Land Pride Rotary Cutters RCBM5710 RCB5710 RCBML5710 RCBL5710 Operation Manual 337-049M
Brand: Land Pride
Model: Land Pride RCBM5710, RCB5710, RCBML5710, RCBL5710 Rotary Cutters
Part Number: 337-049M
Publication Date: 2024
Number of Pages: 86 Pages
Section 1: Assembly & Set-up
Tractor Requirements
Hydraulic Outlets
Drawbar Set-up
Torque Requirements
Tractor Shutdown Procedure
Before You Start
Hitch Options
Hitch Assembly
Attach Park Jack
Attach Spring Hose Loop
Hook-up Constant Level Clevis Hitch
Hook-up LP Performance Hitch
Hook-up Bar-Tite Hitch
Hydraulic Plumbing
Hydraulic Hook-up
Unfold Wing
Fold Lock Lugs Set-up
Driveline Assembly
Driveline Hook-up to Tractor
Driveline Support Adjustment
Driveline Clearance Check
Purge Hydraulic System
Rephase Lift Cylinders
Hook-up LED Lights
Unhook Rotary Cutters
Section 2: Adjustments
LP Performance Hitch Hole Size
Park Jack Angle Alignment
Lift Cylinder Base Mount
Level Center & Wing Deck
Adjust Cutter Height
Section 3: Operating
Operator’s Responsibilities
Safety Information
Roadside Cutting
Avoid Extreme Turning Angles
Tractor & Cutter Inspection
Blade Operation Inspection
Transport Lock
Transporting
Field Set-up
Engage Blades
Disengage Blades
Remove Blade Carrier Blockage
Section 4: Options & Accessories
Safety Chain Guards
Hitches
Wing Fold Options
Tire Options & Configurations
Deck Protection Options
Driveline Options
Blade Carrier Options
Blade Accessories
Axle Options and Configurations
Mechanical Wing Lift Option
Toolbox Option
Tow Lug Option
Slow Moving Vehicle Sign Accessory
Section 5: Maintenance & Lubrication
General Maintenance
Gearbox Driveline Shielding
Drivelines
Drivelines With Slip Clutches
Clutch Run-in
Clutch Disassembly, Inspection & Assembly
Cutter Blades
Hitch Wear Points
Skid Shoes
Flip Spacer Replacement
Chain Guards
Tires
Axle Pivot Bushings
Repack Wheel Hub Bearings
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Section 6: Specifications & Capacities
Section 7: Features & Benefits
Section 8: Troubleshooting
Section 9: Torque Values Chart
Section 10: Warranty
