Land Pride Rotary Cutters RCF3610 RCFM3610 Parts Manual 326-423P
Brand: Land Pride
Model: Land Pride RCF3610 RCFM3610 Rotary Cutters
Part Number: 326-423P
Publication Date: 2024
Number of Pages: 128 Pages
Section 1: Introduction
Using This Manual
Manual Replacement Information
Manual Revisions
Touch-up Paint
Hardware Legend
Replacement Hardware
Serial Numbers
Part Number Service Coding
Section 2: Deck
Deck Components
Section 3: Hitch & Tailwheel
Axle Lift Hydraulic or Manual 3-Point
Axle Lift Hydraulic or Manual Pull Type/SemiMount
Hitch 3-Point
Hitch Pull Type Tounge S/N 1151135-
Hitch Pull Type Tounge S/N 1151136+
Hub & Spindle Assembly (331-795L)
Hub Assembly (330-938K)
Hydraulic Cylinder (810-384C) Cross
Hydraulic Cylinder (850-449C) Cross
Performance Hitch
Swivel Hitch
Tail Wheel 3-Point/ Semi-Mount W/ 15" Lam
Tire
Tail Wheel 3-Point/Semi-Mount W/ 21" Lam
Tire
Transport Axle Pull Type
Section 4: Blade Drive
Blade Carrier CCW
Blade Carrier CW
Blade Drive 3-Point & Semi-Mount
Blade Drive Pull Type W/ CV
Blade Drive Pull Type W/ Equal Angle
Driveline 540 RPM (826-215C) Eurocardan
Driveline 540 RPM (826-220C) Eurocardan
Driveline (826-053C) Walterscheid
Driveline (826-053C) Weasler
Driveline (826-063C) Walterscheid
Driveline (826-151C) Eurocardan
Driveline (826-216C) Eurocardan
Driveline (826-880C) Comer
Driveline (826-881C) Comer
Driveline (826-892C) Comer
Driveline Flex Coupler (826-334C)
Eurocardan
Driveline Jackshaft (540 RPM) (826-220C)
Eurcardan
Driveline Jackshaft (1000 RPM) (826-221C)
Eurocardan
Driveline Pull Type Conv 1000 RPM (826-
223C) Eurocardan
Driveline Slip Clutch (1406016) Eurocardan
Driveline Slip Clutch (1406116) Eurocardan
Driveline Slip Clutch (1406128) EC
Driveline Slip Clutch (1446016) Eurocardan
Driveline Slip Clutch (1446137) Eurocardan
Driveline Stub Shaft Pull Type 540 RPM (826-
225C) Eurocardan
Driveline Stub Shaft Pull Type 1000 RPM
(826-226C) Eurocardan
Flex Coupler (826-969C)
Gearbox (826-315C) Comer
Gearbox (826-356C) Comer
Gearbox (826-424C) Comer
Gearbox (826-666C) Comer
Section 5: Guards
Guard Chain Dual Front
Guard Chain Dual Rear
Guard Chain Single Front
Guard Chain Single Rear
Guard Rubber Front
Guard Rubber Rear
Section 6: Decals & Paint
Decals 3-Point
Decals A-Frame Hitch S/N 1151136 to
153822
Decals Pull Type S/N 153822-
Decals Pull Type S/N 153823+
Land Pride Touch-up Paints
