702,019
Land Pride Rotary Cutters RC3712 RCM3712 Operation Manual 334-203M
Brand: Land Pride
Model: Land Pride RC3712, RCM3712 Rotary Cutters
Part Number: 334-203M
Publication Date: 2023
Number of Pages: 66 Pages
Important Safety Information
Safety at All Times
Look for the Safety Alert Symbol
Safety Labels
Introduction
Application
Using This Manual
Owner Assistance
Section 1: Assembly & Set-up
Tractor Requirements
Before You Start
Torque Requirements
Hitch Types
Tractor Shutdown Procedure
Hitch Assembly
Attach Park Jack
Attach Spring Hose Loop
Swivel Clevis Hitch Hook-up
LP Performance Hitch Hook-up
Bar-Tite Hitch Hook-up
Hydraulic Hook-up
Wing Axle Turnbuckle Set-up
Unfold Wings
Driveline Assembly
Driveline Hook-up to Tractor
Driveline Hanger Adjustment
Driveline Clearance Check
Purge Hydraulic System
Hook-up LED Lights
Remove Shipping Lugs
Unhook Rotary Cutters
Section 2: Adjustments
Lift Cylinder Adjustment
Park Jack Angle Alignment
Level Cutter Decks
Adjust Cutter Height
LP Performance Hitch Hole Size
Section 3: Operating Instructions
Startup Checklist
Safety Information
Tractor & Cutter Inspection
Blade Operation Inspection
Transport Pins
Transporting
Road Side Cutting
Field Set-up
Section 4: Options & Accessories
Safety Chain Guards
Hitches
Main Drivelines
Tire & Axle Arrangements
Slow Moving Vehicle Sign (SMV)
Single Duplex Accessory
Section 5: Maintenance & Lubrication
General Maintenance
Tires
Chain Guards
Skid Shoes
Gearbox Driveline Shielding
Drivelines
Drivelines With Slip Clutches
Cutter Blades
Hitch Wear Points
Long-Term Storage
Ordering Replacement Parts
Lubrication Points
Section 6: Specifications & Capacities
Section 7: Features & Benefits
Section 8: Troubleshooting
Section 9: Torque & Tire Inflation Chart
Section 10: Warranty
