Land Pride Rotary Cutters RC5615 RC6615 RCM5615 RCM6615 Series 2 Operator Manual 330-323M
702,169
Brand: Land Pride
Model: Land Pride RC5615, RC6615, RCM5615, RCM6615 Series 2 Rotary Cutters
Serial Number: 944730+
Part Number: 330-323M
Publication Date: 2020
Number of Pages: 72 Pages
Important Safety Information
Safety at All Times
Look For The Safety Alert Symbol
Safety Labels
Introduction
Application
Using This Manual
Owner Assistance
Section 1: Assembly & Set-up
Tractor Requirements
Before You Start
Torque Requirements
Hitch Types
Hitch Assembly
Park Jack Assembly
Tractor Shutdown Procedure
Standard Clevis Hitch Hook-up
LP Performance Hitch Hook-up
Bar-Tite Hitch Hook-up
Hydraulic Hook-up
Wing Axle Turnbuckle Set-up
Driveline Assembly
Driveline Hook-up
Driveline Hanger Adjustment
Driveline Clearance Check
Purge Hydraulic System
Lift Cylinder Mount Position
Adjust Light Kit
Hook-up LED Lights
Remove Shipping Lugs
Unhook Rotary Cutters
Section 2: Adjustments
Park Jack Angle Alignment
LP Performance Hitch Pin Diameter
Level Cutter Decks
Adjust Deck Cutting Height
Section 3: Operating Instructions
Startup Checklist
Safety Information
Tractor & Cutter Inspection
Avoid Extreme Turning Angles
Blade Operation Inspection
Transport Locks
Transporting
Roadside Cutting
Field Set-up
Section 4: Options & Accessories
Safety Guards
Low Lift Blade Accessory
Tire Options
Hitch Options
Hydraulic Accessories
Mechanical Wing Lift
EU Export Light Kit (Accessory)
Shredder Blades
Section 5: Maintenance & Lubrication
General Maintenance Information
Tires
Skid Shoes & Side Skirts
Spindle Gearbox Shaft Guard
Wing Axle Turnbuckles
Cutter Blades
Drivelines With Slip Clutches
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Section 6: Specifications & Capacities
Section 7: Features & Benefits
Section 8: Troubleshooting
Section 9: Torque & Tire Inflation Charts
Section 10: Warranty
