Land Pride Rotary Cutters RC4610 RCM4610 Operation Manual 334-144M
Brand: Land Pride
Model: Land Pride RC4610 (540 RPM), RCM4610 (1000 RPM) Rotary Cutters
Part Number: 334-144M
Publication Date: 2019
Number of Pages: 68 Pages
Important Safety Information
Safety At All Times
Look For The Safety Alert Symbol
Safety Labels
Introduction
Application
Using This Manual
Owner Assistance
Section 1: Assembly & Set-Up
Tractor Requirements
Before You Start
Torque Requirements
Hitch Types
Hitch Assembly
Park Jack Assembly
Spring Hose Loop Assembly
Tractor Shutdown Procedure
Standard Clevis Hitch Hook-Up
Lp Performance Hitch Hook-Up
Bar-Tite Hitch Hook-Up
Hydraulic Hook-Up
Wing Set-Up
Unfold Wing
Driveline Assembly
Driveline Hook-Up
Adjust Driveline Hanger
Driveline Clearance Check
Purge Hydraulic System
Lift Cylinder Mounting Position
Adjust Light Assemblies
Hook-Up Led Lights
Remove Shipping Lugs
Unhook Rotary Cutters
Section 2: Adjustments
Align Park Jack Vertically
Level Cutter Decks
Adjust Cutting Height
Lp Performance Hitch Hole Size
Section 3: Operating Instructions
Startup Checklist
Safety Information
Avoid Extreme Turning Angles
Tractor & Cutter Inspection
Blade Operation Inspection
Transport Lock
Transporting
Road Side Cutting
Field Set-Up
Section 4: Options & Accessories
Safety Guard
Tire & Axle Arrangements
Hitch Options
Selector Control Valve Kit
Mechanical Wing Lift
Section 5: Maintenance & Lubrication
General Maintenance Information
Tire Maintenance
Skid Shoes
Spindle Gearbox Shaft Guard
Cutter Blade Maintenance
Drivelines With Slip Clutches
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Section 6: Specifications & Capacities
Section 7: Features & Benefits
Section 8: Troubleshooting
Section 9: Torque & Tire Inflation Chart
Section 10: Warranty
