Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Operation Manual 329-301M
Brand: Land Pride
Type of Machine: Multi-Purpose Seeder
Model: Land Pride MPS2607, MPS2609, MPS2611 Multi-Purpose Seeder
Part Number: 329-301M
Publication Date: 2024
Number of Pages: 78 Pages
Section 1: Assembly & Set-up
Tractor Requirements
Quick Hitch Compatibility
Torque Requirements
Dealer Preparations
Sling Bracket
Flex Guard Hose
Small Seeds Zero Adjustment Set-up
Tow Hitch Option
Acremeter Option
Hydraulic Plumbing For Tow Option
Purge Hydraulic System
Section 2: Operating Instructions
Operating Checklist
General Safety
Tractor Shutdown Procedure
Hook-up 3-Point Seeder
Check LED Lights
Check Tractor Clearance
Unhook 3-Point Seeder
Hook-up Pull-Type Seeder
Store Park Jack
Unhook Pull-Type Seeder
Install Transport Locks and Spacers
Transporting
Level Seeder With 3-Point Mount
Level Seeder With Pull Hitch
Fill Small Seeds Seedbox
Filling Grass Seedbox
Filling Native Seedbox
How the Seeder Works
Grass Seeds Transmission
All-Seeds Drive Lock In/Out Clutch
Native Seeds Lock In/out Sprocket
Small Seeds Lock In/out Sprocket
Lock In/Out Pin Operation
Operating the Seeder
Section 3: Roller Adjustments
Front Spike Roller Angle
Mud Scrapers
Section 4: Grass Seed Rate Adjustment
Grass Seedbox Drive Speed Ranges
Grass Seedbox Cup Gate Setting
Grass Seed Rate Adjustments
Calibrate Grass Seed Dispersal
Seed Rate Crank Instructions
Grass Seed Rate Chart (English)
Grass Seed Rate Chart (Metric)
Section 5: Small Seed Rate Adjustment
Small Seeds Seed Rate Adjustments
Calibrate Small Seeds Dispersal
Small Seed Rate Chart (English)
Small Seed Rate Chart (Metric)
Section 6: Native Seed Rate Adjustment
Native Seed Rate Adjustments
Calibrate Native Seed Dispersal
Native Seed Rate Chart
Section 7: Options & Accessories
Agitation Extension Kit (Accessory)
Electronic Acremeter (Option)
Slow Moving Vehicle Sign (Accessory)
Section 8: Maintenance & Lubrication
Maintenance
Roller Chains and Sprockets
Roller Chain Part Numbers
Front Spike Rollers
Rear Packer Roller
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Section 9: Specifications & Capacities
Section 10: Features & Benefits
Section 11: Troubleshooting
Section 12: Torque Values & Tire Inflation
Section 13: Warranty
