Land Pride Rotary Cutters RC4615 RCM4615 Operator Manual 331-644M-FRC FR
Language: French
Brand: Land Pride
Model: Land Pride RC4615, RCM4615 Rotary Cutters
Part Number: 331-644M-FRC
Publication Date: 2017
Number of Pages: 66 Pages
Section 1: Assembly and Setup
Tractor Requirements
Before You Begin
Torque Requirements
Hitch Types
Mounting the Hitch
Mounting the Stationary Stand
Mounting the Loop Spring Hose
Tractor Shutdown Procedure
Connecting the Standard Clevis Hitch
Connecting the Performance LP Hitch
Connecting the Bar-Tite Bar Hitch
Hydraulic Hitch
Right and Left Fender Configuration
Lowering the Fenders
Installing the Driveshaft
Attaching the Driveshaft to the Tractor
Adjusting the Driveshaft Stand
Checking Driveshaft Play
Bleeding the Hydraulic System
Lift Cylinder Mounting Position
Removing Cylinder Port Plugs
Unhooking the Rotary Trimmer
Section 2: Adjustments
Aligning the Stationary Stand Angle
Leveling the Mower Decks
Adjusting the Cutting Height
Diameter of the LP Performance Hitch Pin
Section 3: Operating Instructions
Starting Checklist
Safety Information
Avoiding Extreme Turn Angles
Tractor and Trimmer Inspection
Blade Operation Inspection
Transport Locks
Transporting
Roadside Cutting
Field Setup
Section 4: Options and Accessories
Safety Device
Tire and Axle Options
Hitch Options
Light Kit Option (LED)
Hydraulic Attachments
Mechanical Wing Lift
Section 5: Maintenance and Lubrication
General Maintenance Information
Tractor Maintenance
Tire Maintenance
Trimmer Blade Maintenance
Slip-Clutch Driveshafts
Skid Shoe Maintenance
Axle Gearbox Shaft Guard
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Section 6: Specifications and Capacities
Section 7: Features and Benefits
Section 8 : Troubleshooting
Section 9: Tire Inflation Pressure and Torque Chart
Section 10: Warranty
