702,169
Land Pride Rotary Cutters RCB5710 to RCBL5710 Operator Manual 337-049M-FRC FR
Language: French
Brand: Land Pride
Model: Land Pride RCB5710, RCBL5710, RCBM5710, RCBML5710 Rotary Cutters
Part Number: 337-049M-FRC
Publication Date: 2024
Number of Pages: 84 Pages
Important Safety Information
Safety At All Times
Look For The Safety Alert Symbol
Safety Labels
Introduction
Application
Patented And Patent Pending
Using This Manual
Owner Assistance
Serial Number
Section 1: Mounting And Configuration
Tractor Requirements
Drawbar Configuration
Hydraulic Outlets
Torque Requirements
Before You Begin
Hitch Options
Thickness-Free Hitch
Land Pride Performance Hitch
Bar-Tite Bar Hitch
Ball Hitch
Float Pin Hitch
Hitch Mounting
Parking Stand Mount
Spring Hose Loop Attachment
Constant Level Clevis Hitch
Land Pride Performance Hitch Hitch
Bar-Tite Hitch Hitch
Hydraulic Plumbing
Folding Mechanism Assembly
Single-Action Hinge Assembly
Double-Action Hinge Assembly
Lift Re-Phasing Assembly
Lift Cylinder Re-Phasing And Plumbing
Hydraulic Connection
Wing Unfolding
Configuring The Locking Articulation Pins
Mounting The Drive Shaft
Connecting The Drive Shaft To The Tractor
Adjusting The Drive Shaft Support
Checking The Drive Shaft Play
Bleeding The Hydraulic System
Bleeding The Side Articulated Cylinder
Mower Deck Lift Cylinders
Rephasing The Lift Cylinders
Connecting The Led Lights
Uncoupling The Rotary Cutters
Moving The Slow Moving Vehicle (Smv) Sign
Section 2: Adjustments
Land Pride Performance Hitch Hole Diameter
Parking Stand Angle Alignment
Lift Cylinder Base Assembly
Leveling The Center And Side Mower Decks
Cutting Height Adjustment
Section 3: Operation
Operator Responsibilities
Safety Information
Tractor Stopping Procedure
Tractor And Brushcutter Inspection
Avoid Extreme Turning Angles
Inspecting Blade Operation
Transport Lock
Moving
Roadside Cutting
Field Configuration
Field Inspection
Unfolding The Wing
Adjusting The Blade Cutting Height
Adjusting The Wing Lift Device
To Float Position
Speed Range Selection
Blade Engagement
Blade Disengagement
Blade Holder Obstruction Removal
Section 4: Options And Accessories
Safety Chain Guards
Hitches
Fender Hinge Options
Tire Options And Configurations
Cutting Deck Protection Options
Axle Options And Configurations
Center Axle Options
Heavy-Duty Single Suspension Center Axle
Independent Suspension Center Axle
Tandem Center Travel Axle
Parallel Pivot Center Axle
Side Axle Options
Independent Side Axle
Tandem Side Travel Axle
Parallel Pivot Side Axle
Drive Shaft Options
Main Drive Shaft, 540 Rpm
Without Overrunning Clutch
With Overrunning Clutch
Main Drive Shaft, 1000 Rpm
Blade Support Options
Blade Attachments
Optional Mechanical Wing Lift
Optional Toolbox
Optional Tow Pins
Slow-Moving Vehicle Sign Accessory
Section 5: Maintenance And Lubrication
General Maintenance
Tires
Drive Shaft Housing
Access To The Side Driveshaft Gearbox Cover
Sliding Central Driveshaft Gearbox Cover
Driveshafts
Driveshafts With Friction Torque Limiters
Clutch Running-In
Disassembly, Inspection And Assembly Of The Clutch
Disassembly
Inspection
Assembly
Brushcutter Blades
Hitch Wear Points
Hitch Clevis Wear Point
At Constant Level
Land Pride Performance Hitch Wear Points
Bar-Tite Drawbar Hitch Wear Points
Skids
Fender Side Guard
Side Deck Skids
Center Skids
Swappable Spacer Replacement
Chain Guards
Axle Pivot Bushings
Long-Term Storage
Ordering Spare Parts
Lubrication Points
Axle Bearing
Parking Jack
Deck Hinges With Lowered Wing
Land Pride Performance Hitch (Optional)
Bar-Tite Drawbar Hitch (Optional)
Transmission And Separator Lubrication
Lubrication Point For The Side Drive Shaft Protection Cover
Side Drive Shaft Profile Tubes
Side Drive Shaft Seals
Intermediate Drive Shaft Seals
Lubrication Point For The Main Constant Velocity Drive Shaft Protection Cover
Main Driveshaft Profiled Tubes
With External Grease Point
Main Driveshaft Cv Joints
Access To Driveshaft Joints
Section 6: Specifications And Capacities
Section 7: Features And Benefits
Section 8: Troubleshooting
Section 9: Tightening Torque Table
Section 10: Warranty
