Land Pride Rotary Cutters RCB5715 RCBM5715 Operation Manual 337-046M
Brand: Land Pride
Model: Land Pride RCB5715, RCBM5715 Rotary Cutters
Part Number: 337-046M
Publication Date: 2024
Number of Pages: 88 Pages
Section 1: Assembly & Set-up
Tractor Requirements
Hydraulic Outlets
Drawbar Set-up
Torque Requirements
Tractor Shutdown Procedure
Before You Start
Hitch Options
Hitch Assembly
Attach Park Jack
Attach Spring Hose Loop
Hook-up Constant Level Clevis Hitch
Hook-up LP Performance Hitch
Hook-up Bar-Tite Hitch
Hydraulic Plumbing
Hydraulic Hook-up
Unfold Wings
Fold Lock Lugs Set-up
Driveline Assembly
Driveline Hook-up to Tractor
Driveline Support Adjustment
Driveline Clearance Check
Purge Hydraulic System
Deck Lift Cylinders
Rephase Lift Cylinders
Hook-up LED Lights
Unhook Rotary Cutters
Section 2: Adjustments
LP Performance Hitch Hole Size
Park Jack Angle Alignment
Lift Cylinder Base Mount
Level Center & Wing Decks
Adjust Cutter Height
Section 3: Operating Instructions
Startup Checklist
Safety Information
Roadside Cutting
Tractor & Cutter Inspection
Blade Operation Inspection
Transporting
Transport Locks
Field Set-up
Avoid Extreme Turning Angles
Engage Blades
Disengage Blades
Remove Blade Carrier Blockage
Section 4: Options & Accessories
Safety Chain Guards
Hitches
Wing Fold Options
Tire Options & Configurations
Deck Protection Options
Axle Options and Configurations
Driveline Options
Blade Carrier Options
Blade Accessories
Mechanical Wing Lift Option
Toolbox Option
Tow Lug Option
Slow Moving Vehicle Sign Accessory
Section 5: Maintenance & Lubrication
General Maintenance
Gearbox Driveline Shielding
Drivelines
Drivelines With Slip Clutches
Clutch Run-in
Clutch Disassembly, Inspection & Assembly
Cutter Blades
Hitch Wear Points
Skid Shoes
Flip Spacer Replacement
Chain Guards
Tires
Axle Pivot Bushings
Repack Wheel Hub Bearings
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Section 6: Specifications & Capacities
Section 7: Features & Benefits
Section 8: Troubleshooting
Section 9: Torque & Tire Inflation Chart
Section 10: Warranty
