702,019
Land Pride Rotary Cutters RCM3715 RC3715 Operator Manual 334-114M-SPA ES
Language: Spanish
Brand: Land Pride
Model: Land Pride RCM3715, RC3715 Rotary Cutters
Part Number: 334-114M-SPA
Publication Date: 2023
Number of Pages: 68 Pages
Section 1: Assembly And Installation
Tractor Requirements
Horsepower
Drawbar Preparation
Hydraulic Valves
Before You Begin
Torque Requirements
Hitch Types
Two-Position Clevis Hitch (Optional)
Land Pride Performance Hitch (Optional)
Bar-Tite Drawbar Receiver Hitch
(Optional)
Ball Hitch (Optional)
Ring Hitch (Optional)
Tractor Shutdown Procedure
Hitch Assembly
Parking Stand Installation
Spring Hose Holder Installation
Two-Position Clevis Hitch Installation
Land Pride Performance Hitch Installation
Bar-Tite Drawbar Receiver Hitch Installation
Hydraulic System Installation
Wing Axle Tensioner Preparation
Deploying The Wings
Preparing The Locking Plates For Folding
Assembling The Driveshaft
Mounting The Driveshaft To The Tractor
Adjusting The Driveshaft Support Hook
Checking The Driveshaft Clearance
Bleeding The Hydraulic System
Wing Folding Cylinder
Cover Lift Cylinder
Connecting The Led Lights
Removing The Transport Locks
Disassembling The Trimmer
Change Of Location Of Slow-Moving Vehicle Sign
Section 2: Adjustments
Lift Cylinder Adjustment
Parking Stand Angle Alignment
Leveling The Trimmer Covers
Leveling The Center Cover
Leveling The Wing Covers
Adjusting The Trimmer Height
Land Pride Performance Hitch Hole Size
Section 3: Operating Instructions
Start-Up Checklist
Safety Information
Tractor And Cutter Inspection
Avoid Extreme Swing Angles
Blade Operation Inspection
Transport Safety Bolts
Transport
Mowing Along The Sides Of The Roads
Field Preparation
Ground Inspections
Deploying The Wings And Adjusting The Cutting Height Of The Deck
Placing The Wing Lift Lever In The Hover Position
Selecting The Speed Range
Starting The Blades
Disengaging The Blades
Section 4: Options And Accessories
Safety Chain Guards
Tire And Axle Layout
Hitches
Main Driveshafts
Wing Folding Options
Optional Deck Protector Ring
Kit For Using A Single Dual Valve Box
Slow-Moving Vehicle (Smv) Warning
Section 5: Maintenance And Lubrication
General Maintenance
Tires
Skids
Transmission Case Driveshaft Guard
Drive Shafts With Sliding Clutch
Clutch Disassembly, Inspection, And Assembly
Haulm Cutter Blades
Hitch Wear Points
Two-Position Clevis Hitch Wear Points
Land Pride Performance Hitch Wear Points
Bar-Tite Drawbar Receiver Hitch Wear Points
Long-Term Storage
Ordering Spare Parts
Lubrication Points
Section 6: Specifications And Capacities
Section 7: Features And Benefits
Section 8: Troubleshooting
Section 9: Tire Torque And Inflation Charts
Section 10: Warranty
