702,019
Land Pride Rotary Cutters RC4620 RCM4620 Operator Manual 331-936M-FRC FR
Language: French
Brand: Land Pride
Model: Land Pride RC4620, RCM4620 Rotary Cutters
Part Number: 331-936M-FRC
Publication Date: 2017
Number of Pages: 66 Pages
Section 1: Assembly And Setup
Tractor Requirements
Before You Begin
Torque Requirements
Hitch Types
Mounting The Hitch
Mounting The Stationary Stand
Tractor Shutdown Procedure
Connecting The Standard Clevis Hitch
Connecting The Performance Lp Hitch
Connecting The Bar-Tite Bar Hitch
Rephasing The Cylinders And Plumbing
Articulating Cylinders And Fender Plumbing
Hydraulic Hitch
Removing The Shipping Crossbar
Unfolding The Side Decks
Relocating The Fender Lift Cylinder Brackets
Installing The Driveline
Attaching The Driveline To The Tractor
Adjusting The Driveline Bracket
Checking Driveline Play
Bleeding The Hydraulic System
Unhooking The Rotary Cutters
Section 2: Adjustments
Aligning The Stationary Stand Angle
Leveling The Decks Cutting Height Adjustment
Hitch Pin Diameter Performance Lp
Section 3: Operating Instructions
Starting Checklist
Safety Information
Avoid Extreme Turn Angles
Tractor And Trimmer Inspection
Blade Operation Inspection
Transport Locks
Transportation
Roadside Cutting
Field Setup
Section 4: Options And Attachments
Hitch Options
Tire And Axle Options
Safety Shields
Hydraulic Attachments
Light Kit Option (Led)
Mulcher Blades
Section 5: Maintenance And Lubrication
General Maintenance Information
Tractor Maintenance
Tire Maintenance
Skid Shoes
Cutter Blade Maintenance
Slip-Clutch Driveshafts
Transmission Shaft Shield
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Section 6: Specifications And Capacities
Section 7: Features And Benefits
Section 8: Troubleshooting
Section 9: Tire Pressure And Torque Charts
Section 10: Warranty
