Land Pride Rotary Cutters RCM4715 RC4715 RCGM4715 RCG4715 Operator Manual 334-113M-FRC FR
Language: French
Brand: Land Pride
Model: Land Pride RCM4715, RC4715, RCGM4715, RCG4715 Rotary Cutters
Part Number: 334-113M-FRC
Publication Date: 2020
Number of Pages: 72 Pages
Section 1: Assembly and Setup
Tractor Requirements
Drawbar Setup
Hydraulic Outlets
Before You Begin
Torque Requirements
Hitch Types
Tractor Shutdown Procedure
Hitch Mounting
Attaching the Parking Jack
Attaching the Spring Hose Loop
Swivel Clevis Hitch
Land Pride Performance Hitch Hitch
Bar-Tite Drawbar Hitch Hitch
Hydraulic Connection
Side Axle Idler Setup
Fender Extension
Locking Knuckle Pin Setup
Driveshaft Mounting
Connecting the Driveshaft to the Tractor
Adjusting the Driveshaft Bracket
Checking Driveshaft Freeplay
Bleeding the Hydraulic System
Mower Deck Lift Cylinder
Connecting the LED Lights
Removing the Shipping Pins
Unhitching the Brushcutter Rotary
Section 2: Adjustments
Parking Stand Angle Alignment
Lift Cylinder Adjustment
Leveling Mower Decks
Cutting Height Adjustment
Land Pride Performance Hitch Hole Diameter
Section 3: Operating Instructions
Starting Checklist
Safety Information
Tractor and Trimmer Inspection
Avoiding Extreme Turn Angles
Blade Operation Inspection
Transport Pins
Traveling
Field Setup
Engaging the Blades
Disengaging the Blades
Removing Blade Carrier Locks During Field Operation
Section 4: Options and Accessories
Safety Chain Guards
Hitches
Mower Deck Protection Options
Fender Articulation Options
Tire Options and Configurations
Axle Options and Configurations
Slow Moving Vehicle Panel Attachment
Main Drive Shafts
Blade Carrier Options
Blade Attachments
Single Dual Outlet Attachment
Dual Lift Cylinder Attachment Action
Section 5: Maintenance and Lubrication
General Maintenance
Tires
Driveshaft Housing Cover
Driveshafts
Driveshafts with Slip-On Torque Limiters
Clutch Break-in
Clutch Removal, Inspection, and Installation
Brushcutter Blades
Hitch Wear Points
Skids
Swappable Stroke Control Spacer Replacement
Chain Guards
Long-Term Storage
Ordering Spare Parts
Lubrication Points
Section 6: Specifications and Capacities
Section 7: Features and Benefits
Section 8: Troubleshooting
Section 9: Tire Torque and Inflation Pressure Chart
Section 10: Warranty
