702,019
Land Pride Rotary Cutters RC5020 RCM5020 Operation Manual 318-474M
Brand: Land Pride
Model: Land Pride RC5020, RCM5020 Rotary Cutters
Serial Number: 1316081-
Part Number: 318-474M
Publication Date: 2018
Number of Pages: 60 Pages
Important Safety Information
Safety at All Times
Look for the Safety Alert Symbol
Safety Labels
Introduction
Application
Using This Manual
Terminology
Definitions
Owner Assistance
Serial Number
Section 1: Assembly & Set-up
Tractor Requirements
Horsepower
Drawbar Set-up
Hydraulic Set-up
Torque Requirements
Before You Start
Hitch Types
Standard Clevis Hitch
Land Pride Performance Hitch (Optional)
Bar-Tite Hitch (Optional)
Ball Hitch (Optional)
Pintle Hitch (Optional)
Hitch Assembly
Wing Axle Assembly to Center Axle
Tractor Shutdown Procedure
Standard Clevis Hitch Hook-up
LP Performance Hitch Hook-up
Bar-Tite Hitch Hook-up
Driveline Assembly
Driveline Hook-up
Hydraulic Hook-up
Unfold Wings
Driveline Clearance Check
Purge Hydraulic System
Hook-up LED Lights
Unhook Rotary Cutters
Section 2: Adjustments
Level Cutter Decks
Adjust Deck Cutting Height
LP Performance Hitch Pin Diameter
Section 3: Operating Instructions
Startup Checklist
Safety Information
Tractor & Cutter Inspection
Avoid Extreme Turning Angles
Blade Operation Inspection
Transport Locks
Transporting
Road Side Cutting
Field Set-up
Field Inspection
Section 4: Options & Accessories
Safety Guards
Tire Options
Hitch Options
Hydraulic Accessories
Hydraulic Wing Control Kit
3 Spool Control Valve Kit
Selector Control Valve Kit
Section 5: Maintenance & Lubrication
General Maintenance Information
Tires
Skid Shoes
Center Skid Shoes
Wing Skid Shoes
Gearbox Mounting Bolts
Cutter Blades
Drivelines With Slip Clutches
Type A Clutches
Type B Clutches
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Axle Hub Bearing
Adjustable Turnbuckle
Hitch Frame
Wing Axle Pivot Pins
Center Axle Pivot Pins
Double Swivel Clevis Hitch
Bar-Tite Hitch
Gearbox
Wing Driveline Profile Tubes
Wing Driveline Joints & Shields
Intermediate Driveline Joints
Conventional Driveline Profile Tubes
Conventional Driveline Joints & Shields
CV Main Driveline Profile Tubes
CV Main Driveline Joints & Shields
Section 6: Specifications & Capacities
Section 7: Features & Benefits
Section 8: Troubleshooting
Section 9: Torque & Tire Inflation Charts
Section 10: Warranty
