704,032
Land Pride Rotary Cutters RC5615 RCM5615 RC6615 RCM6615 Parts Manual 330-323P
Brand: Land Pride
Model: Land Pride RC5615, RCM5615, RC6615, RCM6615 Rotary Cutters
Serial Number: 944729-
Part Number: 330-323P
Publication Date: 2024
Number of Pages: 240 Pages
Section 1: Introduction
Using This Manual
Manual Replacement Information
Manual Revisions
Touch-up Paint
Hardware Legend
Replacement Hardware
Serial Numbers
Part Number Service Coding
Section 2: Decks & Hitches
Blade Carrier (5615)
Blade Carrier (6515 & 6615)
Deck Center Section (RC56)
Deck Center Section (RC66)
Deck Wing Section (RC56)
Deck Wing Section (RC66)
Hitch Ball Coupler
Hitch Bar Tite
Hitch LP Performance S/N 1000385-
Hitch Main Frame
Hitch Pintel
Hitch Standard Pivoting Clevis
Hitch Swivel
Leveling Rod & Wing Turnbuckle
Section 3: Axles
Axle Center Dual S/N 774710-
Axle Center Dual S/N 774711+
Axle Wing S/N 774710-
Axle Wing S/N 774711+
HD Hub Kit (337-068K)
Section 4: Guards
Guards Chain Double Row Front
Guards Chain Double Row Rear
Guards Chain Single Row Front
Guards Chain Single Row Rear
Guards Chain W/ Cable Front
Guards Chain W/ Cable Rear
Guards Rubber Front
Guards Rubber Rear
Section 5: Drivelines
Driveline (826-112C) Walterscheid
Driveline (826-183C) Eurocardan
Driveline (826-184C) Eurocardan
Driveline (826-185C) EC New Shielding S/N
929016-
Driveline (826-247C) Walterscheid
Driveline (826-643C) Weasler
Driveline (826-793C) Weasler
Driveline Center (826-478C) Comer
Driveline Center (826-818C) Comer
Driveline CV 138 1000 RPM (826-644C)
Weasler
Driveline CV 540 RPM (826-476C) Comer
Driveline CV 1000 RPM (826-477C) 1 3/8-21
Comer
Driveline CV 1000 RPM (826-499C) 1 3/4-20
Comer
Driveline CV 1000 RPM (826-645C) Weasler
Driveline Slip Clutch 1000 RPM (1406016)
Eurocardan
Driveline Slip Clutch (229829X0)
Walterscheid
Driveline Slip Clutch (395980) Walterscheid
Driveline Slip Clutch (1406116) Eurocardan
Driveline Slip Clutch (1446016) EC
Driveline Slip Clutch (1462640241) Comer
Driveline Slip Clutch (1462840201) Comer
Driveline Wing (826-185C) Walterscheid
Driveline Wing (826-481C) Comer
Driveline Wing (826-481C) Walterscheid
Driveline Wing (826-811C) Comer
Driveline Wing (826-812C) Comer
Driveline Wing (826-812C) Walterscheid
Section 6: Gearboxes
Gearbox (826-315C) Comer
Gearbox (826-316C) Comer
Gearbox (826-317C) Comer
Gearbox (826-318C) Comer
Gearbox (826-319C) Comer
Gearbox (826-320C) Comer
Gearbox (826-321C) Comer
Gearbox (826-322C) Comer
Gearbox (826-323C) Comer
Gearbox (826-324C) Comer
Gearbox (826-547C) Comer
Gearbox (826-626C) Comer
Gearbox (826-650C) Comer
Gearbox (826-666C) Comer
Gearbox (826-721C) Comer
Gearbox (826-725C) Comer
Gearbox (826-726C) Comer
Gearbox (826-729C)
Gearbox (826-730C)
Gearbox (826-732C)
Gearbox (826-920C) Comer
Gearbox (826-921C) Comer
Gearbox (826-922C) Comer
Gearbox (826-923C) Comer
Gearbox (826-924C) Comer
Gearbox (826-925C) Comer
Gearbox (826-928C) Comer
Gearbox (826-929C) Comer
Gearbox (827-927C) Comer
Gearbox Divider 540 RPM (826-520C) Omni
Gearbox Divider 1000 RPM (826-521C) Omni
Gearbox Divider (826-520C) Comer
Gearbox Divider (826-520C) ITG
Gearbox Divider (826-521C) Comer
Gearbox Divider (826-521C) ITG
Section 7: Hydraulics
Hydraulic Lift Components
Hydraulic Cylinder (810-162C) Cross
Hydraulic Cylinder (810-162C) Midway
Hydraulic Cylinder (810-162C) Red Lion
Hydraulic Cylinder (810-644C) Midway
Hydraulic Independent Wing Control
Accessory
Hydraulic Valve Selector Assessory
Hydraulic Valve Spool Control Accessory
Section 8: Decals
Decal Placement
Land Pride Touch-up Paints
Section 9: Options & Accessories
Export Lights Front
Export Lights Hydraulics
Export Lights Rear Standard Axle
Manual Winch Wing Deck
Shredder/Baffle Components Center Deck
Shredder/Baffle Components LH Deck
Shredder/Baffle Components RH Deck
Tire Options
