Land Pride Rotary Cutters RC5710 RCM5710 RCL5710 RCML5710 Operation Manual 331-433M
Brand: Land Pride
Model: Land Pride RC5710, RCM5710, RCL5710, RCML5710 Rotary Cutters
Part Number: 331-433M
Publication Date: 2024
Number of Pages: 84 Pages
Section 1: Assembly & Set-Up
Tractor Requirements
Hydraulic Outlets
Drawbar Set-Up
Torque Requirements
Tractor Shutdown Procedure
Before You Start
Hitch Options
Hitch Assembly
Attach Park Jack
Attach Spring Hose Loop
Hook-Up Constant Level Clevis Hitch
Hook-Up Lp Performance Hitch
Hook-Up Bar-Tite Hitch
Hydraulic Hook-Up
Wing Axle Turnbuckle Set-Up
Unfold Wing
Fold Lock Lugs Set-Up
Driveline Assembly
Driveline Hook-Up To Tractor
Driveline Support Adjustment
Driveline Clearance Check
Purge Hydraulic System
Deck Lift Cylinder
Hook-Up Led Lights
Unhook Rotary Cutters
Section 2: Adjustments
Lp Performance Hitch Hole Size
Park Jack Angle Alignment
Lift Cylinder Base Mount
Level Center & Wing Decks
Adjust Cutter Height
Section 3: Operating
Operator’s Responsibilities
Safety Information
Road Side Cutting
Avoid Extreme Turning Angles
Tractor & Cutter Inspection
Transport Lock
Transporting
Blade Operation Inspection
Field Set-Up
Engage Blades
Disengage Blades
Remove Blade Carrier Blockage
Section 4: Options & Accessories
Safety Chain Guards
Hitches
Wing Fold Options
Tire Options & Configurations
Deck Protection Options
Axle Options And Configurations
Driveline Options
Blade Carrier Options
Blade Accessories
Dual-Acting Lift Cylinder Accessory
Mechanical Wing Lift Option
Toolbox Option
Tow Lug Option
Slow Moving Vehicle Sign Accessory
Section 5: Maintenance & Lubrication
General Maintenance
Gearbox Driveline Shielding
Drivelines
Drivelines With Slip Clutches
Clutch Run-In
Clutch Disassembly, Inspection & Assembly
Cutter Blades
Hitch Wear Points
Skid Shoes
Flip Spacer Replacement
Chain Guards
Tires
Axle Pivot Bushings
Repack Wheel Hub Bearings
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Section 6: Specifications & Capacities
Section 7: Features & Benefits
Section 8: Troubleshooting
Section 9: Torque Values Chart
Section 10: Warranty
Brand: Land Pride
Hydraulic Outlets
Drawbar Set-Up
Torque Requirements
Before You Start
Hitch Options
Hitch Assembly
Attach Park Jack
Hydraulic Hook-Up
Unfold Wing
Driveline Assembly
Deck Lift Cylinder
Hook-Up Led Lights
Safety Information
Road Side Cutting
Transport Lock
Transporting
Field Set-Up
Engage Blades
Disengage Blades
Safety Chain Guards
Hitches
Wing Fold Options
Driveline Options
Blade Accessories
Toolbox Option
Tow Lug Option
General Maintenance
Drivelines
Clutch Run-In
Cutter Blades
Hitch Wear Points
Skid Shoes
Chain Guards
Tires
Axle Pivot Bushings
Long-Term Storage
Lubrication Points
- Land Pride Grapple Buckets GB25 GBE25 GBE30 Series Operation Manual 380-192M
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Operation Manual 329-301M
- Land Pride Rotary Cutters RCF3696 RCFM3696 RCF3610 RCFM3610 Operator Manual 326-600M-FRC FR
- Land Pride Grapple Buckets GB25 GBE25 GBE30 Series Parts Manual 380-192P
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Operator Manual 329-301M-FRC FR
- Land Pride Rotary Cutters RCFM3696 RCF3696 Parts Manual 326-600P
- Land Pride Grapple Buckets SRB1566 to SSB1578 Operation Manual 380-101M
- Land Pride Multi-Purpose Seeder MPS2607 MPS2609 MPS2611 Parts Manual 329-301P
- Land Pride Rotary Cutters RCFM4014 Operator Manual 326-730M
- Land Pride Grapples SGC1060 SGC1072 Operation Manual 380-092M
- Land Pride Multi-Purpose Seeder NTS2607 NTS2609 NTS2611 Operator Manual 329-141M-FRC FR
- Land Pride Rotary Cutters RCFM4014 Operator Manual 326-730M-FRC FR
- Land Pride Grapples SGC1060 SGC1072 Operator Manual 380-092M-FRC FR
- Land Pride No Till Seeder NTS2507 NTS2509 NTS2511 Operation Manual 313-629M 2018
- Land Pride Rotary Cutters RCFM4014 Parts Manual 326-730P
