride Grapples SGC1060 SGC1072 Operation Manual 380-092M
- Land Pride Multi-Purpose Seeder NTS2607 NTS2609 NTS2611 Operator Manual 329-141M-FRC FR
- Land Pride Rotary Cutters RCFM4014 Operator Manual 326-730M-FRC FR
- Land Pride Grapples SGC1060 SGC1072 Operator Manual 380-092M-FRC FR
- Land Pride No Till Seeder NTS2507 NTS2509 NTS2511 Operation Manual 313-629M 2018
- Land Pride Rotary Cutters RCFM4014 Parts Manual 326-730P
