702,019
Land Pride Rotary Cutters RC5710 to RCML5710 Operator Manual 331-433M-FRC FR
Language: French
Brand: Land Pride
Model: Land Pride RC5710, RCL5710, RCM5710, RCML5710 Rotary Cutters
Part Number: 331-433M-FRC
Publication Date: 2024
Number of Pages: 82 Pages
Section 1: Mounting and Configuration
Tractor Requirements
Drawbar Configuration
Hydraulic Outlets
Torque Requirements
Before You Begin
Hitch Options
Thickness-Free Hitch
Land Pride Performance Hitch
Bar-Tite Bar Hitch
Ball Hitch
Float Pin Hitch
Hitch Mounting
Parking Stand Mount
Spring Hose Loop Attachment
Constant Level Clevis Hitch
Land Pride Performance Hitch Hitch
Bar-Tite Hitch Hitch
Hydraulic Connection
Side Axle Idler Setup
Unfolding the Wing
Configuring the Locking Hinge Pins
Mounting the Drive Shaft
Connecting the Drive Shaft to the Tractor
Adjusting the Drive Shaft Support
Checking the Drive Shaft Play
Bleeding the Hydraulic System
Side Articulated Cylinder
Cutter Deck Lift Cylinder
Connecting LED Lights
Uncoupling the Rotary Trimmer
Moving the Slow Moving Vehicle (SMV) Sign
Section 2: Adjustments
Hitch Hole Diameter
Parking Stand Angle Alignment
Lift Cylinder Base Assembly
Leveling the Center and Side Decks
Adjusting the Cutting Height
Section 3: Operation
Operator Responsibilities
Safety Information
Tractor Stopping Procedure
Tractor and Brushcutter Inspection
Avoid Extreme Turning Angles
Blade Operation Inspection
Transport Lock
Movement
Roadside Cut
Field Setup
Field Inspection
Wing Unfolding
Adjusting the Blade Cutting Height
Adjusting the Wing Lift Device to the Float Position
Selecting the Speed Range
Engaging the Blades
Disengaging the Blades
Removing the Obstruction from the Blade Holder
Section 4: Options and Accessories
Safety Chain Guards
Hitches
Wing Articulation Options
Tire Options and Configurations
Cutter Deck Protection Options
Axle Options and Configurations
Center Axle Options
Heavy-Duty Single-Suspension Center Axle
Independent-Suspension Center Axle
Tandem Center Travel Axle
Parallel Pivot Center Axle
Side Axle Options
Heavy-Duty Single-Suspension Side Axle
Independent-Suspension Side Axle
Tandem Side Travel Axle
Parallel Pivot Side Axle
Driveshaft Options
Main Drive Shaft, 540 rpm
without Overrunning Clutch
with Overrunning Clutch
Main Drive Shaft, 1000 rpm
Blade Support Options
Blade Accessories
Double-acting lifting cylinder attachment
Optional mechanical wing lift
Optional tool box
Optional hitch pins
Slow-moving vehicle sign attachment
Section 5: Maintenance and Lubrication
General Maintenance
Tires
Drive shaft gearbox cover
Access to the side drive shaft gearbox cover
Sliding central drive shaft gearbox cover
Drive shafts
Drive shafts with friction torque limiters
Clutch Break-in
Disassembly, Inspection and Assembly of the Clutch
Disassembly
Inspection
Assembly
Brushcutter blades
Hitch wear points
Hitch Clevis Wear Point
Constant Level
Land Pride Performance Hitch Wear Points
Bar-Tite Drawbar Hitch Wear Points
Skids
Side Skid Guard
Side Deck Skids
Center Skids
Swappable Spacer Replacement
Chain Guards
Axle Pivot Bushings
Long-term storage
Spare Parts Ordering
Lubrication Points
Axle Bearing
Adjustable Tensioner
Parking Stand
Cutter Deck Hinges with Lowered Wing
Land Pride Performance Hitch (Optional)
Bar-Tite Drawbar Hitch (Optional)
Transmission and Splitter Lubrication
Side Drive Shaft Cover Grease Point
Side Drive Shaft Profile Tubes
Side Drive Shaft Seals
Intermediate Driveshaft Joints
Main CV Driveshaft Protective Cover Grease Point
Main CV Driveshaft Profiled Tubes with External Grease Point
Main Driveshaft CV Joints
Access to CV Driveshaft Joints
Section 6: Specifications and Capacities
Section 7: Features and Benefits
Section 8: Troubleshooting
Section 9: Torque Chart
Section 10: Warranty
