Land Pride Rotary Cutters RC5610 RC6610 RCM5610 RCM6610 Series 2 Operation Manual 330-539M
702,019
Brand: Land Pride
Model: Land Pride RC5610, RC6610, RCM5610, RCM6610 Series 2 Rotary Cutters
Serial Number: 944730+
Part Number: 330-539M
Publication Date: 2020
Number of Pages: 70 Pages
Important Safety Information
Safety at All Times
Look For The Safety Alert Symbol
Safety Labels
Introduction
Application
Using This Manual
Owner Assistance
Section 1: Assembly & Set-up
Tractor Requirements
Before You Start
Torque Requirements
Hitch Types
Hitch Assembly
Park Jack Assembly
Tractor Shutdown Procedure
Standard Clevis Hitch Hook-up
LP Performance Hitch Hook-up
Bar-Tite Hitch Hook-up
Hydraulic Hook-up
Unfold Wing
Driveline Assembly
Driveline Hook-up
Driveline Hanger Adjustment
Driveline Clearance Check
Purge Hydraulic System
Lift Cylinder Mount Position
Adjust Light Kit
Hook-up LED Lights
Remove Shipping Lugs
Unhook Rotary Cutters
Section 2: Adjustments
Park Jack Angle Alignment
LP Performance Hitch Pin Diameter
Level Cutter Decks
Adjust Deck Cutting Height
Section 3: Operating Instructions
Startup Checklist
Safety Information
Tractor & Cutter Inspection
Blade Operation Inspection
Transport Lock
Transporting
Road Side Cutting
Field Set-up
Section 4: Options & Accessories
Safety Guards
Low Lift Blade Accessory
Tire & Axle Arrangements
Hitches
Selector Control Valve Kit
EU Export Light Kit (Accessory)
Mechanical Wing Lift
Section 5: Maintenance & Lubrication
General Maintenance Information
Tires
Skid Shoes & Side Skirt
Wing Axle Turnbuckle
Spindle Gearbox Shaft Guard
Cutter Blades
Drivelines With Slip Clutches
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Section 6: Specifications & Capacities
Section 7: Features & Benefits
Section 8: Troubleshooting
Section 9: Torque Values Chart
Section 10: Warranty
