Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Operator Manual 329-301M-FRC FR
Language: French
Brand: Land Pride
Type of Machine: Multi-Purpose Seeder
Model: Land Pride MPS2607, MPS2609, MPS2611 Multi-Purpose Seeder
Part Number: 329-301M-FRC
Publication Date: 2024
Number of Pages: 78 Pages
Section 1: Assembly and Setup
Tractor Requirements
Quick Hitch Compatibility
Torque Requirements
Dealer Preparations
Sling Mount
Flexible Duct Hose
Zero Setting for Small Seeds
Tow Hitch Option
Area Meter Option
Hydraulic Plumbing for Tow Option
Hydraulic System Bleeding
Section 2: Operating Instructions
Operating Checklist
General Safety
Tractor Shutdown Procedure
3-Point Seeder Hitch
LED Light Check
Checking Tractor Clearance
Uncoupling the 3-Point Seeder
Hitching the Towed Seeder
Stowing the Parking Stand
Uncoupling the Towed Seeder
Installing the Transport Locks and Spacers
Transportation
Adjusting the Level of the 3-Point Seeder
Adjusting the Level of the Towed Seeder
Filling the Small Seeds Tank
Filling the Grass Seed Tank
Filling the Native Seed Tank Seeder Operation
Grass Seed Speed Selector
Inner/Outer Drive Sprocket Locking Clutch
for All Seeds
Inner/Outer Locking Sprocket for Native
Seeds
Inner/Outer Locking Sprocket for Small
Seeds
Inner/Outer Locking Pin Operation
Operating the Seeder
Section 3: Roller Adjustments
Front Spiked Roller Orientation
Mud Scrapers
Section 4: Grass Seed Rate Adjustment
Grass Hopper Drive Speed Ranges
Grass Seed Box Door Adjustment
Grass Seed Rate Settings
Grass Seed Dissemination Calibration
Seed Rate Crank Instructions
Pulley Seeder
Three-Point Mount Seeder
Installing the Seed Rate Crank
Storing the Seed Rate Crank
Grass Seed Rate Chart
(Metric Units)
(Imperial Units)
Section 5: Small Seed Rate Adjustment
Small Seed Rate Adjustments
Small Seed Rate Calibration
Small Seed Rate Chart (Metric Units)
Small Seed Rate Chart (Imperial Units)
(Metric
Section 6: Native Seed Rate Adjustment
Native Seed Rate Adjustments
Native Seed Dissemination Calibration
Native Seed Rate Chart
Section 7: Options and Accessories
Agitator Extension Kit (Accessory)
Electronic Area Meter (Optional)
Slow Moving Vehicle Sign (Accessory)
Section 8: Maintenance and Lubrication
Maintenance
Roller Chains and Sprocket Wheels
General Maintenance
Drive Chains for All Seeds
(Nos. 3, 6, and 9)
Drive Chain for Grass Seeds
(No. 12)
Gear Selector Drive Chain (No. 15)
Small Seed Drive Chain (No. 18)
Native Seed Hopper
Main Drive Chain for Native Grass Seed (No. 1)
Transmission Drive Chain for Native Grass Seed (No. 5)
Native Grass Seed Cup Drive Chain (No. 10)
Native Grass Seed Agitator Drive Chain (No. 14)
Roller Chain Part Numbers
Drive Chains for All Seeds and Small Seeds
Drive Chains for Native Seeds
Front Spiked Rollers
Rear Roller
Long-Term Storage
Ordering Spare Parts
Lubrication Points
Front Roller Bearings
Rear Roller Left End Bearing
Rear Roller Right End Bearing
Rear Roller Center Bearings
Small Seed Drive Sprocket Bearing
Native Seed Drive Sprocket Bearings
Seed cup drive shafts
All seed drive sprockets
Roller chains
Seed cup sprocket teeth and nylon washers
Transmission box for native seed hopper
Axle Bearing
Section 9: Specifications and Capacities
Section 10: Features and Benefits
Section 11: Troubleshooting
Section 12: Tire Torque and Inflation
Section 13: Warranty
