Land Pride Rotary Cutters RCM4715 RCGM4715 RC4715 RCG4715 Operator Manual 334-113M
- Download this document, you need 300 Gallons
Brand: Land Pride
Model: Land Pride RCM4715, RCGM4715, RC4715, RCG4715 Rotary Cutters
Part Number: 334-113M
Publication Date: 2023
Number of Pages: 74 Pages
Section 1: Assembly & Set-up
Tractor Requirements
Drawbar Set-up
Hydraulic Outlets
Torque Requirements
Before You Start
Hitch Types
Tractor Shutdown Procedure
Hitch Assembly
Attach Park Jack
Attach Spring Hose Loop
Swivel Clevis Hitch Hook-up
LP Performance Hitch Hook-up
Bar-Tite Hitch Hook-up
Hydraulic Hook-up
Wing Axle Turnbuckle Set-up
Unfold Wings
Fold Lock Lugs Set-up
Driveline Assembly
Driveline Hook-up to Tractor
Driveline Hanger Adjustment
Driveline Clearance Check
Purge Hydraulic System
Deck Lift Cylinder
Hook-up LED Lights
Remove Shipping Lugs
Unhook Rotary Cutters
Section 2: Adjustments
Park Jack Angle Alignment
Lift Cylinder Adjustment
Level Cutter Decks
Adjust Cutter Height
LP Performance Hitch Hole Size
Section 3: Operating Instructions
Startup Checklist
Safety Information
Tractor & Cutter Inspection
Avoid Extreme Turning Angles
Blade Operation Inspection
Transport Pins
Transporting
Field Set-up
Engage Blades
Disengage Blades
Blade Carrier Blockage Removal During Field Use
Section 4: Options & Accessories
Safety Chain Guards
Hitches
Deck Protection Options
Wing Fold Options
Tire Options & Configurations
Axle Options and Configurations
Slow Moving Vehicle Sign Accessory
Main Drivelines
Blade Carrier Options
Blade Accessories
Single Duplex Accessory
Dual-Acting Lift Cylinder Accessory
Section 5: Maintenance & Lubrication
General Maintenance
Tires
Gearbox Driveline Shielding
Drivelines
Drivelines With Slip Clutches
Clutch Run-in
Clutch Disassembly, Inspection & Assembly
Cutter Blades
Hitch Wear Points
Skid Shoes
Stroke Control Flip Spacer Replacement
Chain Guards
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Section 6: Specifications & Capacities
Section 7: Features & Benefits
Section 8: Troubleshooting
Section 9: Torque & Tire Inflation Chart
Section 10: Warranty
Brand: Land Pride
Drawbar Set-up
Hydraulic Outlets
Torque Requirements
Before You Start
Hitch Types
Hitch Assembly
Attach Park Jack
Hydraulic Hook-up
Unfold Wings
Driveline Assembly
Deck Lift Cylinder
Hook-up LED Lights
Level Cutter Decks
Startup Checklist
Safety Information
Transport Pins
Transporting
Field Set-up
Engage Blades
Disengage Blades
Safety Chain Guards
Hitches
Wing Fold Options
Main Drivelines
Blade Accessories
General Maintenance
Tires
Drivelines
Clutch Run-in
Cutter Blades
Hitch Wear Points
Skid Shoes
Chain Guards
Long-Term Storage
Lubrication Points
- Land Pride Grapple Buckets GB25 GBE25 GBE30 Series Operation Manual 380-192M
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Operation Manual 329-301M
- Land Pride Rotary Cutters RCF3696 RCFM3696 RCF3610 RCFM3610 Operator Manual 326-600M-FRC FR
- Land Pride Grapple Buckets GB25 GBE25 GBE30 Series Parts Manual 380-192P
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Operator Manual 329-301M-FRC FR
- Land Pride Rotary Cutters RCFM3696 RCF3696 Parts Manual 326-600P
- Land Pride Grapple Buckets SRB1566 to SSB1578 Operation Manual 380-101M
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Parts Manual 329-301P
- Land Pride Rotary Cutters RCFM4014 Operator Manual 326-730M
- Land Pride Grapples SGC1060 SGC1072 Operation Manual 380-092M
- Land Pride Multi-Purpose Seeder NTS2607 NTS2609 NTS2611 Operator Manual 329-141M-FRC FR
- Land Pride Rotary Cutters RCFM4014 Operator Manual 326-730M-FRC FR
- Land Pride Grapples SGC1060 SGC1072 Operator Manual 380-092M-FRC FR
- Land Pride No Till Seeder NTS2507 NTS2509 NTS2511 Operation Manual 313-629M 2018
- Land Pride Rotary Cutters RCFM4014 Parts Manual 326-730P
