702,169
Land Pride Rotary Cutters RCF2060 RCF2072 Operator Manual 326-459M-FRC FR
Download this document, you need 250 Gallons
Language: French
Brand: Land Pride
Model: Land Pride RCF2060 RCF2072 Rotary Cutters
Part Number: 326-459M-FRC
Publication Date: 2023
Number of Pages: 38 Pages
Important Safety Information
Look for the Safety Alert Symbol
Safety at All Times
Safety Labels
Introduction
Application
Using This Manual
Terminology:
Definitions:
Owner Assistance
Serial Number
Additional Assistance
Section 1: Mounting and Setup
Tractor Requirements
Tractor Shutdown Procedure
Unpacking Instructions
Torque Requirements
Transmission Vent Gauge
Three-Point Hitch and Rear Wheel Installation
Driveshaft Installation
Hitching to Tractor
Hitching the Driveshaft to Tractor
Checking Clearances
Checking the Driveshaft Retractable Length
Shortening the Driveshaft
Checking the Maximum Driveshaft Length
Checking Driveshaft Interference
Section 2: Attachment and Option Configuration
Replaceable Skid Shoes (Accessory)
Optional Front Shields
Installing the Front Single-Row Chain Guard
Installing the Front Rubber End Cap
Optional Rear Shields
Removing the Rear Metal Strip Deflector
Rear Single-Row Chain Guard
Installing the Rear Rubber End Cap
Section 3: Adjustments
Cutter Deck Leveling and Cutting Height
Leveling the Cutter Deck from Left to Right
Cutter Deck Cutting Height
Adjusting the Rear Wheel Height
Adjusting the Tractor's Center Three-Point Hitch
Section 4: Operating Instructions
Operation Checklist
Safety Information
Tractor and Brushcutter Inspection
Moving
Engaging and Disengaging the Blades
Engaging the Blades
Disengaging the Blades Blades
Rotary Brushcutter Disconnect
Field Operation
Section 5: Maintenance and Lubrication
Maintenance
Brushcutter Blade Maintenance
Drive Shaft Protection
Drive Shaft Protected with a Shear Bolt
Drive Shafts Protected with a Friction Torque Limiter
Clutch Break-in
Clutch Installation and Removal
Disassembly
Accessory Pad Maintenance
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Gauge Wheel Spindle Tube
Gauge Wheel Hub
Transmission Box
Drive Shaft Universal Joints
Drive Shaft Protector Bushings
Drive Shaft Profiles
Section 6: Specifications and Capacities
Section 7: Features and Benefits
Section 8: Troubleshooting
Section 9: Tightening Torque Table
Section 10: Warranty
